LS OR 4.6L FORD
22 replies to this topic
#1 86technicaflatty
86technicaflatty
  • 14 posts
Posted 12 August 2017 - 11:11 PM
Ok guys I'm digging my quest out of the weeds and start my swap. But I can decide whether it's best to go with a 350 with t56. Or a 4.6l out of a cop car that has been sitting at my shop. Personally id like to go LS but i have the 4.6l already. Also if I could just get some advice on what needs trimming and what y'all did for motor mounts trans cross members etc... I'll try and get some pictures of my car up it's saying the files are too big
#2 creakyjoints
creakyjoints
  • 1,916 posts
Posted 12 August 2017 - 11:45 PM
4.6 is to wide
#3 87redcat
87redcat
    10 years and counting...
  • 3,683 posts
Posted 13 August 2017 - 03:05 AM
And it blows spark plugs...
#4 86technicaflatty
86technicaflatty
  • 14 posts
Posted 13 August 2017 - 09:46 AM
What about motor mounts for LS?
#5 Preludedude
Preludedude
  • 2,558 posts
Posted 13 August 2017 - 02:40 PM
Everything has to be custom...
#6 TexasQuest
  • 8,614 posts
Posted 13 August 2017 - 05:57 PM
You have to custom make motor mounts and cut the trans tunnel to fit a trans. Also make mounts for it too.
88 Fiji Blue -Tsi
#7 EricSQ
EricSQ
  • 358 posts
Posted 14 August 2017 - 01:00 PM
Don't waste your time with the 4.6L out of a P71 because they really are weak compared to any LS.  If you're going SBC with a T56 you will need to cut the tunnel up to get the trans to fit.  You will also be custom fabricating all your brackets, but you would do that for any conversion.
If you can't do the LS, you should do the SBC over the 4.6L IMO.
1988 Chrysler Conquest Tsi (sold)____1994 Mitsubishi 3000GT SL (sold)
1987 Mitsubishi Starion (sold)_______ 1986 Mitsubishi Starion LS Swap (sold)
2015 Subaru WRX (sold)___________ 2002 Chevy Silverado Z71 (For Sale)
1991 Toyota MR2 Turbo (project)____  2000 Chevy Silverado Shortwide (DD)
#8 86technicaflatty
86technicaflatty
  • 14 posts
Posted 15 August 2017 - 07:44 PM
Yah I know I have to fabricate my own mounts. Which is fine I have the skills and tools to do it just wanted to see what everyone else was doing for them. I have a lead on a chevy 350 and turbo 400 trans.
#9 440Quest
440Quest
  • 111 posts
Posted 20 August 2017 - 09:56 PM
LS is by far the most logical. Financially and aftermarket support.
#10 Bradrock
Bradrock
  • 832 posts
Posted 20 August 2017 - 10:08 PM
What's the best poor boy LS candidate?  Seems like the TV hot rod show folks go for truck engines? I'm a blue oval guy, so don't know squat about GM products.
What I REALLY want to use in my roller quest is a Caddy Northstar. Northstarion!
It sure hauls my 99 Deville down the road with gusto! And it's aluminum.
Lots of induction options. You can even get a four barrel intake now & loose a ton of electronics.
http://www.chrfab.com/
https://www.youtube....h?v=MvrFe39xho4
Edited by Bradrock, 20 August 2017 - 10:20 PM.
Run's with scizzor's
#11 mbruneaux
mbruneaux
  • 1,391 posts
Posted 21 August 2017 - 09:23 AM
That would definitely be different  and pretty cool.
Canterbury, CT
1998 BMW 528i 5 Speed because the Suburban gets 10 MPG
#12 EricSQ
EricSQ
  • 358 posts
Posted 22 August 2017 - 08:32 AM
I'm not too familiar with Northstar engines, but I thought they were mostly mounted transverse style for FWD.  Are there any mounted front-to-back and have a transmission for RWD?
#13 86technicaflatty
86technicaflatty
  • 14 posts
Posted 22 August 2017 - 10:13 AM
I think the bell housing for the lt1 is the same as the northstar but that motor is a pain in the tail to maintain. You know where the starter is right? It's under the intake plenum. And the upper oil pan leaks like a sive. If you do that swap I suggest replacing every gasket. And the starter haha.
#14 86technicaflatty
86technicaflatty
  • 14 posts
Posted 22 August 2017 - 10:18 AM
And I'm going with a 5.7L 350 and turbo 400 trans out of a buick road master.
#15 Turbo Cary
Turbo Cary
  • 1,493 posts
Posted 23 August 2017 - 06:11 PM
DONT USE A NORTHSTAR! take it from me. I am a GM Technician. Those thing suck. There are RWD configurations in some Cadillac models but they are hard to come by. Not to mention dumb setups like having the starter under the intake manifold, special tool needed for the water pump, oil leaks everywhere. I don't even recommend fixing leaks on those engines when they come in. If it isn't pouring out oil it and it's just a shiny oil coating, then it doesn't need repair lol.
If going LS and using a truck engine, find one that DOES NOT have active fuel management. That can be determined by looking for a VLOM (valve lifter oil manifold) which is the plate in the valley. If it is active fuel management there will be a 12 pin connector going to the valley and if you remove the plate under the intake you will see the solenoid as part of it.
Non VLOM motors just have a plate with no connector and only one connector present is for the oil pressure sensor.
The AFM motors tend to have camshaft failures as well as lifters failing. To convert a AFM motor to a non AFM configuration you'll need to change the camshaft, lifters, ECU and valley plate. Not a hard job, calls for 14 hours on a truck to replace lifters on both sides but can be done in 5 if you're quick.
Edited by Turbo Cary, 24 August 2017 - 06:46 AM.
#16 TexasQuest
  • 8,614 posts
Posted 24 August 2017 - 12:16 AM
Cheapest route would be 99-02 4.8/5.3/6.0 out of a GM truck/van/suv. They were cable driven throttle.
88 Fiji Blue -Tsi
#17 86technicaflatty
86technicaflatty
  • 14 posts
Posted 24 August 2017 - 08:23 AM
How much power can the factory LSD hand and what about half shafts?
#18 TexasQuest
  • 8,614 posts
Posted 25 August 2017 - 12:14 AM
Joe (4cylfury) is making well over 400hp with the factory diff and upgraded axles.
88 Fiji Blue -Tsi
#19 Starionslider
Starionslider
  • 297 posts
Posted 26 August 2017 - 11:29 PM
Mines at or above 613hp/703ft lbs. still holding on. And when i say i beat my car hard thats a understatement.
#20 stariondreams
stariondreams
  • 420 posts
Posted 31 August 2017 - 06:12 PM
Starionslider you a hard guy to catch. Been trying to catch up to talk swap for awhile I am also in ct.
