Radical Revs Auto- Midnight Star-1987 Mitsubishi Starion Built Barra Swap! 1300HP
99 replies to this topic
#21 TexasQuest
  • 9,110 posts
Posted 08 November 2016 - 09:38 PM
Thanks for the link jimnx. That pipe sticking up looks hilarious.
88 Fiji Blue -TSi
#22 Bradrock
Bradrock
  • 957 posts
Posted 08 November 2016 - 09:44 PM
Sounds like a wicked build.
Are you saying that Brian Crower is building your engine? Or that you are using his parts?
Run's with scizzor's
#23 Mach 5
Mach 5
  • 510 posts
Posted 08 November 2016 - 10:03 PM
If ya got a vin # I can match it.. this car has been sitting for at least 14 years before I bought it... would be pretty cool!
I will be building my engine.. some of the machine work as well. Brian Crower sells a stroker kit slightly larger than Tomei kit and has a longer rod to correct the geometry
Owner- Radical Revs Auto- Jarek-
-Rides-
-1987 Starion -Midnight Star - FORD BARRA GTX4508r Build Progress see link
http://www.starquest...howtopic=152434
-1989 Chrysler Conquest-Track Beast Mode gtx3071r TBI 365hp 407tq @19psi/ 401hp 430tq @ 24psi sold
http://www.starquest...ic=151885&st=40
-1989 Pontiac Grand Prix Turbo SE- 3.1 gtx3582r getrag284 Tilton twin disc
-1991 Toyota Hilux Pickup 1uz itb cp pistons kelford cams TripleR head porting/ long tubes
-1986 AE86 20v.. 171hp@ 8200rpm
#24 jinx
jinx
  • 2,007 posts
Posted 09 November 2016 - 04:27 AM
could'nt u just go the beaten path, rb30 ?
crower and brian crower stuff is a mixed bag. I'd take any oem nissan part over their 'questionable' stuff
I got two budys that r RB die hards.
First done 6.8sec 1/8th rb25 s13 5sp (pulls hella hard for a daily street ride imo). His rb30 been stuggling to match the 6.8
The other goes 6.7 1/8th rb26 s14 5sp. Soon to find out how his new rb30 does
Neither wanted to push their stock 25/26 bottom ends any further, or spray.... hence the move to 30
#25 Mach 5
Mach 5
  • 510 posts
Posted 09 November 2016 - 09:25 AM
Ive  heard good things and seen the crank personally. Should be okay.
I was looking to rev to 9500 only reason not to RB30. block is weaker so I read
yer friends rb30 must be smoking them tires!!
Edited by Mach 5, 09 November 2016 - 09:35 AM.
-Rides-
#26 Mach 5
Mach 5
  • 510 posts
Posted 04 December 2016 - 05:11 PM
Edited by Mach 5, 04 December 2016 - 05:14 PM.
-Rides-
#27 Mach 5
Mach 5
  • 510 posts
Posted 04 December 2016 - 05:14 PM
update: Wedge seat brackets fit like garbage.
-Jarek
-Rides-
#28 Mach 5
Mach 5
  • 510 posts
Posted 04 December 2016 - 05:17 PM
now Im reading the rb blocks like to crack. trying to find alternatives to make this work. I think its mainly related to that skylines are 4wd. and how the front differential mounts through the engine. It may not be an issue on our rwd cars...
-Rides-
#29 TheDemon
TheDemon
  • 351 posts
  • Interests:Cars, Wrenching, Gaming, cars
Posted 04 December 2016 - 09:05 PM
Mach 5, i think you would benefit from checking out the Z car forums... Many of those guys have done or looked into the rb setups for rwd
- The Demon
89 Black Conquest TSI SHP 5-speed - Restoration
00 ford ranger trailhead
97 Red Talon ESi - RIP
#30 Mach 5
Mach 5
  • 510 posts
Posted 05 December 2016 - 12:26 AM
been researching non stop... totally obsessed.. haha! ;)
updated videos of seat brackets
Edited by Mach 5, 05 December 2016 - 12:26 AM.
-Rides-
#31 TexasQuest
  • 9,110 posts
Posted 05 December 2016 - 12:35 AM
Welcome to the world of Wedge Engineering brackets. Mine fit like crap too and had to hack them up to get them to fit halfway decent. The driver seat leans over a little bit toward the consol. I have no idea what car they measured them from.....
88 Fiji Blue -TSi
#32 Mach 5
Mach 5
  • 510 posts
Posted 05 December 2016 - 12:50 AM
Its crazy! I would've just made my own but I just wanted to bolt n go.. terrible. Ill be contacting the company this week. overall Im happy once they were fitted properly. passenger seat very close to door but I don't see much room to move it over.
they definitely were leaning before I fixed them. 1/4in off In height on one side!
Edited by Mach 5, 05 December 2016 - 12:54 AM.
-Rides-
#33 jinx
jinx
  • 2,007 posts
Posted 05 December 2016 - 03:17 AM
Quote
dunno about that one. They can't like crack more than our g54s :D
i know 25s, 26s & 30s all differ.... neither of the examples mentioned above had n e issues
their worst condition; 2 step launch on slicks, full street cars. Relatively mild Tomei 260 cams
Now if u planning that hi rpm stuff.... good luck
on a side note, a couple corolla clubmembers cammed up their turbo 1.6 builds, shifts past 10,000rpm. All their blocks cracked
None of the conventional 8000rpm 1.6s did.... and they et'd the same as the 10k cars. I never saw the point of the hi rpm crap
#34 Mach 5
Mach 5
  • 510 posts
Posted 05 December 2016 - 08:07 AM
was planning on going to 9500. my ae86 20v did 8500 no problem all day but n/a no boost. looking for around 750hp
-Rides-
#35 Turbo Cary
Turbo Cary
  • 1,799 posts
Posted 05 December 2016 - 08:39 PM
Just FYI the old Z31 300zx's came in the form of a 200ZR in Japan. It was an RB20 powered Z. I believe you can use that oil pan for an easy RWD swap
#36 Mach 5
Mach 5
  • 510 posts
Posted 05 December 2016 - 10:46 PM
thanx ill have to check that out!!
-Rides-
#37 Mach 5
Mach 5
  • 510 posts
Posted 06 December 2016 - 01:14 AM
-Rides-
#38 Turbo Cary
Turbo Cary
  • 1,799 posts
Posted 06 December 2016 - 12:06 PM
Found a link for you. Hope it helps with your swap
http://forums.hybrid...these-oil-pans/
#39 Mach 5
Mach 5
  • 510 posts
Posted 08 December 2016 - 10:06 PM
Street Lethal started on the cage...
-Rides-
#40 Funky Phil
Funky Phil
    Super Pooper
  • 6,465 posts
Posted 09 December 2016 - 12:26 PM
Good fit. Are you doing a cage or a roll bar?
Edited by Funky Phil, 09 December 2016 - 12:27 PM.
