D2 Front Coilover Prep COMPLETE tutorial
68 replies to this topic
#41 Fuze
Fuze
    AKA @Battlemagnet
  • 2,751 posts
  • Interests:Chess Boxing
Posted 10 May 2013 - 12:59 PM
View Posttg118, on 15 April 2013 - 02:27 PM, said:
Big thanks to Fuze for this write-up, made it so much easier to know what to expect!!!
Yeah I get a little stressed before I do anything big on the car, I try to run through it in my head a million times if I haven't done it before. This was tricky enough to make a tutorial for, I'm glad it lowered the stress level of some of you guys.
Insta = @battlemagnet
#42 RonnieJ
RonnieJ
    Gchat ronni3jay@gmail.com
  • 1,858 posts
Posted 10 May 2013 - 01:24 PM
+1 on the thanks!
#43 Coke
Coke
    Member Since January 2003
  • 5,584 posts
Posted 08 June 2013 - 01:31 PM
Going to be doing my fronts this afternoon.  My friend who welds, just left his house to come here to help out.  Wish me luck!
#44 Coke
Coke
  • 5,584 posts
Posted 08 June 2013 - 01:34 PM
Also, when you guys did your rears, did you have to switch your lefts with rights, and rights with lefts?  My right is installed on the left, and my left is installed on my right.  It was the only way they would fit with the brake line brackets oriented in the correct position.  Was wondering if anyone else had this situation.
#45 NikoFab
NikoFab
    Go Blue Fan
  • 9,905 posts
Posted 08 June 2013 - 05:06 PM
I wanna see pics when it's done!
#46 383chevelle
383chevelle
  • 298 posts
Posted 08 June 2013 - 08:16 PM
My fronts and rears are both switched. Lefts on right and rights on left.
#47 randy
randy
  • 4,092 posts
Posted 09 June 2013 - 06:34 PM
Why the switch from right to left and left to right mounting tabs wrong or the angle after modding?
#48 Coke
Coke
  • 5,584 posts
Posted 09 June 2013 - 07:24 PM
Yes.
#49 randy
randy
  • 4,092 posts
Posted 09 June 2013 - 09:06 PM
I guess the modding never stops.
#50 383chevelle
383chevelle
  • 298 posts
Posted 09 June 2013 - 10:44 PM
My front camber plates didn't line up right when I put them on the correct side. The camber adjustment was in an odd direction. Switching them right to left was the only way I could get them to adjust in the correct orientation In the back the brake brackets didn't line up right when they were on the correct side.
#51 mstieg
mstieg
  • 6,171 posts
Posted 25 January 2014 - 10:57 PM
Bump for those of us in the recent wave of D2s.  Has the left/right issue been resolved for fronts &/or rears? (per these earlier posts)?
In Progress: breakin & tune
#52 Funky Phil
Funky Phil
    Super Pooper
  • 6,413 posts
Posted 25 January 2014 - 11:07 PM
Everything lined up on my install.
#53 Funky Phil
Funky Phil
    Super Pooper
  • 6,413 posts
Posted 25 January 2014 - 11:10 PM
View PostTsTKl, on 21 March 2012 - 07:43 PM, said:
please elaborate then?
Ground controls are not full coilovers.
Tein and Hotbits
#54 NikoFab
NikoFab
    Go Blue Fan
  • 9,905 posts
Posted 25 January 2014 - 11:38 PM
View PostTexasQuest, on 22 March 2012 - 08:09 AM, said:
K Sport
View PostMotoCam360, on 22 March 2012 - 09:45 PM, said:
K sport is considered by many to be essentially orange colored D2s....  Wasn't there a thread here recently stating that Tein had full coil overs for Starion?
View PostTexasQuest, on 23 March 2012 - 02:16 PM, said:
Wrong. K Sport is a completely different company.
View PostCoke, on 13 January 2013 - 08:49 AM, said:
I also see 'XYZ' brand coil overs on eBay as well.  I guess it comes down to what colors you want your coilovers to be. Hah
Here's the breakdown on D2/KSport.  They are different companies (credit to TexasQuest)...however they are made in the same plant, by the same people, on the same assembly line (credit to MotoCam). It's like comparing a Scion FRS to a Subaru BRZ...same chassis, same motor, same frame, same cockpit.  About all that's different is some trim elements and front and rear body fascia touches.  At any rate, they are wholesaled to the market by the same manufacturer.
The same manufacturer that is imposing a price hike on D2s is also price hiking the KSports.  Both lines are considered to be a mid-range coilover.  Tein would be considered a top line coilover.
XYZ coilovers are considered to be a cheaper coilover due to shaving cost by skimping on some of the production bits and processes (metallurgy rating, welding template, etc.).  In fact, the coilovers that XYZ sells are produced by a subsidiary arm of the same Taiwanese mother company that produces D2s and KSports.  At any rate, I'd advise steering clear of XYZs.  Check any other forum reviews on them and it's not flattering whatsoever.
#55 MTQuest
MTQuest
  • 131 posts
  • Interests:WRC, SCCA, Circuit, 1/4, Motor builds, One off vehicles, Diesel tech, "Customs not bolt on"
Posted 17 April 2014 - 06:51 PM
Great write up! It was an extremely simple conversion, and in a day I was rolling again.
Wanted to add to this thread by saying 309 welding is the best rod to adhere the carbon based spindle housing to the stainless steel insert that D2 has provided. Was told this by a certified welder. The 309 is the absolute best around for a wide variety of carbon based too stainless welding. When it comes stiff suspension, pot holes, safety, and the difficult weld behind the caliper bracket you better use the best of the best. It was only $15 a pound at a local welding supply store.... Just my extra 2 cents.
MTQuest
#56 CarlosFley
CarlosFley
  • 620 posts
  • Interests:-Class Culture-
    Sinatra, Wu-Tang, Keys N Krates
Posted 13 September 2014 - 06:05 PM
Hey guys, so I'm doing the fronts today. My question now is, do I have to take the entire wheel hub apart? And if so, there's a cotter pin which it says on the FSM is non reusable. Is it really? If so, where do I acquire such a pin? Or does the wheel hub even need to be taken apart? I would love to know it doesn't have to be cuz that'll save me a lot of time. Please help and comment. Thanks.
'87 Chrysler Conquest TSI NON-SHP "Diamond"-Walbro 255, rebuilt TB, OVC hardpipe with HKS SSQV, GM 3" MAF, 1G DSM MAF Translator, 88-89 knock box, black silicone vacuum lines, ABS & Cruise Control delete, 3" HKS Super Power Flow, wire tucked... kinda :/, NRG adjustable shift knob, MSD Blaster 2, tucking tire in the rear and zero wheel gap in fronts on D2's, aaaaaaaannddddd stickaaaaaassssss for that booooooooost!
Interested in: CF 83 style hood, CF air daayyuum. Ohh and turbo-to-intercooler hardpipe.
#57 TexasQuest
  • 8,682 posts
Posted 13 September 2014 - 09:38 PM
Yes it needs to be taken down apart all the way. You can match up the cotter pin size at most auto parts stores.
88 Fiji Blue -Tsi
#58 Fuze
Fuze
    AKA @Battlemagnet
  • 2,751 posts
Posted 16 September 2014 - 07:41 AM
It's only one big nut to take the hub off, not a big deal. A cotter pin is a cotter pin, they just don't like to be bent multiple times as they tend to break. Every auto parts store has them.
#59 CarlosFley
CarlosFley
  • 620 posts
Posted 16 September 2014 - 09:45 AM
Yeah I already finished it Fuze. Took the hub apart, thought it was more work than it really was :/ She's nice and low now :D
#60 RonnieJ
RonnieJ
  • 1,858 posts
Posted 16 September 2014 - 11:31 AM
Oops wrong thread sorry
Edited by RonnieJ, 16 September 2014 - 11:33 AM.
