D2- measurement 2 this will help us all out.
I-W D2
20 replies to this topic
#1 importwarrior
  • 17,703 posts
Posted 17 June 2014 - 05:28 PM
ok here we go again.
i am ready to do my D2's and would like a measurement.
just take a measurement.
i would like to know what you measured for the front and rear struts.
i would like there to be no fender gap on stock tires and rims.
in the pic below just pic a color of where you measured and post your measurements please..
Edited by importwarrior, 17 June 2014 - 05:30 PM.
#2 speedyquest
speedyquest
  • 3,701 posts
Posted 17 June 2014 - 06:03 PM
Another thing you may want to ask about is camber settings up front. That will effect it too.
#3 randy
randy
  • 4,089 posts
Posted 17 June 2014 - 06:31 PM
Maybe BC99 might chime in being he does the mods.
#4 BC_99
BC_99
    Plays in traffic
  • 5,130 posts
Posted 17 June 2014 - 06:34 PM
I wish I had some numbers for you guys, but don't as of yet. I have only done the welding and fabrication side of things. I haven't actually installed them and played with the heights yet. Sorry,
BC_99
#5 JohnnyWadd
JohnnyWadd
  • Banned
  • 8,936 posts
Posted 17 June 2014 - 07:30 PM
I can measure mine, I have some fender gap. Text me.
#6 importwarrior
  • 17,703 posts
Posted 17 June 2014 - 08:02 PM
Just thought all D2 people could benefit from having a good base setup for when they install their D2's
#7 JohnnyWadd
JohnnyWadd
  • Banned
  • 8,936 posts
Posted 17 June 2014 - 08:52 PM
Here is mine up front I have 4 inched front perch to top of threaded collars
It right at 22  3/5 at the highest part of the fender arch after jouncing the front.
Edited by JohnnyWadd, 18 June 2014 - 11:25 PM.
#8 importwarrior
  • 17,703 posts
Posted 18 June 2014 - 05:16 AM
great!!!
Thank you very much for the info.
Edited by importwarrior, 18 June 2014 - 05:19 AM.
#9 jisleyjr
jisleyjr
  • 1,254 posts
Posted 24 June 2014 - 09:37 AM
One thing i have noticed is that people aren't mentioning the preload. I assume everyone's d2s arrived with the springs being loose, so no preload at all.
I am not even sure how to say what i set my preload too? Maybe the height/length of the spring? Can anyone measure the height of springs when there is no preload?
What are people using for the rebound/bound setting? I started with 10 clicks turning it clockwise (0 is softest) and found that to be bouncy, i think am closer to mid 20's now and i still think it's too soft at times like during a corner, uneven pavement, or if i get on the throttle i feel like i am squatting too much.
Is there a connection between the preload of the spring and the rebound/bound setting and how the car should handle? I am sitting pretty low right now too, comparable to JohnnyWadd's photo.
1988 Conquest, Fiji with blue/grey cloth interior. Magna MPI/MS2/EDIS-4, D2's, td05h/s16g
1987 Starion, Black Ext and Black Leather, parts car :(
1983 Starion, Black Ext and grey cloth interior, driveway queen
2006 Acura TL, Anthracite Ext with Black Leather, rolling on 18's.
#10 importwarrior
  • 17,703 posts
Posted 24 June 2014 - 10:47 AM
I didn't think the springs needed to be messed with.
the adjustment for height is separate from the springs.
#11 Maxzillian
Maxzillian
    Car Shaman
  • 2,650 posts
  • Interests:Autocrossing, atv riding, general tinkering, machining, a few other things.
Posted 24 June 2014 - 11:02 AM
I have preloaded my springs some as no preload lets the car bottom out too much. The only trouble now is that the shocks don't have internal bump stops so if the suspension drops into a hole, there is usually a very solid thud when it runs out of travel.
I want to say my front is at .75" preload and rear is 1-1.25. I do feel that my shocks have way too little dampening for the springs they ship with.
What's the fun in making something simple?
'87 TSI - StarOrion braided brake lines, StarOrion radiator, StarOrion alternator, StarOrion 2.5" stainless exhaust w/Magnaflow muffler, 1G MAS, Competition Clutch 15 lb flywheel, Competition Clutch Stage 4 clutch, Mookeh polyurethane bushings, ABS elimination, 8:1 Wiseco Pistons, TD05 14G turbocharger, Axiss ceramic rear brake pages, Hawk HP+ front pads, heat wrapped and ported exhaust manifold/turbine housing, Accusump oil accumulator, remote oil filter, NJV head, EVO intercooler, remote battery, D2 coil over struts, flatty front struts and control arms, 8" non-SHP wheels all four corners, 12.75"x1.25" front rotors with 4 pot Wilwood calipers, manual brakes using dual master cylinders and balance bar, gutted (deleted) brake proportioning valve and modified steering pump speed sensitive valve.
#12 KT
KT
  • 303 posts
Posted 24 June 2014 - 10:46 PM
The owner's manual says that the preload is set from the factory, but mine was loose as well. I just put enough preload in to keep the spring from moving around in the perches.
1988 Conquest - Blue - 14.4s 1/4mi
1999 LS7 C5 540HP/520TQ
2002 F-250 7.3L PSD CC 4X4 240HP/475TQ
2012 VW Jetta TDI
#13 Maxzillian
Maxzillian
    Car Shaman
  • 2,650 posts
Posted 25 June 2014 - 08:55 PM
I got one of the first kits and the instructions said to just snug the springs.... I'm convinced that adding preload makes the car ride and handle better. What's better is that you can adjust the attitude of the car by chaning how much preload the front and rear has in relation to each other.
#14 freebird
freebird
  • 2,847 posts
  • Interests:time is of no moment, but only what your doing
Posted 24 October 2014 - 12:48 PM
This would help if it was Saved in the rims&suspension section.
These measurements can help someone, But when the search function dont work members cant find it!
My preload was not set either.
Also my front tops had to be switched left to right.
I dont have pics of my measurments....but it's not like it would help if this thread keeps getting pushed to 30 pages back in the BS section.....just saying....lol ;)
Any one else take the time to measure in these area's?
#15 importwarrior
  • 17,703 posts
Posted 24 October 2014 - 01:21 PM
i can now fix this issue and will...
#16 freebird
freebird
  • 2,847 posts
Posted 24 October 2014 - 02:27 PM
WoW...that was fast!
Thanks man I have a couple projects with d2's going on right now and will post measurement results ASAP!
#17 importwarrior
  • 17,703 posts
Posted 24 October 2014 - 05:45 PM
Great thanks!!!
#18 tankbob
tankbob
  • 1,101 posts
Posted 25 October 2014 - 05:15 AM
Ive got no/super little fender gap without it looking stanced out, 16x9s all around and a little camber in the front.
Fronts are at 2.75in and rears 2.5 measured using the tan line. Ill get pics up tomoro
#19 importwarrior
  • 17,703 posts
Posted 25 October 2014 - 09:25 AM
Thanks!!!
#20 tankbob
tankbob
  • 1,101 posts
Posted 26 October 2014 - 06:56 PM
Here are the pics, also if you are measuring coilovers the proper way to measure them is using the tan line. Ignore the ugly hdr, it shows the tires better.
Also tagged with one or more of these keywords: I-W, D2
