tux Posted January 29, 2022 Report Share Posted January 29, 2022 (edited) Anyone have any tips for pulling the rear LCA bolts out? Trying to change the bushes. I already removed the 12mm small bolt and tried heat, loads of pb blaster, a dead blow hammer, but i can't get that bolt to budge. Any other tips before i try an air hammer or just cut it out and hope i can find replacement bolts? Edited January 29, 2022 by tux Link to comment Share on other sites More sharing options...
Caliber308 Posted January 29, 2022 Report Share Posted January 29, 2022 I've never done this but I have read in Professor Quests S.O.S. manuals that the 8" bolt has a notch in it for a thru bolt. Hope this helps. Good Luck, Bill Link to comment Share on other sites More sharing options...
tux Posted January 29, 2022 Author Report Share Posted January 29, 2022 I got that little bolt out, but she's seized in there good. I need to reuse the sleeves for the new bushings so i want to avoid cutting. Not sure where I'd get the sleeves. Link to comment Share on other sites More sharing options...
Caliber308 Posted January 29, 2022 Report Share Posted January 29, 2022 (edited) P.Q. Also said that the bolt was a P.I.T.A. to get out because of rust but it could be done. Spray Blaster in the hole where you removed the thru bolt and let it sit ,don't be in a hurry. If it doesn't come loose, try it again with Blaster. Also the FSM says to make sure that the mark on the end of the bolt is pointing down, most likely for reassembly. Bill Edited January 29, 2022 by Caliber308 Link to comment Share on other sites More sharing options...
tux Posted January 29, 2022 Author Report Share Posted January 29, 2022 Thanks. i saw the notes in manual. And my bushing kit came with similar instructions about spraying in the hole. Been at it on and off for 3 days. Definitely not in a rush. But also not sure it's going to free itself ever. Link to comment Share on other sites More sharing options...
Caliber308 Posted January 29, 2022 Report Share Posted January 29, 2022 (edited) DON'T CUT THE BOLT!!!!! NLA from Japan. P.Q. Said that you could put a little heat to it. Depending on the size of the bolt as a last resort, you might be able to cut a similar notch in another bolt of the same size. After all, we will all be doing things like that when we run out of spare parts and it seems like that time is coming sooner than later. Bill Edited January 29, 2022 by Caliber308 Link to comment Share on other sites More sharing options...
Turbo Cary Posted January 29, 2022 Report Share Posted January 29, 2022 Use a map gas torch to heat the knuckle up. Get it good and hot then try spinning the bolt in the knuckle. But be careful about it possibly snapping. I would spray it with PB blaster and allow to soak for a day or so before attempting Link to comment Share on other sites More sharing options...
obsolete Posted January 29, 2022 Report Share Posted January 29, 2022 FYI, if worse comes to worst, Mookeeh is selling replacement bolts: https://www.ebay.com/itm/253042348223 Link to comment Share on other sites More sharing options...
tux Posted January 29, 2022 Author Report Share Posted January 29, 2022 Yeah i was debating buying that when i bought my bushings 😕 Was hoping not to. Link to comment Share on other sites More sharing options...
tux Posted January 29, 2022 Author Report Share Posted January 29, 2022 I'm going to buy and attempt to use one of those induction heat things. Getting nowhere with map gas and pb blaster. If not cutting is next. Link to comment Share on other sites More sharing options...
Turbo Cary Posted January 30, 2022 Report Share Posted January 30, 2022 3 hours ago, tux said: I'm going to buy and attempt to use one of those induction heat things. Getting nowhere with map gas and pb blaster. If not cutting is next. I have used one of those before and they work amazing! Literally in 5 seconds the nut was glowing red and came right off. That was used to take a catalytic converter bolt off a 5.3 GM engine. I think if you did that in stages from one end of the hub to the other and tried to move the bolt it would work. Link to comment Share on other sites More sharing options...
tux Posted January 30, 2022 Author Report Share Posted January 30, 2022 That's the hope. It comes with some make your own loops cable so i will try to wrap it around the hub. Figured worth a try. A 300$ try, but a try none the less Link to comment Share on other sites More sharing options...
tux Posted February 2, 2022 Author Report Share Posted February 2, 2022 First inductive heater arrived non-working. Will update when a new one comes and if it works. Might help other people if it does work. Link to comment Share on other sites More sharing options...
tux Posted February 12, 2022 Author Report Share Posted February 12, 2022 I got my new inductor and a flexible piece of wire for it and wrapped around the LCA where the bolt is. Couldn't get much over 330 degrees f. Not enough heat to may any difference it seems. Might be cutting them bolts out. Link to comment Share on other sites More sharing options...
tux Posted February 14, 2022 Author Report Share Posted February 14, 2022 Got them out. Needed to get it up to 330, then hit with impact, then air hammer. Rinse and repeat. Came right out Link to comment Share on other sites More sharing options...
obsolete Posted February 14, 2022 Report Share Posted February 14, 2022 Very nice! Congrats. Link to comment Share on other sites More sharing options...
tux Posted February 14, 2022 Author Report Share Posted February 14, 2022 So for this job, I would recommend buying an inductor and the 96" length of flexible wire called "bearing buddy" and also buying a long throw air hammer. Link to comment Share on other sites More sharing options...
psu_Crash Posted February 14, 2022 Report Share Posted February 14, 2022 Congrats Tux! You are far more patient than I. When mine wouldn't come out the BFH had a different idea. Luckily a member hooked me up with new bolts back then. (Thanks Jimmy!) Link to comment Share on other sites More sharing options...
