So what NGK wires replaced the 8079?
7 replies to this topic
#1 Preludedude
Preludedude
  • 3,144 posts
Posted 23 September 2019 - 06:12 PM
I see the 8079 Wires are discontinued....I think the 9012 Wires were also....
What is the next best plug wire for these cars?
Edited by Preludedude, 23 September 2019 - 08:55 PM.
#2 ucw458
ucw458
  • 11,636 posts
Posted 23 September 2019 - 10:07 PM
I run cut to fit MSD wires.  A V8 kit gives you x2 sets.
But a better thing to do is protect the wires from turbo heat so they last 10x longer.  Get some fiberglass boots that go on the plug end of the wire like these.
And get some spark plug wire insulation like this and slide it onto the wire.
http://www.summitrac...VBoCtvwQAvD_BwE
My 87
#3 TexasQuest
  • 9,000 posts
Posted 24 September 2019 - 12:05 PM
2.6L Montero NGK plug wires are still available. Part# 53003
Edited by TexasQuest, 24 September 2019 - 12:08 PM.
88 Fiji Blue -TSi
#4 Preludedude
Preludedude
  • 3,144 posts
Posted 24 September 2019 - 12:44 PM
Good Info.   Thank you!
Those NGK 53003 wires are $15.74 on RockAuto. May buy some to stock up on....
I will be trying some Taylor 87030 for $48 on Summit....
I've read good things about them on this forum...
My NGK 8079 #4 wire just got chewed up on water pump pulley while idling....
Edited by Preludedude, 24 September 2019 - 12:55 PM.
#5 Rapom
Rapom
  • 110 posts
Posted 26 September 2019 - 07:32 PM
Im running the red Taylors... love the look.. they run with no issues B U T i must warn you. If you have to remove them from the plugs at any point you may get got. 3 of my 4 tore leaving the metal stuck to the plug! And i used plug grease. I fixed them like you would a universal set.. but still.. wth
#6 Jay40245
Jay40245
  • 212 posts
  • Interests:cars
Posted 10 October 2019 - 11:08 PM
I was just about to get some Taylor wires since they worked so well on my typhoon, but the experience you have had gives me pause.
#7 psu_Crash
psu_Crash
  • 7,219 posts
Posted 11 October 2019 - 05:38 PM
If you use a spark plug boot plier, you won't have that issue
https://shop.advance...uQaApSWEALw_wcB
Edited by psu_Crash, 11 October 2019 - 05:40 PM.
The Valencia Project
My Feedback Link
#8 Turbo Cary
Turbo Cary
  • 1,766 posts
Posted 19 October 2019 - 06:06 AM
Buying those DEI spark plug heat protector boots makes a big difference. I cooked a set of wires in 10k miles before installing those on my new set. They lasted much longer.
https://www.amazon.c...la-744381733611
