Intermittant crank no start
m2552135
Hey all,
Got an 86ESI R that gave me a crank/no start the other day, Car was running fine, stopped somewhere about 10 minutes and no start, called for some help withcranking to see if it had lost spark or fuel but by the time help arrived it started right up
Any suggestions, I can't remember how to pull codes from this car (I worked as a Mitsu Tech from 86-89)
Any help would be appreciated
Dirty ECI fuse link
Dirty injectors that drip and spray poorly and foul plugs
Wrong spark plugs
CTS incorrectly replaced with a Temp. gauge unit. or plugged in wrong
Dirty injector clips
Dying fuel pump
Dying ignitor
http://www.b2600turbo.com/images/ECICTS.jpg
Could be any of those or a combination but 1st I'd say the injectors need removed and professionally cleaned, the clips replaced and the rotten wire cut from the ends of the harness they are attached to. The ECI fuse link cleaned and the connector where the pigtail from the fuse link holder attaches to the harness and order a set of NGK 7031 spark plugs.
Could also run rich from the pressure sensor and the solenoid beside of it hooked up wrong. The ports on it are, right side goes to the TB at a port towards the back of those 3 in a row and slightly up, the T'd branch goes to the pressure sensor and the one from the left goes around to the air filter can and shouldn't be hanging in the breeze and whatever you do, don't cap it.
