Guest Paul87Quest Posted November 15, 2002 Report Share Posted November 15, 2002 I was looking at Alldata website, and there are quite a few important technical service bulletins (TSB's) that apply to our cars. Something unique I discovered also is that they are not identical between Chrysler and Mitsu...some are only on one make which completely baffles me. So make sure to check both makes for your year car as both apply, and you may miss something if not. I have access to Alldata at my local library, and plan on copying the ones that are important. I could then scan them, or type them up and post them for part of a database. As time allows, I will boldface certain titles, and that will mean their entire content (or a good summary) will be included below. NOTE: TSB's are service bulletins issued by the manufacturer to dealer service staff that alert them about fixes for hard to diagnose problems, or procedures to follow in diagnostics. EDIT added by the Moderators of this site: Below are the Technical Service Bulletins that apply to our cars. Â These can be searched through the site search engine or you can hit Ctrl-F to search this thread. Â Many thanks to Paul for putting this list together. Link to comment Share on other sites More sharing options...
Guest Paul87Quest Posted November 23, 2002 Report Share Posted November 23, 2002 Bulletins for 1989 Chrysler Conquest TSI L4-2555cc 2.6L SOHC Turbo VIN N FI Emissions Recalls TSB Number  Issue Date  TSB Title 524       JUL 92    Recall - CO Emissions (Catalytic Converter) 523       MAY 92    Recall - CO Emissions General Recalls TSB Number  Issue Date  TSB Title 455         OCT 89    Campaign - Engine Connecting Rod Bearings Service Bulletins TSB Number  Issue Date  TSB Title 23-008-00B      NOV 00    Child Seat - Tether Anchor Part Numbers & Labor Time 23-35-99A      OCT 99    Child Seat Tether Anchor - Labor/Parts Identification 08-36-98       JUL 98    Auto Computers - Y2K Effects 23-03-97       FEB 97    Black Plastic Body Components - Chalky Residue 241796        NOV 96    R-12 to R-134A A/C Adaptation Procedure ATRATB294     JAN 95    A/T - Drive Axle and Wheel Lug Nut Torque Specifications 241192        AUG 92    A/C Refrigerant - Substitutes and Compatibility ATRATB078     NOV 91    A/T - How To Use A Pressure Gauge 080991        JUL 91    Air Bags - Scheduled Inspection/Maintenance 080791        MAY 91    Wiring - Repair Instruction Sheets 070390        DEC 90    Engine Coolant - Recycling Recommendations 212390        DEC 90    M/T - High Shift Effort During Cold Weather ATRATB028     OCT 90    A/T - Engine Vacuum Testing MEMO082790   AUG 90    Service Bulletin Format Has Been Revised MEMO82790    AUG 90    Service Bulletin Format Revised 211090       MAR 90    KM132 M/T - 5TH Gear Revision 250190       MAR 90    Secondary Air Supply System - Manual Revision 181190       MAR 90    Flooded Engine - Service Precautions 210890       MAR 90    M/T Shift Lever - Buzzes During Acceleration ATRATB9002006FEB 90    A/T - Choosing the Right ATF 262489       OCT 89    Vehicle Identification Number - Decoder 091289       OCT 89    Timing Chain Silent Shaft Chain - Guide Bolt Revisions ATRATB8930   OCT 89    A/T - Math Part II ATRATB8927    SEP 89    A/T - Twenty Steps To Successful Repairs ATRATB8923   AUG 89    A/T - Math Formulas Part I 020389       JUL 89    Lower Control Arm Bushings - Update 030289       MAY 89    Rear Axle - Click/Snap/Clunk Noises on Acceleration 100189       APR 89    Engine Oil - New `SG' Level Oil 090789       APR 89    Oil Pump Screen - Manual Revision 230889       APR 89    Paint - Codes/Applications/Cross References 230389       FEB 89    Upholstery - Cleaning Procedure 240189       JAN 89    A/C Compressor - Revised Parts 081088       DEC 88    Battery - Checking Procedure Revision 260988       NOV 88    Technical Service Bulletins - Body Code Usage 181788       OCT 88    Spark Plugs - Oil Fouling/Misfire on Hard Acceleration ATRATB8754   SEP 87    A/T - Front Bushing Wear ATRATB8748   AUG 87    A/T - Slipping or No-Shift/Metal Sealing Rings Link to comment Share on other sites More sharing options...
Guest Paul87Quest Posted November 23, 2002 Report Share Posted November 23, 2002 Bulletins for 1989 Mitsubishi Starion L4-2555cc 2.6L SOHC Turbo Safety Recalls TSB Number  Issue Date  TSB Title SR-95-002    OCT 95    Recall - Front Seat Belt Buckle Emissions Recalls TSB Number  Issue Date  TSB Title EMR92010    MAY 92    Recall - Catalytic Converter Replacement EMR92001R    JAN 92    Recall - Catalytic Converter Inspection/Replacement General Recalls TSB Number  Issue Date  TSB Title SC89001     NOV 89    Campaign - New Connecting Rod Bearing Service Bulletins TSB Number  Issue Date  TSB Title 01-11-002    MAY 01    Engine - Block Heater Update 01-54-006    MAY 01    Speedometer/Odometer - Replacement/Mileage Setting 99-23-011    OCT 99    A/T Oil Cooler - Backflush Alternative 99-11-006    JUN 99    Engine - Valve Lash Adjuster Cleaning Procedure 98-42A-008   OCT 98    Remote Keyless Entry - Update 98-00-00A    SEP 98    Fluids, Refrigerants and Materials (Genuine Mitsubishi) 99-00-001    JUN 98    VIN - Decoding Information 98-23-004    APR 98    A/T - Perform Cooler Flow Test When Replacing A/T 98-54-001    FEB 98    Audio System - Diagnosis 97-35-004    SEP 97    Brakes - Judder (vibration) Diagnosis and Repair 97-42A-012   SEP 97    Interior - Buzz, Squeak, and Rattle Kit 97-42A-001   FEB 97    Interior - Wind Noise Diagnosis 97-11-002    FEB 97    Valve Lash Adjuster Noise - Troubleshooting Procedures 96-35-009    SEP 96    Antilock Brake System - Diagnosis 96-11-009    SEP 96    Piston Pin - Installation Tool Instructions 96-11-005    JUL 96    Engine - Oil Economy Test 96-55-006    MAY 96    A/C Refrigerant - Service Information 95-16-003    NOV 95    Spark Plug - Fouling 95-54-001    OCT 95    Rear Window Defogger Grid - Repair ATRATB294    JAN 95    A/T - Drive Axle and Wheel Lug Nut Torque Specifications 9455001     JUN 94    A/C - System Leak Checking 9355006     DEC 93    A/C - Refrigerant Temperature Switch Manual Correction 9313004     AUG 93    ECM - Adaptive Memory 9355001     JUN 93    A/C - Odor Correction 9322001     APR 93    M/T - Fluid Recommendation/Caution 9321001     APR 93    M/T - Flywheel Surfacing Limit 9235008     DEC 92    Brakes - Rotor Service Procedures 9200010     DEC 92    VIN - Replacement Plate/Label 9213010     NOV 92    Chemicals - Fuel Injector Cleaner Feels 1/2 Full 9200009     NOV 92    Tools - MSN Multi-Use Tester ROM Pack Update 9231001     NOV 92    Wheels - Lug Nut Torque Information and Chart 9200003     AUG 92    Engine Controls - Never Use a Test Light To Check an ECM 9200005     AUG 92    VIN - Master Decoder Information 9251001     MAY 92    Paint - Damage Identification and Repair 9235003     MAR 92    Brakes - Pad Installation Service Points 9200001     JAN 92    Tools - Fault Codes When Using the Multi-Use Tester ATRATB078    NOV 91    A/T - How To Use A Pressure Gauge 91-00-015    OCT 91    Tools - Multi-Use Tester Warranty ATRATB062B   JUL 91    A/T - E4N71B, 4N71B & JM600 Overdrive Check Balls 9111010      JUL 91    Engine - Piston Pin Installation Tool 91-00-011     JUL 91    Tools - Multi-Use Tester ROM Pack Usage ATRATBB055   JUN 91    A/T - E4N71B/JM600 Overdrive Sprag Rotation 9111009      MAY 91    Engine - Automatic Valve Lash Adjuster Noise 9117002      MAR 91    Emissions - Correct Diagnosis of Emission Control Parts 9100004      MAR 91    Tools -  Multi-Use Tester ROM Pack Usage 9155003      FEB 91    A/C - Refrigeration Oil Specification 9117001      FEB 91    Emissions - Updated Secondary Air System Inspection ATRATB028    OCT 90    A/T - Engine Vacuum Testing 9023011      OCT 90    A/T - Overdrive Shift Switch Removal 9016001      OCT 90    Battery - Care During Long Term Storage 9011007      OCT 90    Tools - Piston Pin Tool Operating Instructions 9054011      OCT 90    Windows - Repair of Rear Defogger Grid 9000001      SEP 90    VIN - Codes 9054003      MAR 90    Audio - Speaker Troubleshooting Manual Supplement 9027002      MAR 90    Drivetrain - Click, Snap or Clunking Noise From Rear 9011002      MAR 90    Timing Chain & Tensioner Spring - Parts Available 9055001      FEB 90    A/C - Handling Precautions For Freon R-12 ATRATB9002006 FEB 90    A/T - Choosing the Right ATF 9042B001     JAN 90    Windshield - Installation Instructions ATRATB8930   OCT 89    A/T - Math Part II 8911004      OCT 89    Silent Shaft Chain Tensioner Bolt - Torque Update ATRATB8927   SEP 89    A/T - Twenty Steps To Successful Repairs ATRATB8923   AUG 89    A/T - Math Formulas Part I 8911001      JUN 89    Engine Oil Screen - Illustration Revision 8900002      JUN 89    Multi Use Tester - Warranty 8923006      MAR 89    Paint - Exterior Color Codes and Applications 8921001      JAN 89    A/T - Recommended Fluid 8908001      JAN 89    Fuel Gauge - Simple Test Procedures, Revision 88-24-004     OCT 88    A/C - Odors 88-00-005     OCT 88    Tool - Multi-Use Tester Application Chart 88-21-024     OCT 88    Transmission - Identification Codes ATRATB8754   SEP 87    A/T - Front Bushing Wear ATRATB8748   AUG 87    A/T - Slipping or No-Shift/Metal Sealing Rings Link to comment Share on other sites More sharing options...
Guest Paul87Quest Posted November 23, 2002 Report Share Posted November 23, 2002 Bulletins for 1988 Chrysler Conquest TSI L4-2555cc 2.6L Turbo VIN N FI Emissions Recalls TSB Number  Issue Date  TSB Title 524       JUL 92    Recall - CO Emissions (Catalytic Converter) 523       MAY 92    Recall - CO Emissions General Recalls TSB Number  Issue Date  TSB Title 455       OCT 89    Campaign - Engine Connecting Rod Bearings Service Bulletins TSB Number  Issue Date  TSB Title 241796        NOV 96    R-12 to R-134A A/C Adaptation Procedure ATRATB294      JAN 95    A/T - Drive Axle and Wheel Lug Nut Torque Specifications 241192        AUG 92    A/C Refrigerant - Substitutes and Compatibility ATRATB078     NOV 91    A/T - How To Use A Pressure Gauge 080991        JUL 91    Air Bags - Scheduled Inspection/Maintenance 080791        MAY 91    Wiring - Repair Instruction Sheets 070390        DEC 90    Engine Coolant - Recycling Recommendations ATRATB028      OCT 90    A/T - Engine Vacuum Testing MEMO082790    AUG 90    Service Bulletin Format Has Been Revised MEMO82790     AUG 90    Service Bulletin Format Revised 211890         AUG 90    Overdrive Switch - Removal Procedure 211090        MAR 90    KM132 M/T - 5TH Gear Revision 250190        MAR 90    Secondary Air Supply System - Manual Revision 181190        MAR 90    Flooded Engine - Service Precautions 210890        MAR 90    M/T Shift Lever - Buzzes During Acceleration ATRATB9002006  FEB 90    A/T - Choosing the Right ATF ATRATB8930     OCT 89    A/T - Math Part II ATRATB8927     SEP 89    A/T - Twenty Steps To Successful Repairs ATRATB8923     AUG 89    A/T - Math Formulas Part I 030289         MAY 89    Rear Axle - Click/Snap/Clunk Noises on Acceleration 100189         APR 89    Engine Oil - New `SG' Level Oil 090789         APR 89    Oil Pump Screen - Manual Revision 080989         APR 89    Spark Plug Usage - Service Manual Revision 050189         FEB 89    Master Cylinder - Check Valve Elimination 230389         FEB 89    Upholstery - Cleaning Procedure 240189         JAN 89    A/C Compressor - Revised Parts 261088         DEC 88    Adhesives & Sealants - Applications and Instructions 240388         DEC 88    A/C - Performance Test, Procedure Revision 081088         DEC 88    Battery - Checking Procedure Revision 181788         OCT 88    Spark Plugs - Oil Fouling/Misfire on Hard Acceleration 260488         SEP 88    Trouble Shooting - Service Manual Revisions 080388         MAY 88    Temperature Sending Unit - Improvements 210588         APR 88    A/T - Valve Body/Check Valve Specification Revision 230588         APR 88    Rear Shoulder Belt - Installation 180688         FEB 88    Engine - Prohibited Starting Practice 230388         FEB 88    Paint - Codes/Cross References/Applications 080188         JAN 88    Radio/Electronic Component - Repair & Exchange Depots 140188         JAN 88    Fuel Injection System - Manual Revisions 220187         DEC 87    Wheels/Tires - Vibration & Road Shake At 45-65 Mph 260887         DEC 87    Vehicle & Component Identification 181987         NOV 87    Driveability Manual - Revisions 260587         NOV 87    Service Bulletin - Body Code Usage ATRATB8754     SEP 87    A/T - Front Bushing Wear ATRATB8748     AUG 87    A/T - Slipping or No-Shift/Metal Sealing Rings Link to comment Share on other sites More sharing options...
Guest Paul87Quest Posted November 23, 2002 Report Share Posted November 23, 2002 Bulletins for 1988 Mitsubishi Starion L4-2555cc 2.6L SOHC Turbo Safety Recalls TSB Number    Issue Date  TSB Title SR-95-002     OCT 95    Recall - Front Seat Belt Buckle Emissions Recalls TSB Number  Issue Date  TSB Title EMR92010     MAY 92    Recall - Catalytic Converter Replacement EMR92001R    JAN 92    Recall - Catalytic Converter Inspection/Replacement General Recalls TSB Number  Issue Date   TSB Title SC89001      NOV 89    Campaign - New Connecting Rod Bearing Service Bulletins TSB Number  Issue Date  TSB Title 99-23-011     OCT 99    A/T Oil Cooler - Backflush Alternative 99-31-004     OCT 99    Wheel - Balancing Accuracy Tips 99-11-006     JUN 99    Engine - Valve Lash Adjuster Cleaning Procedure 99-00-002     FEB 99    Sealant/Adhesive/Chemical - Interchange Information 98-42A-008    OCT 98    Remote Keyless Entry - Update 98-00-00A     SEP 98    Fluids, Refrigerants and Materials (Genuine Mitsubishi) 99-00-001     JUN 98    VIN - Decoding Information 98-23-004     APR 98    A/T - Perform Cooler Flow Test When Replacing A/T 98-54-001     FEB 98    Audio System - Diagnosis 97-35-004     SEP 97    Brakes - Judder (vibration) Diagnosis and Repair 97-42A-012    SEP 97    Interior - Buzz, Squeak, and Rattle Kit 97-11-003     MAY 97    Engine, Valves - Valve Adjuster Noise Diagnosis 97-42A-001    FEB 97    Interior - Wind Noise Diagnosis 96-35-009     SEP 96    Antilock Brake System - Diagnosis 96-11-009     SEP 96    Piston Pin - Installation Tool Instructions 96-11-005     JUL 96    Engine - Oil Economy Test 96-42A-015    JUL 96    Synthetic Resin Parts - Heat Resistance Specifications 96-55-006     MAY 96    A/C Refrigerant - Service Information 96-42A-007    MAR 96    Window - Chemical Film Build-Up/Fogging 95-16-003     NOV 95    Spark Plug - Fouling 95-54-001     OCT 95    Rear Window Defogger Grid - Repair ATRATB294    JAN 95    A/T - Drive Axle and Wheel Lug Nut Torque Specifications 9455001      JUN 94    A/C - System Leak Checking 9355006      DEC 93    A/C - Refrigerant Temperature Switch Manual Correction 9355001      JUN 93    A/C - Odor Correction 9322001      APR 93    M/T - Fluid Recommendation/Caution 9321001      APR 93    M/T - Flywheel Surfacing Limit 9317001      FEB 93    Emission - Control Information Label Ordering 9235008      DEC 92    Brakes - Rotor Service Procedures 9200010      DEC 92    VIN - Replacement Plate/Label 9213010      NOV 92    Chemicals - Fuel Injector Cleaner Feels 1/2 Full 9200009      NOV 92    Tools - MSN Multi-Use Tester ROM Pack Update 9231001      NOV 92    Wheels - Lug Nut Torque Information and Chart 9200003      AUG 92    Engine Controls - Never Use a Test Light To Check an ECM 9200005      AUG 92    VIN - Master Decoder Information 9251001      MAY 92    Paint - Damage Identification and Repair 9235003      MAR 92    Brakes - Pad Installation Service Points Link to comment Share on other sites More sharing options...
Guest Paul87Quest Posted November 23, 2002 Report Share Posted November 23, 2002 Bulletins for 1988 Mitsubishi Starion L4-2555cc 2.6L SOHC Turbo (CONT.) 9200001 JAN 92 Tools - Fault Codes When Using the Multi-Use Tester ATRATB078 NOV 91 A/T - How To Use A Pressure Gauge 91-00-015 OCT 91 Tools - Multi-Use Tester Warranty ATRATB062B JUL 91 A/T - E4N71B, 4N71B & JM600 Overdrive Check Balls 9111010 JUL 91 Engine - Piston Pin Installation Tool 91-00-011 JUL 91 Tools - Multi-Use Tester ROM Pack Usage ATRATBB055 JUN 91 A/T - E4N71B/JM600 Overdrive Sprag Rotation 9111009 MAY 91 Engine - Automatic Valve Lash Adjuster Noise 9117002 MAR 91 Emissions - Correct Diagnosis of Emission Control Parts 9100004 MAR 91 Tools - Multi-Use Tester ROM Pack Usage 9155003 FEB 91 A/C - Refrigeration Oil Specification 9117001 FEB 91 Emissions - Updated Secondary Air System Inspection ATRATB028 OCT 90 A/T - Engine Vacuum Testing 9023011 OCT 90 A/T - Overdrive Shift Switch Removal 9016001 OCT 90 Battery - Care During Long Term Storage 9011007 OCT 90 Tools - Piston Pin Tool Operating Instructions 9054011 OCT 90 Windows - Repair of Rear Defogger Grid 9000001 SEP 90 VIN - Codes 9054003 MAR 90 Audio - Speaker Troubleshooting Manual Supplement 9027002 MAR 90 Drivetrain - Click, Snap or Clunking Noise From Rear 9011002 MAR 90 Timing Chain & Tensioner Spring - Parts Available 9055001 FEB 90 A/C - Handling Precautions For Freon R-12 ATRATB9002006 FEB 90 A/T - Choosing the Right ATF 9042B001 JAN 90 Windshield - Installation Instructions 8952002 NOV 89 Seat Belt - Rear Shoulder Belt Installation ATRATB8930 OCT 89 A/T - Math Part II 8911004 OCT 89 Silent Shaft Chain Tensioner Bolt - Torque Update ATRATB8927 SEP 89 A/T - Twenty Steps To Successful Repairs ATRATB8923 AUG 89 A/T - Math Formulas Part I 8911001 JUN 89 Engine Oil Screen - Illustration Revision 8900002 JUN 89 Multi Use Tester - Warranty 8900001 JUN 89 New Service Bulletin Group Numbers 8916002 JUN 89 Spark Plug Specification - Service Manual Revision 8921001 JAN 89 A/T - Recommended Fluid 8908001 JAN 89 Fuel Gauge - Simple Test Procedures, Revision 88-24-004 OCT 88 A/C - Odors 88-24-003 OCT 88 A/C - Performance Tests Revision 88-05-007 OCT 88 Brakes - Master Cylinder Update 88-23-019 OCT 88 Door Front/Rear - Production Changes 88-00-005 OCT 88 Tool - Multi-Use Tester Application Chart 88-21-024 OCT 88 Transmission - Identification Codes 8814009 JUL 88 ECI-Multi Driveability Troubleshooting - Manual Update 8814010 JUL 88 Turbo - Driveability Troubleshooting Manual Update 8807002 MAY 88 Engine Coolant - Mixture Information 8821005 APR 88 A/T - Valve Body Corrections 8808006 APR 88 Battery - Test Procedure 8814007 APR 88 EGR Solenoid Valve - Updated RPM Specification for Check 8821003 MAR 88 M/T - KM132/KM145 Counter Gear Lock Nut Modification ATRATB889 FEB 88 A/T - Identification 8808001 JAN 88 Battery - Service and Care ATRATB8754 SEP 87 A/T - Front Bushing Wear ATRATB8748 AUG 87 A/T - Slipping or No-Shift/Metal Sealing Rings 8723011 AUG 87 Paint - Exterior Color Codes and Applications Link to comment Share on other sites More sharing options...
Guest Paul87Quest Posted November 23, 2002 Report Share Posted November 23, 2002 Bulletins for 1987 Chrysler Conquest TSI L4-2555cc 2.6L Turbo VIN N FI Emissions Recalls TSB Number Issue Date TSB Title 524 JUL 92 Recall - CO Emissions (Catalytic Converter) 523 MAY 92 Recall - CO Emissions Service Bulletins TSB Number Issue Date TSB Title 241796 NOV 96 R-12 to R-134A A/C Adaptation Procedure ATRATB294 JAN 95 A/T - Drive Axle and Wheel Lug Nut Torque Specifications 241192 AUG 92 A/C Refrigerant - Substitutes and Compatibility ATRATB078 NOV 91 A/T - How To Use A Pressure Gauge 080791 MAY 91 Wiring - Repair Instruction Sheets 070390 DEC 90 Engine Coolant - Recycling Recommendations ATRATB028 OCT 90 A/T - Engine Vacuum Testing MEMO082790 AUG 90 Service Bulletin Format Has Been Revised MEMO82790 AUG 90 Service Bulletin Format Revised 211890 AUG 90 Overdrive Switch - Removal Procedure 211090 MAR 90 KM132 M/T - 5TH Gear Revision 250190 MAR 90 Secondary Air Supply System - Manual Revision 181190 MAR 90 Flooded Engine - Service Precautions 210890 MAR 90 M/T Shift Lever - Buzzes During Acceleration ATRATB9002006 FEB 90 A/T - Choosing the Right ATF ATRATB8930 OCT 89 A/T - Math Part II ATRATB8927 SEP 89 A/T - Twenty Steps To Successful Repairs ATRATB8923 AUG 89 A/T - Math Formulas Part I 100189 APR 89 Engine Oil - New `SG' Level Oil 090789 APR 89 Oil Pump Screen - Manual Revision 230389 FEB 89 Upholstery - Cleaning Procedure 081088 DEC 88 Battery - Checking Procedure Revision 181788 OCT 88 Spark Plugs - Oil Fouling/Misfire on Hard Acceleration 260488 SEP 88 Trouble Shooting - Service Manual Revisions 210788 JUL 88 M/T - Countershaft Gear Locknut Modification 080588 MAY 88 A/C - Condenser Fan Motor & Fan Relay Correction 210588 APR 88 A/T - Valve Body/Check Valve Specification Revision 230588 APR 88 Rear Shoulder Belt - Installation 140188 JAN 88 Fuel Injection System - Manual Revisions 220187 DEC 87 Wheels/Tires - Vibration & Road Shake At 45-65 Mph 181987 NOV 87 Driveability Manual - Revisions ATRATB8754 SEP 87 A/T - Front Bushing Wear ATRATB8748 AUG 87 A/T - Slipping or No-Shift/Metal Sealing Rings 231087 JUL 87 Front Seat Belt Lock Function - Test Procedure 230987 JUL 87 Sunroof - Service Procedures 260487 JUL 87 Service Manual - Revisions 081787 JUN 87 Radio & Electronics - Repair/Exchange Depots 210687 APR 87 A/T - Clunk or Squawk Noise Shifting Into Reverse 260287 MAR 87 TSB - Body Model Code Use 080687 FEB 87 Ignition Timing - Procedure Revision 020287 FEB 87 Lower Control Arm to Axle Housing Bolt - Revision 230187 JAN 87 Theft Protection Label - Masking Film Removal 081686 DEC 86 Battery - Discharges If Vehicle Is Stored 231486 DEC 86 Paint - Codes/Applications 260386 DEC 86 Body - Rustproofing Application 185786 NOV 86 Failed Emission Black Smoke Code 52 081186 NOV 86 Radio - Exchange Program 260286 NOV 86 Vehicle & Component Identification 230886 SEP 86 Seat Belt Extender - Types/Identification Link to comment Share on other sites More sharing options...
Guest Paul87Quest Posted November 23, 2002 Report Share Posted November 23, 2002 Bulletins for 1987 Mitsubishi Starion L4-2555cc 2.6L SOHC Turbo VIN N FI Safety Recalls TSB Number  Issue Date   TSB Title SR-95-002     OCT 95    Recall - Front Seat Belt Buckle Emissions Recalls TSB Number  Issue Date   TSB Title EMR92010      MAY 92    Recall - Catalytic Converter Replacement EMR92001R     JAN 92    Recall - Catalytic Converter Inspection/Replacement General Recalls TSB Number  Issue Date    TSB Title SC89001      NOV 89    Campaign - New Connecting Rod Bearing Service Bulletins TSB Number  Issue Date  TSB Title 99-23-011     OCT 99    A/T Oil Cooler - Backflush Alternative 99-31-004     OCT 99    Wheel - Balancing Accuracy Tips 99-11-006     JUN 99    Engine - Valve Lash Adjuster Cleaning Procedure 99-00-002     FEB 99    Sealant/Adhesive/Chemical - Interchange Information 98-42A-008    OCT 98    Remote Keyless Entry - Update 98-00-00A     SEP 98    Fluids, Refrigerants and Materials (Genuine Mitsubishi) 99-00-001     JUN 98    VIN - Decoding Information 98-23-004     APR 98    A/T - Perform Cooler Flow Test When Replacing A/T 98-54-001     FEB 98    Audio System - Diagnosis 97-35-004     SEP 97    Brakes - Judder (vibration) Diagnosis and Repair 97-42A-012    SEP 97    Interior - Buzz, Squeak, and Rattle Kit 97-11-003     MAY 97    Engine, Valves - Valve Adjuster Noise Diagnosis 97-42A-001    FEB 97    Interior - Wind Noise Diagnosis 96-35-009     SEP 96    Antilock Brake System - Diagnosis 96-11-009     SEP 96    Piston Pin - Installation Tool Instructions 96-42A-015    JUL 96    Synthetic Resin Parts - Heat Resistance Specifications 96-55-006     MAY 96    A/C Refrigerant - Service Information 96-42A-007    MAR 96    Window - Chemical Film Build-Up/Fogging 95-16-003     NOV 95    Spark Plug - Fouling 95-54-001     OCT 95    Rear Window Defogger Grid - Repair ATRATB294     JAN 95    A/T - Drive Axle and Wheel Lug Nut Torque Specifications 9455001      JUN 94    A/C - System Leak Checking 9355006      DEC 93    A/C - Refrigerant Temperature Switch Manual Correction 9355001      JUN 93    A/C - Odor Correction 9322001      APR 93    M/T - Fluid Recommendation/Caution 9321001      APR 93    M/T - Flywheel Surfacing Limit 9317001      FEB 93    Emission - Control Information Label Ordering 9235008      DEC 92    Brakes - Rotor Service Procedures 9200010      DEC 92    VIN - Replacement Plate/Label 9213010      NOV 92    Chemicals - Fuel Injector Cleaner Feels 1/2 Full 9200009      NOV 92    Tools - MSN Multi-Use Tester ROM Pack Update 9231001      NOV 92    Wheels - Lug Nut Torque Information and Chart 9200003      AUG 92    Engine Controls - Never Use a Test Light To Check an ECM 9200005      AUG 92    VIN - Master Decoder Information 9251001      MAY 92    Paint - Damage Identification and Repair 9235003      MAR 92    Brakes - Pad Installation Service Points 9200001      JAN 92    Tools - Fault Codes When Using the Multi-Use Tester ATRATB078     NOV 91    A/T - How To Use A Pressure Gauge 91-00-015     OCT 91    Tools - Multi-Use Tester Warranty ATRATB062B    JUL 91    A/T - E4N71B, 4N71B & JM600 Overdrive Check Balls Link to comment Share on other sites More sharing options...
Guest Paul87Quest Posted November 23, 2002 Report Share Posted November 23, 2002 Bulletins for 1987 Mitsubishi Starion L4-2555cc 2.6L SOHC Turbo VIN N FI (CONT) 9111010 JUL 91 Engine - Piston Pin Installation Tool 91-00-011 JUL 91 Tools - Multi-Use Tester ROM Pack Usage ATRATBB055 JUN 91 A/T - E4N71B/JM600 Overdrive Sprag Rotation ATRATB053 JUN 91 A/T - Overdrive Planetary Burn Up 9111009 MAY 91 Engine - Automatic Valve Lash Adjuster Noise 9117002 MAR 91 Emissions - Correct Diagnosis of Emission Control Parts 9100004 MAR 91 Tools - Multi-Use Tester ROM Pack Usage 9155003 FEB 91 A/C - Refrigeration Oil Specification 9117001 FEB 91 Emissions - Updated Secondary Air System Inspection ATRATB028 OCT 90 A/T - Engine Vacuum Testing 9023011 OCT 90 A/T - Overdrive Shift Switch Removal 9016001 OCT 90 Battery - Care During Long Term Storage 9011007 OCT 90 Tools - Piston Pin Tool Operating Instructions 9054011 OCT 90 Windows - Repair of Rear Defogger Grid 9000001 SEP 90 VIN - Codes 9054003 MAR 90 Audio - Speaker Troubleshooting Manual Supplement 9027002 MAR 90 Drivetrain - Click, Snap or Clunking Noise From Rear 9011002 MAR 90 Timing Chain & Tensioner Spring - Parts Available 9055001 FEB 90 A/C - Handling Precautions For Freon R-12 ATRATB9002006 FEB 90 A/T - Choosing the Right ATF 9042B001 JAN 90 Windshield - Installation Instructions 8952002 NOV 89 Seat Belt - Rear Shoulder Belt Installation ATRATB8930 OCT 89 A/T - Math Part II 8911004 OCT 89 Silent Shaft Chain Tensioner Bolt - Torque Update ATRATB8927 SEP 89 A/T - Twenty Steps To Successful Repairs ATRATB8923 AUG 89 A/T - Math Formulas Part I 8911001 JUN 89 Engine Oil Screen - Illustration Revision 8900002 JUN 89 Multi Use Tester - Warranty 8900001 JUN 89 New Service Bulletin Group Numbers 8921001 JAN 89 A/T - Recommended Fluid 8908001 JAN 89 Fuel Gauge - Simple Test Procedures, Revision 88-24-004 OCT 88 A/C - Odors 88-00-005 OCT 88 Tool - Multi-Use Tester Application Chart 88-21-024 OCT 88 Transmission - Identification Codes 8814009 JUL 88 ECI-Multi Driveability Troubleshooting - Manual Update 8808007 MAY 88 A/C - Wiring Diagram Update 8821005 APR 88 A/T - Valve Body Corrections 8814007 APR 88 EGR Solenoid Valve - Updated RPM Specification for Check 8821003 MAR 88 M/T - KM132/KM145 Counter Gear Lock Nut Modification ATRATB889 FEB 88 A/T - Identification 8723015 DEC 87 Seat Belt Retractors - Inoperative 8722002 DEC 87 Wheels - Change In Amount of Allowable Runout 8723013 NOV 87 Paint - Repair of Minor Exterior Blemishes 8705003 OCT 87 Brake Modulator - Repair Kit 8700006 OCT 87 Brakes - Pad Thickness Limit Update 8714011 OCT 87 ISC & TPS - Revised Adjustment Procedure ATRATB8754 SEP 87 A/T - Front Bushing Wear 8707001 SEP 87 Cooling System - Water Outlet Fitting Change 8708008 SEP 87 Ignition Timing - Inspection Procedure Update 8708001R SEP 87 Ignition Timing - Revised Specifications & Procedure ATRATB8748 AUG 87 A/T - Slipping or No-Shift/Metal Sealing Rings 8709004 AUG 87 Engine - Thrust Plate Modification 8702001 AUG 87 Suspension - Front Strut Refill Capacity 8714005 JUN 87 Automatic Speed Control System - Service Manual Update 87-23-002 MAR 87 Chip Guard - Removal and Installation 8708006 MAR 87 Lighting Relay Box - Service Manual Update 8724001 FEB 87 A/C Oil & Refrigerant - Capacities 8714001 FEB 87 ECI - System Fundamentals Link to comment Share on other sites More sharing options...
Guest Paul87Quest Posted November 23, 2002 Report Share Posted November 23, 2002 Bulletins for 1986 Dodge Conquest TSI L4-2555cc 2.6L SOHC Turbo Safety Recalls TSB Number  Issue Date  TSB Title 651       JUN 96    Recall - Front Seat Belt Buckle Service Bulletins TSB Number  Issue Date  TSB Title 241796      NOV 96    R-12 to R-134A A/C Adaptation Procedure ATRATB294    JAN 95    A/T - Drive Axle and Wheel Lug Nut Torque Specifications ATRATB078    NOV 91    A/T - How To Use A Pressure Gauge ATRATB062B   JUL 91    A/T - E4N71B, 4N71B & JM600 Overdrive Check Balls ATRATBB055   JUN 91    A/T - E4N71B/JM600 Overdrive Sprag Rotation 080791       MAY 91    Wiring - Repair Instruction Sheets 070390       DEC 90    Engine Coolant - Recycling Recommendations ATRATB028    OCT 90    A/T - Engine Vacuum Testing MEMO082790  AUG 90    Service Bulletin Format Has Been Revised MEMO82790   AUG 90    Service Bulletin Format Revised 211890       AUG 90    Overdrive Switch - Removal Procedure 211090       MAR 90    KM132 M/T - 5TH Gear Revision 181190       MAR 90    Flooded Engine - Service Precautions 210890       MAR 90    M/T Shift Lever - Buzzes During Acceleration ATRATB9002006  FEB 90    A/T - Choosing the Right ATF ATRATB8930   OCT 89    A/T - Math Part II 262089       SEP 89    FWD Supplemental Labor Operation - Time Schedule Pages ATRATB8927   SEP 89    A/T - Twenty Steps To Successful Repairs ATRATB8923   AUG 89    A/T - Math Formulas Part I 100189       APR 89    Engine Oil - New `SG' Level Oil 090789       APR 89    Oil Pump Screen - Manual Revision 230389       FEB 89    Upholstery - Cleaning Procedure 081088       DEC 88    Battery - Checking Procedure Revision 181788       OCT 88    Spark Plugs - Oil Fouling/Misfire on Hard Acceleration 210788       JUL 88    M/T - Countershaft Gear Locknut Modification 210588       APR 88    A/T - Valve Body/Check Valve Specification Revision 211787       DEC 87    A/T - Gasket Kit Installation 220187       DEC 87    Wheels/Tires - Vibration & Road Shake At 45-65 Mph ATRATB8754   SEP 87    A/T - Front Bushing Wear ATRATB8748   AUG 87    A/T - Slipping or No-Shift/Metal Sealing Rings 081087A      APR 87    Wiper Wiring & Relays - Service Manual Revision 260386       DEC 86    Body - Rustproofing Application 091586       DEC 86    Engine - Oil Capacity, Manual Revision 185786       NOV 86    Failed Emission Black Smoke Code 52 185286       NOV 86    ECU - Rough Engine Idle 230986       SEP 86    Head Restraint Guide - Replacement 230886       SEP 86    Seat Belt Extender - Types/Identification 140886       JUL 86    ECI Driveability Tester - Usage 091386       JUN 86    Engine - Torque Specification Revision 230486       JUN 86    Rear Spoiler - Paint Peeling 240286       JUN 86    A/C Compressor Clutch - Repeat Failures 140586       MAY 86    Idle Speed/Air Flow Sensor - Manual Revisions 090886       MAR 86    Cylinder Head & Block - Resurface Limits 090386       MAR 86    Turbocharger - Manual Revisions 020985       OCT 85    Front Sway Bar - Squeak/Squawk Noises 260585       SEP 85    Vehicle & Component Identification 091785       SEP 85    Engine - Oil Application 232185       SEP 85    Paint - Codes/Applications/Cross References Link to comment Share on other sites More sharing options...
Guest Paul87Quest Posted November 23, 2002 Report Share Posted November 23, 2002 Bulletins for 1986 Mitsubishi Starion L4-2555cc 2.6L SOHC Turbo VIN N FI Safety Recalls TSB Number  Issue Date  TSB Title SR-95-002    OCT 95    Recall - Front Seat Belt Buckle Service Bulletins TSB Number  Issue Date  TSB Title 99-23-011    OCT 99    A/T Oil Cooler - Backflush Alternative 99-31-004    OCT 99    Wheel - Balancing Accuracy Tips 99-11-006    JUN 99    Engine - Valve Lash Adjuster Cleaning Procedure 99-00-002    FEB 99    Sealant/Adhesive/Chemical - Interchange Information 98-42A-008   OCT 98    Remote Keyless Entry - Update 98-00-00A    SEP 98    Fluids, Refrigerants and Materials (Genuine Mitsubishi) 99-00-001    JUN 98    VIN - Decoding Information 98-23-004    APR 98    A/T - Perform Cooler Flow Test When Replacing A/T 98-54-001    FEB 98    Audio System - Diagnosis 97-35-004    SEP 97    Brakes - Judder (vibration) Diagnosis and Repair 97-42A-012   SEP 97    Interior - Buzz, Squeak, and Rattle Kit 97-11-003    MAY 97    Engine, Valves - Valve Adjuster Noise Diagnosis 97-42A-001   FEB 97    Interior - Wind Noise Diagnosis 96-35-009    SEP 96    Antilock Brake System - Diagnosis 96-11-009    SEP 96    Piston Pin - Installation Tool Instructions 96-42A-015   JUL 96    Synthetic Resin Parts - Heat Resistance Specifications 96-55-006    MAY 96    A/C Refrigerant - Service Information 96-42A-007   MAR 96    Window - Chemical Film Build-Up/Fogging 95-16-003    NOV 95    Spark Plug - Fouling 95-54-001    OCT 95    Rear Window Defogger Grid - Repair ATRATB294    JAN 95    A/T - Drive Axle and Wheel Lug Nut Torque Specifications 9455001     JUN 94    A/C - System Leak Checking 9355006     DEC 93    A/C - Refrigerant Temperature Switch Manual Correction 9355001     JUN 93    A/C - Odor Correction 9322001     APR 93    M/T - Fluid Recommendation/Caution 9321001     APR 93    M/T - Flywheel Surfacing Limit 9317001     FEB 93    Emission - Control Information Label Ordering 9235008     DEC 92    Brakes - Rotor Service Procedures 9200010     DEC 92    VIN - Replacement Plate/Label 9213010     NOV 92    Chemicals - Fuel Injector Cleaner Feels 1/2 Full 9200009     NOV 92    Tools - MSN Multi-Use Tester ROM Pack Update 9231001     NOV 92    Wheels - Lug Nut Torque Information and Chart 9200003     AUG 92    Engine Controls - Never Use a Test Light To Check an ECM 9200005     AUG 92    VIN - Master Decoder Information 9251001     MAY 92    Paint - Damage Identification and Repair 9235003     MAR 92    Brakes - Pad Installation Service Points 9200001     JAN 92    Tools - Fault Codes When Using the Multi-Use Tester ATRATB078    NOV 91    A/T - How To Use A Pressure Gauge 91-00-015    OCT 91    Tools - Multi-Use Tester Warranty ATRATB062B   JUL 91    A/T - E4N71B, 4N71B & JM600 Overdrive Check Balls 9111010     JUL 91    Engine - Piston Pin Installation Tool 91-00-011    JUL 91    Tools - Multi-Use Tester ROM Pack Usage ATRATBB055   JUN 91    A/T - E4N71B/JM600 Overdrive Sprag Rotation ATRATB053    JUN 91    A/T - Overdrive Planetary Burn Up 9111009     MAY 91    Engine - Automatic Valve Lash Adjuster Noise 9117002     MAR 91    Emissions - Correct Diagnosis of Emission Control Parts 9100004     MAR 91    Tools -  Multi-Use Tester ROM Pack Usage 9155003     FEB 91    A/C - Refrigeration Oil Specification ATRATB028    OCT 90    A/T - Engine Vacuum Testing 9023011     OCT 90    A/T - Overdrive Shift Switch Removal 9016001     OCT 90    Battery - Care During Long Term Storage 9011007     OCT 90    Tools - Piston Pin Tool Operating Instructions 9054011     OCT 90    Windows - Repair of Rear Defogger Grid 9000001     SEP 90    VIN - Codes 9054003     MAR 90    Audio - Speaker Troubleshooting Manual Supplement 9027002     MAR 90    Drivetrain - Click, Snap or Clunking Noise From Rear 9011002     MAR 90    Timing Chain & Tensioner Spring - Parts Available 9055001     FEB 90    A/C - Handling Precautions For Freon R-12 ATRATB9002006  FEB 90    A/T - Choosing the Right ATF 9042B001    JAN 90    Windshield - Installation Instructions 8952002     NOV 89    Seat Belt - Rear Shoulder Belt Installation ATRATB8930  OCT 89    A/T - Math Part II Link to comment Share on other sites More sharing options...
Guest Paul87Quest Posted November 23, 2002 Report Share Posted November 23, 2002 Bulletins for 1986 Mitsubishi Starion L4-2555cc 2.6L SOHC Turbo VIN N FI (cont) 8911004 Â Â Â Â OCT 89 Â Â Â Silent Shaft Chain Tensioner Bolt - Torque Update ATRATB8927 Â Â SEP 89 Â Â Â A/T - Twenty Steps To Successful Repairs ATRATB8923 Â Â AUG 89 Â Â Â A/T - Math Formulas Part I 8911001 Â Â Â Â JUN 89 Â Â Â Engine Oil Screen - Illustration Revision 8900002 Â Â Â Â JUN 89 Â Â Â Multi Use Tester - Warranty 8900001 Â Â Â Â JUN 89 Â Â Â New Service Bulletin Group Numbers 8921001 Â Â Â Â JAN 89 Â Â Â A/T - Recommended Fluid 88-24-004 Â Â Â OCT 88 Â Â Â A/C - Odors 88-00-005 Â Â Â OCT 88 Â Â Â Tool - Multi-Use Tester Application Chart 88-21-024 Â Â Â OCT 88 Â Â Â Transmission - Identification Codes 8821005 Â Â Â Â APR 88 Â Â Â A/T Â - Valve Body Corrections ATRATB889 Â Â Â FEB 88 Â Â Â A/T - Identification ATRATB8754 Â Â SEP 87 Â Â Â A/T - Front Bushing Wear 8700005 Â Â Â Â SEP 87 Â Â Â Engine Oil - Capacity Update ATRATB8748 Â Â AUG 87 Â Â Â A/T - Slipping or No-Shift/Metal Sealing Rings 8702001 Â Â Â Â AUG 87 Â Â Â Suspension - Front Strut Refill Capacity 8709008 Â Â Â Â MAY 87 Â Â Â Engine Main Bearing Cap Bolt - Torque Update 87-08-003 Â Â Â MAR 87 Â Â Â Wiper Relay and Wiring Diagram - Revision 8714001 Â Â Â Â FEB 87 Â Â Â ECI - System Fundamentals 8621011 Â Â Â Â DEC 86 Â Â Â A/T - KM170 Transfer Idler Gear Bearing Removal 8623012 Â Â Â Â DEC 86 Â Â Â Body - Chipping Protector Replacement 8608008 Â Â Â Â DEC 86 Â Â Â Spark Plugs - Originals Differ From Replacements 8600002 Â Â Â Â OCT 86 Â Â Â Engine Oil Specifications - Service Manual Update 8602003 Â Â Â Â OCT 86 Â Â Â Front Tire - Fender Interference 8613001 Â Â Â Â AUG 86 Â Â Â Body - Repair Information 8623006 Â Â Â Â AUG 86 Â Â Â Paint - Color Codes and Applications 8609005 Â Â Â Â JUL 86 Â Â Â Engine - Semicircular Packing (Cam Bore Plug) 8621005 Â Â Â Â JUN 86 Â Â Â A/T - Service Manual Update 8621004 Â Â Â Â JUN 86 Â Â Â Clutch Release Cylinder - Repair Kit 8623002 Â Â Â Â MAY 86 Â Â Â Body - Sealant Application 8614002 Â Â Â Â MAY 86 Â Â Â Fuel System - Specifications Update 8623003 Â Â Â Â MAY 86 Â Â Â Spoilers - Paint Peeling or Blistering 8609002 Â Â Â Â FEB 86 Â Â Â Turbocharger - Removal/Installation Manual Update 8502006 Â Â Â Â DEC 85 Â Â Â Strut - Noise 8523016 Â Â Â Â NOV 85 Â Â Â Side Molding and Front Bumper Stripe - Labor Time 8523010 Â Â Â Â OCT 85 Â Â Â Front Bumper Stripe - Bubbling or Wrinkling 8523013 Â Â Â Â OCT 85 Â Â Â Paint - Exterior Color Codes and Applications 8508010 Â Â Â Â JUL 85 Â Â Â Fuse Block - Update 8523006 Â Â Â Â JUN 85 Â Â Â Body Side Molding - Replacement 8500002 Â Â Â Â JUN 85 Â Â Â Crankcase - Drain Plug Gasket 8523005 Â Â Â Â JUN 85 Â Â Â Side Moulding Application - Adhesion Tip 8522001 Â Â Â Â JUN 85 Â Â Â Wheels - Aftermarket Replacement Precaution 8514003 Â Â Â Â MAY 85 Â Â Â ECI - ECI W/Intercooler Test Procedures 8502002 Â Â Â Â FEB 85 Â Â Â Suspension - PDI Front Spring Restraints Link to comment Share on other sites More sharing options...
Guest Paul87Quest Posted November 25, 2002 Report Share Posted November 25, 2002 Bulletins for 1985 Dodge Conquest L4-2555cc 2.6L SOHC Turbo Service Bulletins    TSB Number  Issue Date  TSB Title 241796      NOV 96    R-12 to R-134A A/C Adaptation Procedure ATRATB294    JAN 95    A/T - Drive Axle and Wheel Lug Nut Torque Specifications ATRATB078    NOV 91    A/T - How To Use A Pressure Gauge ATRATB062B   JUL 91    A/T - E4N71B, 4N71B & JM600 Overdrive Check Balls ATRATBB055   JUN 91    A/T - E4N71B/JM600 Overdrive Sprag Rotation 080791       MAY 91    Wiring - Repair Instruction Sheets 070390       DEC 90    Engine Coolant - Recycling Recommendations ATRATB028    OCT 90    A/T - Engine Vacuum Testing MEMO082790  AUG 90    Service Bulletin Format Has Been Revised MEMO82790   AUG 90    Service Bulletin Format Revised 211890       AUG 90    Overdrive Switch - Removal Procedure 211090       MAR 90    KM132 M/T - 5TH Gear Revision 181190       MAR 90    Flooded Engine - Service Precautions 210890       MAR 90    M/T Shift Lever - Buzzes During Acceleration ATRATB9002006 FEB 90    A/T - Choosing the Right ATF ATRATB8930    OCT 89    A/T - Math Part II 262089        SEP 89    FWD Supplemental Labor Operation - Time Schedule Pages ATRATB8927    SEP 89    A/T - Twenty Steps To Successful Repairs ATRATB8923    AUG 89    A/T - Math Formulas Part I 100189        APR 89    Engine Oil - New `SG' Level Oil 090789        APR 89    Oil Pump Screen - Manual Revision 230389        FEB 89    Upholstery - Cleaning Procedure 081088        DEC 88    Battery - Checking Procedure Revision 181788        OCT 88    Spark Plugs - Oil Fouling/Misfire on Hard Acceleration 210788        JUL 88    M/T - Countershaft Gear Locknut Modification 210588        APR 88    A/T - Valve Body/Check Valve Specification Revision 211787        DEC 87    A/T - Gasket Kit Installation ATRATB8754     SEP 87    A/T - Front Bushing Wear ATRATB8748     AUG 87    A/T - Slipping or No-Shift/Metal Sealing Rings 091786        DEC 86    Silent Shaft Sprocket Bolt - Torque Revision 091586        DEC 86    Engine - Oil Capacity, Manual Revision 185286        NOV 86    ECU - Rough Engine Idle 230886        SEP 86    Seat Belt Extender - Types/Identification 140886        JUL 86    ECI Driveability Tester - Usage 080486        JUL 86    Battery/Charging System - Malfunction 091386        JUN 86    Engine - Torque Specification Revision 240286         JUN 86    A/C Compressor Clutch - Repeat Failures 140586        MAY 86    Idle Speed/Air Flow Sensor - Manual Revisions 181586        MAR 86    TPS - Cold Engine Sag, Cold Engine Surge 090886        MAR 86    Cylinder Head & Block - Resurface Limits 140186        JAN 86    ECI System - Service Manual Revision 050485        NOV 85    Rear Disc Brakes - Squeak During Stopping 020985        OCT 85    Front Sway Bar - Squeak/Squawk Noises 082585        OCT 85    Radio - Trembling Noise/Distortion From Speakers 091785        SEP 85    Engine - Oil Application 050385        SEP 85    Front Disc Brakes - Squeaks on Stopping 142585        AUG 85    ECI System - Check Procedure Chart 211685        AUG 85    Overdrive Indicator Switch - Deletion/Manual Update 082285        JUL 85    Cassette Player - Non Ejection/Tape Removal 210485        JUN 85    Automatic Transmission - New Fluid Type 081685        JUN 85    Fuse Block - Fuse Applications 082085        MAY 85    Power Window Switch - Manual Revision 240585        APR 85    A/C Cooling Unit - Removal and Installation 080985        APR 85    Radio - Rapid Crackling Noise in FM Mode 180085        FEB 85    Technical Service Bulletins - New Driveability Group 180885        FEB 85    Engine - Road Ready Idle Speed 080385        FEB 85    Radio/Clock - Defeat Function Explanation 080685        FEB 85    Oil Pressure Sender - Leaks Oil 090685        JAN 85    Turbocharger - Service Manual Correction ATRATB8542    JAN 85    A/T - Fluid Recommendation 082784        NOV 84    Radio - Volume Control Inoperative 232184        NOV 84    Synthetic Resin Bumpers - Painting 145284        OCT 84    Fuel - Alcohol Fuel Recommendations 145484        OCT 84    Fuel Hose - Restriction at Medium/Wide Open Throttle 144684        OCT 84    Propane Idle Adjustment - Determination Guidelines 231784        SEP 84    Paint - Codes/Cross References/Applications Link to comment Share on other sites More sharing options...
Guest Paul87Quest Posted November 25, 2002 Report Share Posted November 25, 2002 Bulletins for 1985 Mitsubishi Starion L4-2555cc 2.6L SOHC Turbo VIN H FI Service Bulletins TSB Number  Issue Date  TSB Title 99-23-011    OCT 99    A/T Oil Cooler - Backflush Alternative 99-31-004    OCT 99    Wheel - Balancing Accuracy Tips 99-11-006    JUN 99    Engine - Valve Lash Adjuster Cleaning Procedure 99-00-002    FEB 99    Sealant/Adhesive/Chemical - Interchange Information 98-42A-008   OCT 98    Remote Keyless Entry - Update 98-00-00A    SEP 98    Fluids, Refrigerants and Materials (Genuine Mitsubishi) 99-00-001    JUN 98    VIN - Decoding Information 98-23-004    APR 98    A/T - Perform Cooler Flow Test When Replacing A/T 98-54-001    FEB 98    Audio System - Diagnosis 97-35-004    SEP 97    Brakes - Judder (vibration) Diagnosis and Repair 97-42A-012   SEP 97    Interior - Buzz, Squeak, and Rattle Kit 97-42A-001   FEB 97    Interior - Wind Noise Diagnosis 96-35-009    SEP 96    Antilock Brake System - Diagnosis 96-11-009    SEP 96    Piston Pin - Installation Tool Instructions 96-42A-015   JUL 96    Synthetic Resin Parts - Heat Resistance Specifications 96-55-006    MAY 96    A/C Refrigerant - Service Information 96-42A-007   MAR 96    Window - Chemical Film Build-Up/Fogging 95-16-003    NOV 95    Spark Plug - Fouling 95-54-001    OCT 95    Rear Window Defogger Grid - Repair ATRATB294    JAN 95    A/T - Drive Axle and Wheel Lug Nut Torque Specifications 9455001     JUN 94    A/C - System Leak Checking 9355006     DEC 93    A/C - Refrigerant Temperature Switch Manual Correction 9355001     JUN 93    A/C - Odor Correction 9322001     APR 93    M/T - Fluid Recommendation/Caution 9321001     APR 93    M/T - Flywheel Surfacing Limit 9317001     FEB 93    Emission - Control Information Label Ordering 9235008     DEC 92    Brakes - Rotor Service Procedures 9200010     DEC 92    VIN - Replacement Plate/Label 9213010     NOV 92    Chemicals - Fuel Injector Cleaner Feels 1/2 Full 9200009     NOV 92    Tools - MSN Multi-Use Tester ROM Pack Update 9231001     NOV 92    Wheels - Lug Nut Torque Information and Chart 9200003     AUG 92    Engine Controls - Never Use a Test Light To Check an ECM 9200005     AUG 92    VIN - Master Decoder Information 9251001     MAY 92    Paint - Damage Identification and Repair 9235003     MAR 92    Brakes - Pad Installation Service Points 9200001     JAN 92    Tools - Fault Codes When Using the Multi-Use Tester ATRATB078    NOV 91    A/T - How To Use A Pressure Gauge 91-00-015    OCT 91    Tools - Multi-Use Tester Warranty ATRATB062B   JUL 91    A/T - E4N71B, 4N71B & JM600 Overdrive Check Balls 9111010     JUL 91    Engine - Piston Pin Installation Tool 91-00-011    JUL 91    Tools - Multi-Use Tester ROM Pack Usage ATRATBB055   JUN 91    A/T - E4N71B/JM600 Overdrive Sprag Rotation ATRATB053    JUN 91    A/T - Overdrive Planetary Burn Up 9111009     MAY 91    Engine - Automatic Valve Lash Adjuster Noise 9117002     MAR 91    Emissions - Correct Diagnosis of Emission Control Parts 9100004     MAR 91    Tools -  Multi-Use Tester ROM Pack Usage 9155003     FEB 91    A/C - Refrigeration Oil Specification ATRATB028    OCT 90    A/T - Engine Vacuum Testing Link to comment Share on other sites More sharing options...
Guest Paul87Quest Posted November 25, 2002 Report Share Posted November 25, 2002 Bulletins for 1985 Mitsubishi Starion L4-2555cc 2.6L SOHC Turbo VIN H FI (cont) 9023011     OCT 90    A/T - Overdrive Shift Switch Removal 9016001     OCT 90    Battery - Care During Long Term Storage 9011007     OCT 90    Tools - Piston Pin Tool Operating Instructions 9054011     OCT 90    Windows - Repair of Rear Defogger Grid 9000001     SEP 90    VIN - Codes 9054003     MAR 90    Audio - Speaker Troubleshooting Manual Supplement 9027002     MAR 90    Drivetrain - Click, Snap or Clunking Noise From Rear 9011002     MAR 90    Timing Chain & Tensioner Spring - Parts Available 9055001     FEB 90    A/C - Handling Precautions For Freon R-12 ATRATB9002006  FEB 90    A/T - Choosing the Right ATF 9042B001    JAN 90    Windshield - Installation Instructions 8952002     NOV 89    Seat Belt - Rear Shoulder Belt Installation ATRATB8930    OCT 89    A/T - Math Part II 8911004      OCT 89    Silent Shaft Chain Tensioner Bolt - Torque Update ATRATB8927   SEP 89    A/T - Twenty Steps To Successful Repairs ATRATB8923   AUG 89    A/T - Math Formulas Part I 8911001     JUN 89    Engine Oil Screen - Illustration Revision 8900002     JUN 89    Multi Use Tester - Warranty 8900001     JUN 89    New Service Bulletin Group Numbers 8921001     JAN 89    A/T - Recommended Fluid 88-24-004    OCT 88    A/C - Odors 88-00-005    OCT 88    Tool - Multi-Use Tester Application Chart 88-21-024    OCT 88    Transmission - Identification Codes 8821005     APR 88    A/T  - Valve Body Corrections ATRATB889    FEB 88    A/T - Identification ATRATB8754   SEP 87    A/T - Front Bushing Wear 8700005     SEP 87    Engine Oil - Capacity Update ATRATB8748   AUG 87    A/T - Slipping or No-Shift/Metal Sealing Rings 8709008     MAY 87    Engine Main Bearing Cap Bolt - Torque Update 8714001     FEB 87    ECI - System Fundamentals 8600002     OCT 86    Engine Oil Specifications - Service Manual Update 8621005     JUN 86    A/T - Service Manual Update 8621004     JUN 86    Clutch Release Cylinder - Repair Kit 8614002     MAY 86    Fuel System - Specifications Update 8608001     FEB 86    Alternator - Damaged Harness Replacement 8524010     DEC 85    A/C - Water Temperature Switch Torque Spec Revision 8505004     DEC 85    Brakes - Squeel/Pad Kit 8514011     DEC 85    Fuel - Pressure Test Adapter Couplers 8514008     NOV 85    Engine - Sag or Bucking Condition 8523016     NOV 85    Side Molding and Front Bumper Stripe - Labor Time 8509013     NOV 85    Special Tool - Adapter For Engine Stabilizer 8524009     OCT 85    A/C - Wiring Diagram Update 8503001     OCT 85    Differential Drive Pinion Bearing - New 8509011     OCT 85    Exhaust Manifold - Replacement 8523010     OCT 85    Front Bumper Stripe - Bubbling or Wrinkling 8519006     OCT 85    Power Steering - Flow Control Spring Service Standard 8524007     SEP 85    A/C Controller - Replacement Procedure & Precaution 8524006     AUG 85    ATC Controller - Diagnostic & Repair Informaton 8505002     AUG 85    Brakes - Push Rod Clearance Specifications 8508009     JUL 85    Distributor - Timing Specifications 8509009     JUL 85    Engine - Cylinder Block Distortion Limit Specification 8508010     JUL 85    Fuse Block - Update 8523006     JUN 85    Body Side Molding - Replacement 8500002     JUN 85    Crankcase - Drain Plug Gasket 8508011     JUN 85    Engine - Turbo Cross-Fire Shock 8523005     JUN 85    Side Moulding Application - Adhesion Tip 8519003     JUN 85    Steering Wheel - Centering 8522001     JUN 85    Wheels - Aftermarket Replacement Precaution 8514003     MAY 85    ECI - ECI W/Intercooler Test Procedures 8525003     MAY 85    Emissions Certification - Identification Update 8508008     MAY 85    Power Window Switch - Connection, Manual Update 8508005     APR 85    Audio - Steering Wheel Controls Do Not Work 8509005     APR 85    Cylinder Head - Distortion Limits 8524002     FEB 85    A/C Evaporator - Removal and Installation 8514002     FEB 85    Engine - ISC/TPS Adjustment (ECI Models) 8502002     FEB 85    Suspension - PDI Front Spring Restraints 85-24-001    FEB 85    Water Temperature Switch - Torque Specification 8408009     NOV 84    Audio - Troubleshooting Steering Wheel Radio Controls 8400002     NOV 84    Automatic Transmission - Fluid Recommendations 8423006R    SEP 84    Paint  - Code Index 8424003     AUG 84    A/C - Adding Refrigerant Oil 8424002     AUG 84    A/C - High Pressure Service Valve Adapter 8421006     AUG 84    M/T - Changes 8423003     AUG 84    Paint - Codes Link to comment Share on other sites More sharing options...
Guest Paul87Quest Posted November 25, 2002 Report Share Posted November 25, 2002 Bulletins for 1985 Mitsubishi Starion L4-2555cc 2.6L SOHC Turbo VIN N FI Service Bulletins   TSB Number  Issue Date  TSB Title 99-23-011    OCT 99    A/T Oil Cooler - Backflush Alternative 99-31-004    OCT 99    Wheel - Balancing Accuracy Tips 99-11-006    JUN 99    Engine - Valve Lash Adjuster Cleaning Procedure 99-00-002    FEB 99    Sealant/Adhesive/Chemical - Interchange Information 98-42A-008   OCT 98    Remote Keyless Entry - Update 98-00-00A    SEP 98    Fluids, Refrigerants and Materials (Genuine Mitsubishi) 99-00-001    JUN 98    VIN - Decoding Information 98-23-004    APR 98    A/T - Perform Cooler Flow Test When Replacing A/T 98-54-001    FEB 98    Audio System - Diagnosis 97-35-004    SEP 97    Brakes - Judder (vibration) Diagnosis and Repair 97-42A-012   SEP 97    Interior - Buzz, Squeak, and Rattle Kit 97-42A-001   FEB 97    Interior - Wind Noise Diagnosis 96-35-009    SEP 96    Antilock Brake System - Diagnosis 96-11-009    SEP 96    Piston Pin - Installation Tool Instructions 96-42A-015   JUL 96    Synthetic Resin Parts - Heat Resistance Specifications 96-55-006    MAY 96    A/C Refrigerant - Service Information 96-42A-007   MAR 96    Window - Chemical Film Build-Up/Fogging 95-16-003    NOV 95    Spark Plug - Fouling 95-54-001    OCT 95    Rear Window Defogger Grid - Repair ATRATB294    JAN 95    A/T - Drive Axle and Wheel Lug Nut Torque Specifications 9455001     JUN 94    A/C - System Leak Checking 9355006     DEC 93    A/C - Refrigerant Temperature Switch Manual Correction 9355001     JUN 93    A/C - Odor Correction 9322001     APR 93    M/T - Fluid Recommendation/Caution 9321001     APR 93    M/T - Flywheel Surfacing Limit 9317001     FEB 93    Emission - Control Information Label Ordering 9235008     DEC 92    Brakes - Rotor Service Procedures 9200010     DEC 92    VIN - Replacement Plate/Label 9213010     NOV 92    Chemicals - Fuel Injector Cleaner Feels 1/2 Full 9200009     NOV 92    Tools - MSN Multi-Use Tester ROM Pack Update 9231001     NOV 92    Wheels - Lug Nut Torque Information and Chart 9200003     AUG 92    Engine Controls - Never Use a Test Light To Check an ECM 9200005     AUG 92    VIN - Master Decoder Information 9251001     MAY 92    Paint - Damage Identification and Repair 9235003     MAR 92    Brakes - Pad Installation Service Points 9200001     JAN 92    Tools - Fault Codes When Using the Multi-Use Tester ATRATB078    NOV 91    A/T - How To Use A Pressure Gauge 91-00-015    OCT 91    Tools - Multi-Use Tester Warranty ATRATB062B   JUL 91    A/T - E4N71B, 4N71B & JM600 Overdrive Check Balls 9111010     JUL 91    Engine - Piston Pin Installation Tool 91-00-011    JUL 91    Tools - Multi-Use Tester ROM Pack Usage ATRATBB055   JUN 91    A/T - E4N71B/JM600 Overdrive Sprag Rotation ATRATB053    JUN 91    A/T - Overdrive Planetary Burn Up 9111009     MAY 91    Engine - Automatic Valve Lash Adjuster Noise 9117002     MAR 91    Emissions - Correct Diagnosis of Emission Control Parts 9100004     MAR 91    Tools -  Multi-Use Tester ROM Pack Usage 9155003     FEB 91    A/C - Refrigeration Oil Specification ATRATB028    OCT 90    A/T - Engine Vacuum Testing 9023011     OCT 90    A/T - Overdrive Shift Switch Removal 9016001     OCT 90    Battery - Care During Long Term Storage 9011007     OCT 90    Tools - Piston Pin Tool Operating Instructions Link to comment Share on other sites More sharing options...
Guest Paul87Quest Posted November 25, 2002 Report Share Posted November 25, 2002 Bulletins for 1985 Mitsubishi Starion L4-2555cc 2.6L SOHC Turbo VIN N FI (CONT) 9054011 OCT 90 Windows - Repair of Rear Defogger Grid 9000001 SEP 90 VIN - Codes 9054003 MAR 90 Audio - Speaker Troubleshooting Manual Supplement 9027002 MAR 90 Drivetrain - Click, Snap or Clunking Noise From Rear 9011002 MAR 90 Timing Chain & Tensioner Spring - Parts Available 9055001 FEB 90 A/C - Handling Precautions For Freon R-12 ATRATB9002006 FEB 90 A/T - Choosing the Right ATF 9042B001 JAN 90 Windshield - Installation Instructions 8952002 NOV 89 Seat Belt - Rear Shoulder Belt Installation ATRATB8930 OCT 89 A/T - Math Part II 8911004 OCT 89 Silent Shaft Chain Tensioner Bolt - Torque Update ATRATB8927 SEP 89 A/T - Twenty Steps To Successful Repairs ATRATB8923 AUG 89 A/T - Math Formulas Part I 8911001 JUN 89 Engine Oil Screen - Illustration Revision 8900002 JUN 89 Multi Use Tester - Warranty 8900001 JUN 89 New Service Bulletin Group Numbers 8921001 JAN 89 A/T - Recommended Fluid 88-24-004 OCT 88 A/C - Odors 88-00-005 OCT 88 Tool - Multi-Use Tester Application Chart 88-21-024 OCT 88 Transmission - Identification Codes 8821005 APR 88 A/T - Valve Body Corrections ATRATB889 FEB 88 A/T - Identification ATRATB8754 SEP 87 A/T - Front Bushing Wear 8700005 SEP 87 Engine Oil - Capacity Update ATRATB8748 AUG 87 A/T - Slipping or No-Shift/Metal Sealing Rings 8709008 MAY 87 Engine Main Bearing Cap Bolt - Torque Update 8714001 FEB 87 ECI - System Fundamentals 8600002 OCT 86 Engine Oil Specifications - Service Manual Update 8621005 JUN 86 A/T - Service Manual Update 8621004 JUN 86 Clutch Release Cylinder - Repair Kit 8614002 MAY 86 Fuel System - Specifications Update 8608001 FEB 86 Alternator - Damaged Harness Replacement 8524010 DEC 85 A/C - Water Temperature Switch Torque Spec Revision 8505004 DEC 85 Brakes - Squeel/Pad Kit 8514011 DEC 85 Fuel - Pressure Test Adapter Couplers 8514008 NOV 85 Engine - Sag or Bucking Condition 8523016 NOV 85 Side Molding and Front Bumper Stripe - Labor Time 8509013 NOV 85 Special Tool - Adapter For Engine Stabilizer 8524009 OCT 85 A/C - Wiring Diagram Update 8503001 OCT 85 Differential Drive Pinion Bearing - New 8509011 OCT 85 Exhaust Manifold - Replacement 8523010 OCT 85 Front Bumper Stripe - Bubbling or Wrinkling 8519006 OCT 85 Power Steering - Flow Control Spring Service Standard 8524007 SEP 85 A/C Controller - Replacement Procedure & Precaution 8524006 AUG 85 ATC Controller - Diagnostic & Repair Informaton 8505002 AUG 85 Brakes - Push Rod Clearance Specifications 8508009 JUL 85 Distributor - Timing Specifications 8509009 JUL 85 Engine - Cylinder Block Distortion Limit Specification 8508010 JUL 85 Fuse Block - Update 8523006 JUN 85 Body Side Molding - Replacement 8500002 JUN 85 Crankcase - Drain Plug Gasket 8508011 JUN 85 Engine - Turbo Cross-Fire Shock 8523005 JUN 85 Side Moulding Application - Adhesion Tip 8519003 JUN 85 Steering Wheel - Centering 8522001 JUN 85 Wheels - Aftermarket Replacement Precaution 8514003 MAY 85 ECI - ECI W/Intercooler Test Procedures 8525003 MAY 85 Emissions Certification - Identification Update 8508008 MAY 85 Power Window Switch - Connection, Manual Update 8508005 APR 85 Audio - Steering Wheel Controls Do Not Work 8509005 APR 85 Cylinder Head - Distortion Limits 8524002 FEB 85 A/C Evaporator - Removal and Installation 8514002 FEB 85 Engine - ISC/TPS Adjustment (ECI Models) 8502002 FEB 85 Suspension - PDI Front Spring Restraints 85-24-001 FEB 85 Water Temperature Switch - Torque Specification 8408009 NOV 84 Audio - Troubleshooting Steering Wheel Radio Controls 8400002 NOV 84 Automatic Transmission - Fluid Recommendations 8423006R SEP 84 Paint - Code Index 8424003 AUG 84 A/C - Adding Refrigerant Oil 8424002 AUG 84 A/C - High Pressure Service Valve Adapter 8421006 AUG 84 M/T - Changes 8423003 AUG 84 Paint - Codes Link to comment Share on other sites More sharing options...
Guest Paul87Quest Posted November 25, 2002 Report Share Posted November 25, 2002 Bulletins for 1984 Dodge Conquest L4-2555cc 2.6L Turbo General Recalls TSB Number Issue Date TSB Title 356 JUL 84 Campaign - Sticking Oil Pump Relief Valve Service Bulletins TSB Number Issue Date TSB Title 241796 NOV 96 R-12 to R-134A A/C Adaptation Procedure ATRATB294 JAN 95 A/T - Drive Axle and Wheel Lug Nut Torque Specifications ATRATB078 NOV 91 A/T - How To Use A Pressure Gauge ATRATB062B JUL 91 A/T - E4N71B, 4N71B & JM600 Overdrive Check Balls ATRATBB055 JUN 91 A/T - E4N71B/JM600 Overdrive Sprag Rotation 080791 MAY 91 Wiring - Repair Instruction Sheets 070390 DEC 90 Engine Coolant - Recycling Recommendations ATRATB028 OCT 90 A/T - Engine Vacuum Testing MEMO082790 AUG 90 Service Bulletin Format Has Been Revised MEMO82790 AUG 90 Service Bulletin Format Revised 211890 AUG 90 Overdrive Switch - Removal Procedure 181190 MAR 90 Flooded Engine - Service Precautions ATRATB9002006 FEB 90 A/T - Choosing the Right ATF ATRATB8930 OCT 89 A/T - Math Part II 262089 SEP 89 FWD Supplemental Labor Operation - Time Schedule Pages ATRATB8927 SEP 89 A/T - Twenty Steps To Successful Repairs ATRATB8923 AUG 89 A/T - Math Formulas Part I 100189 APR 89 Engine Oil - New `SG' Level Oil 090789 APR 89 Oil Pump Screen - Manual Revision 230389 FEB 89 Upholstery - Cleaning Procedure 081088 DEC 88 Battery - Checking Procedure Revision 181788 OCT 88 Spark Plugs - Oil Fouling/Misfire on Hard Acceleration 210788 JUL 88 M/T - Countershaft Gear Locknut Modification 211787 DEC 87 A/T - Gasket Kit Installation ATRATB8754 SEP 87 A/T - Front Bushing Wear ATRATB8748 AUG 87 A/T - Slipping or No-Shift/Metal Sealing Rings 091786 DEC 86 Silent Shaft Sprocket Bolt - Torque Revision 230886 SEP 86 Seat Belt Extender - Types/Identification 140886 JUL 86 ECI Driveability Tester - Usage 080486 JUL 86 Battery/Charging System - Malfunction 181586 MAR 86 TPS - Cold Engine Sag, Cold Engine Surge 090886 MAR 86 Cylinder Head & Block - Resurface Limits 050485 NOV 85 Rear Disc Brakes - Squeak During Stopping 020985 OCT 85 Front Sway Bar - Squeak/Squawk Noises 091785 SEP 85 Engine - Oil Application 050385 SEP 85 Front Disc Brakes - Squeaks on Stopping 142385 AUG 85 Turbocharger - Lack of Boost/Grinding Noises 090985 JUL 85 Engine - Metallic Knock/Noise on Start Up 082285 JUL 85 Cassette Player - Non Ejection/Tape Removal 210485 JUN 85 Automatic Transmission - New Fluid Type 180085 FEB 85 Technical Service Bulletins - New Driveability Group 180885 FEB 85 Engine - Road Ready Idle Speed 210385 FEB 85 A/T - Service Manual Correction ATRATB8542 JAN 85 A/T - Fluid Recommendation 145184 DEC 84 Fuel Injector - Identification Chart 082584 DEC 84 Electronics/Instruments - Regional Service Centers 144884 DEC 84 Engine - Sag/Poor Hot Restart 091284 DEC 84 Oil Filter - Addition of Second Supplier 081384 DEC 84 Radio/Stereo - Repair and Exchange Depots 146284 DEC 84 Carburetor Coolant Hose - Installation Procedure 082784 NOV 84 Radio - Volume Control Inoperative 232184 NOV 84 Synthetic Resin Bumpers - Painting 082684 NOV 84 Radio - Speaker Noise When Warning Buzzers Are ON 145284 OCT 84 Fuel - Alcohol Fuel Recommendations 144184 OCT 84 Turbocharger - Component Part Replacement Procedure 210684A AUG 84 5-Speed Manual Transmission - Revisions 082284 AUG 84 Horn - Intermittently Inoperative 081984 JUL 84 Speed Control - Diagnosis & Test Procedures 143484 JUN 84 ECI Self Diagnosis Connector -Relocation 090584 MAY 84 Engine - Oil Pressure Testing Revision 142084 MAY 84 Engine Specifications - Manual Corrections 030184 APR 84 Differential - Limited-Slip Lubricant 080184 MAR 84 Instrument Cluster - Odometer Memory Chip Service 141284 MAR 84 Throttle Cable Adjusting Nut - Torque Specification 081184 MAR 84 Voltmeter - Explanation for High Readings 081084 MAR 84 Speed Control - Wiring Diagram Revision 080884 FEB 84 Radio - No AM/Weak FM Reception 260184 FEB 84 Vehicle & Component Identification 140884 JAN 84 Propane Idle Set - Procedure 232083 NOV 83 Front License Plate Bracket - Installation 231483 NOV 83 Outside Door Mirror - Installation 231383 SEP 83 Paint - Codes/Cross References Link to comment Share on other sites More sharing options...
Guest Paul87Quest Posted November 25, 2002 Report Share Posted November 25, 2002 Bulletins for 1984 Mitsubishi Starion L4-2555cc 2.6L SOHC Turbo Service Bulletins TSB Number Issue Date TSB Title 99-23-011 OCT 99 A/T Oil Cooler - Backflush Alternative 99-31-004 OCT 99 Wheel - Balancing Accuracy Tips 99-11-006 JUN 99 Engine - Valve Lash Adjuster Cleaning Procedure 99-00-002 FEB 99 Sealant/Adhesive/Chemical - Interchange Information 98-42A-008 OCT 98 Remote Keyless Entry - Update 98-00-00A SEP 98 Fluids, Refrigerants and Materials (Genuine Mitsubishi) 99-00-001 JUN 98 VIN - Decoding Information 98-23-004 APR 98 A/T - Perform Cooler Flow Test When Replacing A/T 98-54-001 FEB 98 Audio System - Diagnosis 97-35-004 SEP 97 Brakes - Judder (vibration) Diagnosis and Repair 97-42A-012 SEP 97 Interior - Buzz, Squeak, and Rattle Kit 97-42A-001 FEB 97 Interior - Wind Noise Diagnosis 96-35-009 SEP 96 Antilock Brake System - Diagnosis 96-11-009 SEP 96 Piston Pin - Installation Tool Instructions 96-42A-015 JUL 96 Synthetic Resin Parts - Heat Resistance Specifications 96-55-006 MAY 96 A/C Refrigerant - Service Information 96-42A-007 MAR 96 Window - Chemical Film Build-Up/Fogging 95-16-003 NOV 95 Spark Plug - Fouling 95-54-001 OCT 95 Rear Window Defogger Grid - Repair ATRATB294 JAN 95 A/T - Drive Axle and Wheel Lug Nut Torque Specifications 9455001 JUN 94 A/C - System Leak Checking 9355006 DEC 93 A/C - Refrigerant Temperature Switch Manual Correction 9355001 JUN 93 A/C - Odor Correction 9322001 APR 93 M/T - Fluid Recommendation/Caution 9321001 APR 93 M/T - Flywheel Surfacing Limit 9317001 FEB 93 Emission - Control Information Label Ordering 9235008 DEC 92 Brakes - Rotor Service Procedures 9200010 DEC 92 VIN - Replacement Plate/Label 9213010 NOV 92 Chemicals - Fuel Injector Cleaner Feels 1/2 Full 9200009 NOV 92 Tools - MSN Multi-Use Tester ROM Pack Update 9231001 NOV 92 Wheels - Lug Nut Torque Information and Chart 9200003 AUG 92 Engine Controls - Never Use a Test Light To Check an ECM 9200005 AUG 92 VIN - Master Decoder Information 9251001 MAY 92 Paint - Damage Identification and Repair 9235003 MAR 92 Brakes - Pad Installation Service Points 9200001 JAN 92 Tools - Fault Codes When Using the Multi-Use Tester ATRATB078 NOV 91 A/T - How To Use A Pressure Gauge 91-00-015 OCT 91 Tools - Multi-Use Tester Warranty 9111010 JUL 91 Engine - Piston Pin Installation Tool 91-00-011 JUL 91 Tools - Multi-Use Tester ROM Pack Usage 9111009 MAY 91 Engine - Automatic Valve Lash Adjuster Noise 9117002 MAR 91 Emissions - Correct Diagnosis of Emission Control Parts 9100004 MAR 91 Tools - Multi-Use Tester ROM Pack Usage 9155003 FEB 91 A/C - Refrigeration Oil Specification ATRATB028 OCT 90 A/T - Engine Vacuum Testing 9016001 OCT 90 Battery - Care During Long Term Storage 9011007 OCT 90 Tools - Piston Pin Tool Operating Instructions 9054011 OCT 90 Windows - Repair of Rear Defogger Grid 9000001 SEP 90 VIN - Codes 9054003 MAR 90 Audio - Speaker Troubleshooting Manual Supplement 9027002 MAR 90 Drivetrain - Click, Snap or Clunking Noise From Rear 9011002 MAR 90 Timing Chain & Tensioner Spring - Parts Available 9055001 FEB 90 A/C - Handling Precautions For Freon R-12 ATRATB9002006 FEB 90 A/T - Choosing the Right ATF Link to comment Share on other sites More sharing options...
Guest Paul87Quest Posted November 25, 2002 Report Share Posted November 25, 2002 Bulletins for 1984 Mitsubishi Starion L4-2555cc 2.6L SOHC Turbo (CONT) 9042B001 JAN 90 Windshield - Installation Instructions 8952002 NOV 89 Seat Belt - Rear Shoulder Belt Installation ATRATB8930 OCT 89 A/T - Math Part II 8911004 OCT 89 Silent Shaft Chain Tensioner Bolt - Torque Update ATRATB8927 SEP 89 A/T - Twenty Steps To Successful Repairs ATRATB8923 AUG 89 A/T - Math Formulas Part I 8911001 JUN 89 Engine Oil Screen - Illustration Revision 8900002 JUN 89 Multi Use Tester - Warranty 8900001 JUN 89 New Service Bulletin Group Numbers 8921001 JAN 89 A/T - Recommended Fluid 88-24-004 OCT 88 A/C - Odors 88-00-005 OCT 88 Tool - Multi-Use Tester Application Chart 88-21-024 OCT 88 Transmission - Identification Codes ATRATB889 FEB 88 A/T - Identification 8705005 DEC 87 Brakes - Proportioning Valve Precaution Update ATRATB8754 SEP 87 A/T - Front Bushing Wear ATRATB8748 AUG 87 A/T - Slipping or No-Shift/Metal Sealing Rings 8709008 MAY 87 Engine Main Bearing Cap Bolt - Torque Update 8714001 FEB 87 ECI - System Fundamentals 8621004 JUN 86 Clutch Release Cylinder - Repair Kit 8608001 FEB 86 Alternator - Damaged Harness Replacement 8514008 NOV 85 Engine - Sag or Bucking Condition 8503001 OCT 85 Differential Drive Pinion Bearing - New 8509011 OCT 85 Exhaust Manifold - Replacement 8519006 OCT 85 Power Steering - Flow Control Spring Service Standard 8505002 AUG 85 Brakes - Push Rod Clearance Specifications 8509009 JUL 85 Engine - Cylinder Block Distortion Limit Specification 8500002 JUN 85 Crankcase - Drain Plug Gasket 8509006 APR 85 Turbocharger - Installation of Water Cooled Unit 85-24-001 FEB 85 Water Temperature Switch - Torque Specification 8400002 NOV 84 Automatic Transmission - Fluid Recommendations 8408006 OCT 84 Battery - Charging Procedures 8414016 SEP 84 Fuel Injector - Identification 8421010 SEP 84 M/T - Synchronizer Modifications 8424003 AUG 84 A/C - Adding Refrigerant Oil 8423002 AUG 84 Window Shade Kit - Repairs 8414014 JUL 84 ECI System - Voltmeter Check Procedure 8409005 JUL 84 Engine - Oil Jet Assemblies in Turbo Short Blocks 8421004 JUL 84 Transmission Deceleration Sound 8414011 JUL 84 Turbocharger - Oil Feed Pipe Parts Available 8408004 JUN 84 Audio - (Rx-390 Radio) Digital Volume Control 8414015 JUN 84 Carburetor Choke Warmer - Coolant Hose Cup Installation 8414013 JUN 84 ECI - Self-Diagnosis/Test Connector Location 8408005 JUN 84 Fog/Passing Light - Aiming 8408001 JUN 84 Headlamp Linkage - Service Procedures 8421001 MAY 84 A/T - Service Manual Supplement Update 8414010 MAY 84 Turbocharger - Component Availability/Replacement 8414007 APR 84 ECI Checker & FBC Harness - Connector Modification 8409001 MAR 84 Engine - Jet Valve Clearance Change 8400001 MAR 84 Limited-Slip Differential - Lubricant Recommendations 8424001 FEB 84 A/C - System Update, Manual Revisions 8414003 FEB 84 Accelerator Cable - Adjusting Nut Torque Specification 8407001 FEB 84 Radiator - Pressure Test Adapter 8423001 JAN 84 Body - Electric Welding Precaution 8325007 DEC 83 49 State RE-Designed High-Altitude Areas 8308016 DEC 83 Audible Warning System - Service Manual Changes 8324005 DEC 83 Automatic A/C - Service Manual Update 8300008 DEC 83 Curb Idle Speed - Specification Tolerance 8314008 DEC 83 ECI System - Diagnosis Update 8308014 DEC 83 Electrical System - Manual Revisions 83-14-009 DEC 83 ISC Motor and TPS - Adjustment 8308011 DEC 83 Navigation System - Manual Updates 8323021 DEC 83 Paint - Codes/Cross Reference Index 8323017 NOV 83 Antenna - Hole Template 8323020 NOV 83 Paint - Color Codes 8323018 NOV 83 Urethane Bumpers - Painting Process Link to comment Share on other sites More sharing options...
Guest Paul87Quest Posted November 25, 2002 Report Share Posted November 25, 2002 Bulletins for 1983 Mitsubishi Starion L4-2555cc 2.6L SOHC Turbo General Recalls TSB Number  Issue Date  TSB Title 83E26L     MAR 83    Campaign - Cam Bore Plug Sealing Service Bulletins TSB Number  Issue Date  TSB Title 99-23-011    OCT 99    A/T Oil Cooler - Backflush Alternative 99-31-004    OCT 99    Wheel - Balancing Accuracy Tips 99-11-006    JUN 99    Engine - Valve Lash Adjuster Cleaning Procedure 99-00-002    FEB 99    Sealant/Adhesive/Chemical - Interchange Information 98-42A-008   OCT 98    Remote Keyless Entry - Update 98-00-00A    SEP 98    Fluids, Refrigerants and Materials (Genuine Mitsubishi) 99-00-001    JUN 98    VIN - Decoding Information 98-23-004    APR 98    A/T - Perform Cooler Flow Test When Replacing A/T 98-54-001    FEB 98    Audio System - Diagnosis 97-35-004    SEP 97    Brakes - Judder (vibration) Diagnosis and Repair 97-42A-012   SEP 97    Interior - Buzz, Squeak, and Rattle Kit 97-42A-001   FEB 97    Interior - Wind Noise Diagnosis 96-35-009    SEP 96    Antilock Brake System - Diagnosis 96-11-009    SEP 96    Piston Pin - Installation Tool Instructions 96-42A-015   JUL 96    Synthetic Resin Parts - Heat Resistance Specifications 96-55-006    MAY 96    A/C Refrigerant - Service Information 96-42A-007   MAR 96    Window - Chemical Film Build-Up/Fogging 95-16-003    NOV 95    Spark Plug - Fouling 95-54-001    OCT 95    Rear Window Defogger Grid - Repair 9455001     JUN 94    A/C - System Leak Checking 9355006     DEC 93    A/C - Refrigerant Temperature Switch Manual Correction 9355001     JUN 93    A/C - Odor Correction 9322001     APR 93    M/T - Fluid Recommendation/Caution 9321001     APR 93    M/T - Flywheel Surfacing Limit 9317001     FEB 93    Emission - Control Information Label Ordering 9235008     DEC 92    Brakes - Rotor Service Procedures 9200010     DEC 92    VIN - Replacement Plate/Label 9213010     NOV 92    Chemicals - Fuel Injector Cleaner Feels 1/2 Full 9231001     NOV 92    Wheels - Lug Nut Torque Information and Chart 9200003     AUG 92    Engine Controls - Never Use a Test Light To Check an ECM 9200005     AUG 92    VIN - Master Decoder Information 9251001     MAY 92    Paint - Damage Identification and Repair 9235003     MAR 92    Brakes - Pad Installation Service Points 9200001     JAN 92    Tools - Fault Codes When Using the Multi-Use Tester ATRATB078    NOV 91    A/T - How To Use A Pressure Gauge 91-00-015    OCT 91    Tools - Multi-Use Tester Warranty 9111010     JUL 91    Engine - Piston Pin Installation Tool 91-00-011    JUL 91    Tools - Multi-Use Tester ROM Pack Usage 9111009     MAY 91    Engine - Automatic Valve Lash Adjuster Noise 9117002     MAR 91    Emissions - Correct Diagnosis of Emission Control Parts 9100004     MAR 91    Tools -  Multi-Use Tester ROM Pack Usage 9155003     FEB 91    A/C - Refrigeration Oil Specification ATRATB028    OCT 90    A/T - Engine Vacuum Testing 9016001     OCT 90    Battery - Care During Long Term Storage 9011007     OCT 90    Tools - Piston Pin Tool Operating Instructions 9054011     OCT 90    Windows - Repair of Rear Defogger Grid 9000001     SEP 90    VIN - Codes 9054003     MAR 90    Audio - Speaker Troubleshooting Manual Supplement 9027002     MAR 90    Drivetrain - Click, Snap or Clunking Noise From Rear 9011002     MAR 90    Timing Chain & Tensioner Spring - Parts Available 9055001     FEB 90    A/C - Handling Precautions For Freon R-12 ATRATB9002006  FEB 90    A/T - Choosing the Right ATF 9042B001    JAN 90    Windshield - Installation Instructions 8952002     NOV 89    Seat Belt - Rear Shoulder Belt Installation ATRATB8930   OCT 89    A/T - Math Part II 8911004     OCT 89    Silent Shaft Chain Tensioner Bolt - Torque Update ATRATB8927   SEP 89    A/T - Twenty Steps To Successful Repairs ATRATB8923   AUG 89    A/T - Math Formulas Part I 8900002     JUN 89    Multi Use Tester - Warranty 8900001     JUN 89    New Service Bulletin Group Numbers 8921001     JAN 89    A/T - Recommended Fluid Link to comment Share on other sites More sharing options...
Guest Paul87Quest Posted November 25, 2002 Report Share Posted November 25, 2002 Bulletins for 1983 Mitsubishi Starion L4-2555cc 2.6L SOHC Turbo (CONT) 88-24-004 OCT 88 A/C - Odors 88-00-005 OCT 88 Tool - Multi-Use Tester Application Chart 88-21-024 OCT 88 Transmission - Identification Codes ATRATB889 FEB 88 A/T - Identification 8705005 DEC 87 Brakes - Proportioning Valve Precaution Update ATRATB8754 SEP 87 A/T - Front Bushing Wear ATRATB8748 AUG 87 A/T - Slipping or No-Shift/Metal Sealing Rings 8621004 JUN 86 Clutch Release Cylinder - Repair Kit 8608001 FEB 86 Alternator - Damaged Harness Replacement 8509011 OCT 85 Exhaust Manifold - Replacement 8505002 AUG 85 Brakes - Push Rod Clearance Specifications 8509009 JUL 85 Engine - Cylinder Block Distortion Limit Specification 8500002 JUN 85 Crankcase - Drain Plug Gasket 8509006 APR 85 Turbocharger - Installation of Water Cooled Unit 85-24-001 FEB 85 Water Temperature Switch - Torque Specification 8400002 NOV 84 Automatic Transmission - Fluid Recommendations 8424003 AUG 84 A/C - Adding Refrigerant Oil 8423005 AUG 84 Door Glass - Scratches 8423002 AUG 84 Window Shade Kit - Repairs 8414014 JUL 84 ECI System - Voltmeter Check Procedure 8409005 JUL 84 Engine - Oil Jet Assemblies in Turbo Short Blocks 8421004 JUL 84 Transmission Deceleration Sound 8414011 JUL 84 Turbocharger - Oil Feed Pipe Parts Available 8408001 JUN 84 Headlamp Linkage - Service Procedures 8414010 MAY 84 Turbocharger - Component Availability/Replacement 8409001 MAR 84 Engine - Jet Valve Clearance Change 8414003 FEB 84 Accelerator Cable - Adjusting Nut Torque Specification 8314006 NOV 83 Propane-Assisted Idle - Adjustment 8323013 NOV 83 Roof-Mounted Antenna - Hole Template 8323018 NOV 83 Urethane Bumpers - Painting Process 8306003 OCT 83 Clutch Pedal - Engagement Point Adjustment 8314011 OCT 83 Engine - Stumble/Low Power/Black Smoke 8319001 OCT 83 Steering Wheel - Off Center Diagnosis 8309004 OCT 83 Turbocharger - Oil Pipe Leakage 8308013 OCT 83 Wiring Diagrams - Service Manual Corrections 8305002 AUG 83 Modulator - Rear Brake Lock-Up Control System 8300007 JUL 83 3M Lubricants, Sealers, Cleaners Etc. 8323006 JUL 83 Door Glass - Adjustment and Guide 8309003 JUL 83 Exhaust - Noises When Cold 8321006 JUL 83 M/T - Repair Procedure Updates 8323010 JUL 83 Paint - Overspray On Body Surfaces 8308012 JUL 83 Rear Window Defogger - Repair 8306002 APR 83 Clutch Pedal - Height Specification Change 8308003R APR 83 Communications Devices - Installation Precautions 8308006 APR 83 Cruise Control - Updates 8314003 APR 83 ECI System - Manual Update 8323004 MAR 83 Instrument Pad - Mounting Points 8324001 MAR 83 Pusher Fan For A/C Condenser - Manual Update 8308004 MAR 83 Speedometer/Cable - Chattering/Noisy 8324002 MAR 83 Ventilation System - Cannot Be Regulated With Lever 8302001 FEB 83 Front Cross Member - Removal 0082003 DEC 82 LS Differential - Oil/Lubrication Recommendations 0682001 DEC 82 M/T Clutch - Judder 23-82-003 NOV 82 Paint Codes - Applications and Cross Reference 0882002 NOV 82 Rear Wiper/Defogger - Inoperative 23-82-002 NOV 82 Scuff Plate - Deformation/Overlap 0882001 NOV 82 Spark Plug Cable - Proper Routing 008202 OCT 82 Brakes/AT - Fluid Recommendations Link to comment Share on other sites More sharing options...
Guest Paul87Quest Posted November 28, 2002 Report Share Posted November 28, 2002 TSB NO. Â Â ISSUE DATE Â Â Â YEARS EFFECTED SC89001 Â Â Â Â NOV 89 Â Â Â Â Â 1988-1989 CAMPAIGN- New Connecting Rod Bearing SUMMARY: Materials in the connecting rod bearing have been changed from an alluminum alloy to a new copper/lead alloy. Effects Starions produced between July 1987 and March 1989. This change is due to the these years having an increase in horsepower. The aluminum bearings are still acceptable for the Montero and pick-up truck. * No mention in the TSB about incorrect installation from factory or problems as a result of these aluminum bearings...just that the copper/lead alloy is more durable. * Link to comment Share on other sites More sharing options...
Metric-man Posted January 9, 2003 Report Share Posted January 9, 2003 NA Link to comment Share on other sites More sharing options...
Tim_C. Posted November 24, 2003 Report Share Posted November 24, 2003 Well, I have always been able to see the TSB's & Recalls on ALLDATA. They are all listed, for each year, etc... I just can't transfer them in a readable format, digitally. I would need to copy them, and someone could scan them. We are switching to Mitchell I believe soon, but they will have it too. Mitchell is a little better organized it seems. Most of the mechanics we have talked to, like Mitchell better. Let me know if a hardcopy of the TSB's would help? Link to comment Share on other sites More sharing options...
