Yellow 4g63
Started by cheesey, Nov 22 2018 09:55 PM
105 replies to this topic
#101
Posted 09 January 2021 - 06:34 AM
I then fixed the crack and welded in a gusset for added strength.
#102
Posted 09 January 2021 - 06:38 AM
Another issue is that my car was originally an auto. When I did the 5 speed swap I didn't have the tools or skill to weld in the upper support for the clutch pedal bracket that's under the dash. I also don't fit under there and didn't want to burn up anything while welding. So i came up with a compromise. Hopefully this gives it some support and prevents it from cracking again.
Edited by cheesey, 09 January 2021 - 06:39 AM.
#103
Posted 09 January 2021 - 06:43 AM
Since my valve cover is a shaved one I decided to try out a mitsu spark plug cover. I painted it but I don't have the steadiest of hands.
#104
Posted 09 January 2021 - 06:45 AM
I also built a radiator cover out of some plastic from Menard's. Hopefully a cheap lightweight solution that wont melt.
#105
Posted 09 January 2021 - 06:50 AM
After the pedal was fixed and clutch master was swapped car shifted normally! So next on the list is to re-build the power steering pump. It has a slight leak. And to re-do the turbo oil drain line. I forgot to put thread sealant on the bolts for the flange going into the oil pan. I also have to polish up a set of SHP rims. Hopping to run 9's on all corners. Seems like tire choices for that size rim are dwindling.
Edited by cheesey, 09 January 2021 - 06:51 AM.
#106
Posted 09 January 2021 - 09:08 AM
Looks awesome! What paint did you use for the cover trim?
Edited by Turbo Cary, 09 January 2021 - 09:09 AM.
