Brakes not working
7 replies to this topic
#1 StarquestRescue
StarquestRescue
  • 4,626 posts
Posted 22 July 2017 - 12:56 PM
Car sat 7 years. At first pedal was hard as a rock very little whoa. Changed calipers from a car that was wreaked a year ago. Now has normal peddle feel but no more whoa. Thought maybe the rotors were just to rusty, so installed front rotors and matching pads from the doner car.
No improvement in stopping power.
  If I coast down a hill, shut the motor off and pump the brake to bleed off the vacuum to the brake booster. And then restart the car the brake pedal feels like the booster kicks in but no change in stopping power.
The ebrake works better then the service brakes!  After a short drive and using the ebrake some. Rear rotor temps were 220, front 160.
What next?
Edited by StarquestRescue, 22 July 2017 - 12:57 PM.
#2 ucw458
ucw458
  • 11,373 posts
Posted 22 July 2017 - 01:26 PM
Master cyl, it's the one part that has failed on every SQ I've owned.  There's also a rear brake bias valve below the booster that has clogged on a few members cars causing brake issues.
My 87
#3 StarquestRescue
StarquestRescue
  • 4,626 posts
Posted 22 July 2017 - 01:35 PM
But it pushes the pistons out just fine if I have then pushed in and the caliper's bleed ok, so it is moving fluid?
#4 87redcat
87redcat
    10 years and counting...
  • 3,570 posts
Posted 22 July 2017 - 02:08 PM
Rear brake valve like ucw said or still air in a line somewhere or master getting ready to let go. My brakes were fine one day, then went to the floor the next. No amount of pumping the pedal helped. Master was leaking into the booster
#5 tsi_tom
tsi_tom
  • 2,118 posts
Posted 22 July 2017 - 02:53 PM
I think I have this problem too.  It seems like I have to press the pedal too hard to stop.
Engine
20 over forged pistons
Stock injection system
#6 ucw458
ucw458
  • 11,373 posts
Posted 22 July 2017 - 02:58 PM
With any damaged pump you can have it flow but never build pressure.  With the bleeders open there's no resistance so you get flow.  But with the bleeders closed the resistance can cause the fluid to flow past leaky pistons back into the resivour.  Or leak out the back into the booster.
My 87
#7 87redcat
87redcat
  • 3,570 posts
Posted 23 July 2017 - 08:52 PM
BINGO!!!
#8 StarquestRescue
StarquestRescue
  • 4,626 posts
Posted 23 July 2017 - 09:50 PM
I am thinking purporting valve or abs modulator. If the master cylinder was leaking the pedal would drift towards the floor. It does not.
