Conquest project
74 replies to this topic
#41 importwarrior
  • 18,269 posts
Posted 16 April 2015 - 05:15 AM
looks proper
http://www.autozone....ch&fromType=oem
for about $$65 and some time you can rebuild your own.
www.rockauto.com
GATES Part # 349400
how to rebuild steering box
http://www.starquest...howtopic=127385
hope that helps
#42 lgarbz
lgarbz
  • 102 posts
Posted 16 April 2015 - 08:46 PM
Thanks man. Also need some help with my hvac system. I'm going to start a new thread for that. It wouldnt let me post in the HVAC forum, so I put it here.
http://www.starquest...howtopic=147264
Thanks guys!
Booze and tattoos.
#43 pcristquester
pcristquester
  • 2,420 posts
Posted 16 April 2015 - 10:44 PM
Most of the time when asking for help with something, you should post it in the virtual mechanic section
#44 lgarbz
lgarbz
  • 102 posts
Posted 16 April 2015 - 10:46 PM
That's where I posted it. Thanks.
Booze and tattoos.
#45 lgarbz
lgarbz
  • 102 posts
Posted 16 April 2015 - 11:59 PM
View Postbha280, on 11 April 2015 - 09:04 AM, said:
I have all the A/C parts sitting in my garage if theres anything you need. Off to a good start on the body work.
Do you happen to have the AC compressor bolts?
Booze and tattoos.
#46 lgarbz
lgarbz
  • 102 posts
Posted 17 April 2015 - 11:06 PM
Got a little more accomplished. Started disconnecting the plumbing and removed the intercooler.
Turbo looks like it's in decent condition, no visible leaks.
A little gin and tonic to keep me motivated.
Started the body work with the driver fender.
That's pretty much all I had time for after work tonight.
Here's a quick video of start up/ walk around and my HVAC unit working.
https://youtu.be/9sl47pEO-mo
Booze and tattoos.
#47 lgarbz
lgarbz
  • 102 posts
Posted 17 April 2015 - 11:25 PM
In need of some turbo oil feed/return lines and coolant lines. Preferably braided hoses. Let me know if you have any you are willing to part with.
Booze and tattoos.
#48 MasterVivi
MasterVivi
  • 775 posts
  • Interests:Coffee, Conquests, Speed.
Posted 18 April 2015 - 03:59 AM
I think I have a braided turbo coolant or oil retur or feed line still. I'll check for you.
#49 '87quest
'87quest
  • 839 posts
Posted 18 April 2015 - 01:17 PM
Check with brianpaul98 he makes all those stainless braided lines and does top notch work.
#50 lgarbz
lgarbz
  • 102 posts
Posted 19 April 2015 - 01:04 AM
If you have some lemme know, I'll scoop them up from you.
And Thanks for the OVC pipe, I'm looking forward to throwing it on!
Booze and tattoos.
#51 lgarbz
lgarbz
  • 102 posts
Posted 19 April 2015 - 01:07 AM
Also another quick update. I fixed the whining noise from my steering gear box. Bled out the air with a mitvac pump and put in some Bar's power steering additive. Noise is completely gone. Saved me about $200 for a reman gearbox and/or hours of my time.
Booze and tattoos.
#52 randy
randy
  • 4,104 posts
Posted 19 April 2015 - 06:00 AM
that's coming along nicely.
#53 BuGG
BuGG
  • 1,963 posts
Posted 19 April 2015 - 08:15 AM
You mean Bar's auto tranny additive right.  These cars use ATF in the power steering.
Edited by BuGG, 19 April 2015 - 08:16 AM.
#54 lgarbz
lgarbz
  • 102 posts
Posted 19 April 2015 - 04:32 PM
No I just used power the power steering fluid repair stuff.
Booze and tattoos.
#55 lgarbz
lgarbz
  • 102 posts
Posted 19 April 2015 - 04:34 PM
Got some more sanding done on the hood.
Gonna start some of my vacuum deletes next weekend.
Got some vacuum line and connectors/plugs.
Booze and tattoos.
#56 importwarrior
  • 18,269 posts
Posted 19 April 2015 - 08:07 PM
Did you see the FAQ on the vac delete? See page 3 at the end.
Use ZIP ties if vac lines are not tight. Stock vac line ID is 3.2 mm
#57 lgarbz
lgarbz
  • 102 posts
Posted 19 April 2015 - 09:58 PM
Good to know, I'll check it out. Thanks,
Booze and tattoos.
#58 lgarbz
lgarbz
  • 102 posts
Posted 28 April 2015 - 09:37 PM
Started on my vacuum deletes. Cruise control is gone. Ordered a block off plate for the EGR. Also ordered a braided hose and adapter to do away with the ABS. Should have some pictures up this weekend.
Booze and tattoos.
#59 lgarbz
lgarbz
  • 102 posts
Posted 02 May 2015 - 09:36 PM
Got some good work done today. ABS delete, Started EGR delete, Installed braided coolant hose, removed exhaust system. I'm gonna have a shop in town build me a new exhaust system. Was thinking either 2.5" or 3", what do you guys think? Also found cracks in exhaust manifold (shocker). Removed turbo, removed exhaust manifold. Gonna weld the cracks. Is there a good way to stress relieve the manifolds? Also some idiot put silicone on the manifold, and most of the buts/bolts I've removed were only finger tight.....
Booze and tattoos.
#60 lgarbz
lgarbz
  • 102 posts
Posted 02 May 2015 - 09:42 PM
Also, thanks brianpaul98 for the braided line!
Booze and tattoos.
