forcedairtsi Posted August 4, 2007 Report Share Posted August 4, 2007 My buddy gave me a brand new turbo. I'm just not so sure about it because of its size. Its a garrett A/R .70 m43 7129-3 r ?...I can't find any nfo out on it I am just wondering if some of you turbo heads can help. What is this? I'm not too turbo friendly so please forgive me....Thanks for the help... He gave me a custom welded down pipe and everything.... Link to comment Share on other sites More sharing options...
Truth Posted August 4, 2007 Report Share Posted August 4, 2007 you must have good friends Link to comment Share on other sites More sharing options...
Hit_N_Run-player Posted August 4, 2007 Report Share Posted August 4, 2007 get pics. m43 is the casting. If you post a pic most we'll tell you what it is. Link to comment Share on other sites More sharing options...
forcedairtsi Posted August 5, 2007 Author Report Share Posted August 5, 2007 I will try to post the pictures...I have it unbolted from the down pipe that was custom welded together.. Oh yeah its brand new...never spooled..http://i193.photobucket.com/albums/z222/bimmer_addict/turbo01.jpghttp://i193.photobucket.com/albums/z222/bimmer_addict/turbo02.jpghttp://i193.photobucket.com/albums/z222/bimmer_addict/turbo03.jpg[/img] Link to comment Share on other sites More sharing options...
michigidi Posted December 28, 2007 Report Share Posted December 28, 2007 That looks like a big turbo. T4 exhaust housing maybe? That's a pretty big exhaust wheel. It could be the closeup to . A/R is also big. This means slow spool (turbo lag), but great topend. For the starion motor w/turbo only I'd go with a 50 ish. a/r. Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted December 28, 2007 Report Share Posted December 28, 2007 I wouldn't worry about it too much. We can spool large turbos just fine due to the large displacement and long stroke. You just have to match it right while knowing the flow limitations of the stock head. Can't try an spool a larger compressor wheel as fast as a smaller one and not expect to get choked up. A .70 on the cold side(assuming that's what you meant, based on the original info) would be fine depending on what you want the car to perform like.. Auto-X type racing, not a chance.. LOL Top end highway runs, dragstrip use.. Sure. The stock TD05 turbine housing roughly translates to a 0.57 A/R, although i'm not sure what the compressor housing size is. Mike K posted this info years ago about his setup(built block, ported head, Tim C cam, mpi, tubular header etc.. T04B .60 A/R 60-1 with a split tang .70 hotside O trim. 2900 - 10 psi 3100 - 13 psi 3500 - 18psi I say .58 - .70 is your optimal hot side A/R. Also I feel an O trim T4 trim to be a very good trim in a .70 A/R hotside. I wouldn't consider that much lag at all. Eeaston had this to say about a larger A/R..I run a stage 5 T-3 turbine with a .86 AR and it is a little slow on the uptake. I hit about 10 PSI by around 3000 RPMs. After that it takes off and hits 17 a few hundred later. That's also a T3, not a T4 so it'll be different. But then again, it's a stg 5. Link to comment Share on other sites More sharing options...
CaliConquestAlex Posted December 29, 2007 Report Share Posted December 29, 2007 If you don't want it let me know. I'm in the market for a new turbo with a stage 5 turbine. Link to comment Share on other sites More sharing options...
