Lizzord30 Posted June 6, 2012 Report Share Posted June 6, 2012 Anyone know the proper shift linkage adjustment procedure? The service manual isnt very good and seams if i get Park to work well then drive 2nd and L doesnt work correctly. I got my bushings pretty good so I dont think that is it. Link to comment Share on other sites More sharing options...
Alan Posted June 7, 2012 Report Share Posted June 7, 2012 Check this lever. This was taken in neutral. It's almost dead center in the slide.http://i970.photobucket.com/albums/ae184/owenbyj/XMSN%20rebuild%20Jan%202010/100_1901.jpg Link to comment Share on other sites More sharing options...
Metric-man Posted June 8, 2012 Report Share Posted June 8, 2012 (edited) Check this lever. This was taken in neutral. It's almost dead center in the slide.This thread is in the Automatic transmission forum. Anyone know the proper shift linkage adjustment procedure? The service manual isnt very good and seams if i get Park to work well then drive 2nd and L doesnt work correctly. I got my bushings pretty good so I dont think that is it. It might be the neutral safety switch itself.Do you have all the linkage bushings still? Edited June 8, 2012 by Metric-man Link to comment Share on other sites More sharing options...
Alan Posted June 8, 2012 Report Share Posted June 8, 2012 (edited) That pic is of my auto 89. The inhibitor switch will effect starting. If that lever is all the way over to one end, you will not get full travel at the park reverse side or the 1st/2nd side. Edited June 8, 2012 by Alan Link to comment Share on other sites More sharing options...
Metric-man Posted June 9, 2012 Report Share Posted June 9, 2012 Aligning the safety switch is what mandates the linkage position.If the park or neutral position is off so will the drive speed and reverse selection. Link to comment Share on other sites More sharing options...
Alan Posted June 9, 2012 Report Share Posted June 9, 2012 No, whole different deal and procedure. Put the transmission selector shaft in park or netural, it will work either way. With the mounting bolts backed out rotate the switch unit the alignment pin engages then tighten bolts. All in the FSM. Does not move the shifter linkage, just the switch body on the transmission shaft input. If done correctly will not crank in gear unless the linkage is not correct. Link to comment Share on other sites More sharing options...
89PalermoSHP Posted August 28, 2012 Report Share Posted August 28, 2012 I found that I needed to adjust it a couple times. I dont think there is one "correct" way to do it. Link to comment Share on other sites More sharing options...
