My JDM GSR-VR MPI build thread.
38 replies to this topic
#21 importwarrior
  • 17,589 posts
Posted 29 July 2017 - 10:20 AM
I had a problem with my studs backing out. Not the nut.
I had to use some high temp thread locker. Good to 2100 degree.
#22 Woody
Woody
  • 324 posts
  • Interests:Starions
Posted 30 July 2017 - 06:50 PM
Tightened the turbo nut and removed the tbi intake. The nut was extremely difficult to get tight. Test fitted the MPI intake and the top half hits against the abs unit. I need to get the temp sensors screwed into the new intake. Hoping to have it all mostly done by next weekend except for the fuel lines and wiring.
Intake is off! Anyone wanting to buy it or it's injectors, let me know.
Test fit the lower intake. It's snug but fits. Have to grind off a small part of the water outlet so the dizzy will fit.
But unfortunately the upper intake housing hits the ABS brakes. Time for it to go.
And gone! Now to just re-route that one brake line and bleed it.
www.sweetfrostings.com.au
#23 BuGG
BuGG
  • 1,767 posts
Posted 30 July 2017 - 07:34 PM
Is that a boost gauge fitting on your brake booster line?
#24 Woody
Woody
  • 324 posts
Posted 31 July 2017 - 02:14 AM
Yes, which I am most certainly moving! It shouldn't be there at all.
#25 Fuze
Fuze
    AKA #Battlemagnet
  • 2,530 posts
  • Interests:Chess Boxing
Posted 02 August 2017 - 08:44 AM
Weird! ABS unit on the intake side..?
Insta = @battlemagnet
#26 88351wtsi
88351wtsi
  • 938 posts
  • Interests:My kids, music, and cars, not always in that order.
Posted 02 August 2017 - 04:20 PM
It's gotta be a right hand drive so brake booster is where the Abs unit would be on ours here in the States
1988 Conquests
His:  Durban maroon with 351w
#27 TexasQuest
  • 8,337 posts
Posted 02 August 2017 - 10:17 PM
GSR-VR is a JDM model so everything is flip-flopped on the firewall.
88 Fiji Blue -Tsi
Zoom clutch, Fidanza flywheel, Stedebani shifter, KYB's, ST springs, ST swaybars, abs delete, a/c delete, cruise delete, JVE, BSEK, TEP steel brake lines, LSP braided cooler lines, CX Racing radiator,  MK1 silicone hoses, MK1 pullies, *DM hard pipes & intercooler,14G turbo, ported exh. manifold, MAF Translator, 3.5" GM maf, Turbo XS RFL bov, *DM 3" exhaust, Cusco front strut bar, TEP rear strut bar, Enkei 92's, HKS turbo timer, AEM wideband, AEM boost gauge, AEM oil pressure gauge, Hallman boost controller
#28 Woody
Woody
  • 324 posts
Posted 03 August 2017 - 01:03 AM
Exactly. This is in Australia with the JDM version from Japan because we didn't get Widebodies over here.
#29 Fuze
Fuze
    AKA #Battlemagnet
  • 2,530 posts
Posted 03 August 2017 - 06:59 AM
Yeah I figured, just looks so strange. Not often I look under a Starion hood and see something surprising lol. Now I'm noticing all the little stuff like the wiper motor and VIN plate.
#30 Woody
Woody
  • 324 posts
Posted 19 August 2017 - 02:10 AM
Need injector wiring help.
I have a Haltech ECU. Do I wire up Injector 1,2,3,4 to be wired up in the same order as the firing order?
Thanks.
#31 Woody
Woody
  • 324 posts
Posted 25 August 2017 - 02:10 AM
Used the pipe bender to re-route the brake line. It's not the neatest but it was extremely annoying to use.
Spent some time last night wiring up an injector wiring hardness for the intake. Now to wire up some plugs onto the actual car loom.
Look what turned up today :) My new set of D2 coilovers. Can't wait to swap these in. But I'm holding off until the car is running again.
I've also hooked up the FPR and new fuel line in, but no photos of that yet.
#32 importwarrior
  • 17,589 posts
Posted 25 August 2017 - 05:17 AM
Very nice D2's. so you did the ABS delete? your car looks all backwards to me LOL.
#33 Woody
Woody
  • 324 posts
Posted 25 August 2017 - 05:13 PM
Yep I did the ABS delete. I couldn't get the intake and fuel rail in with it there.
#34 Woody
Woody
  • 324 posts
Posted 29 August 2017 - 05:31 AM
Decided to bolt up the lower half of the manifold and ran into some issues. I need to fix this water hose that is hitting the fuel rail. Thanks to Anthony for offering a suggestion on how to fix it.
I also sat the top half on to see how it looks.
#35 Woody
Woody
  • 324 posts
Posted 07 September 2017 - 04:37 PM
Car went in to get the Intercooler mounted and piping made up. Until then, just a photo from a few months ago to keep the thread going :)
#36 GSRVR
GSRVR
  • 103 posts
Posted 08 September 2017 - 05:59 AM
 Woody, on 07 September 2017 - 04:37 PM, said:
Great shot. Looking very sleek mate, black beauty!
Mitsubishi Starion GSR-VR |2016-Present|
#37 Turbo Cary
Turbo Cary
  • 1,379 posts
Posted 13 September 2017 - 08:14 PM
Thanks.
The injectors do not need to be wired up for a firing order. But they need to go to the correct injector. With the ECU Manager haltech software you set the firing order there.
I have a tune from my friends Conquest that ran on a Haltech Sprint series. If you are using a Sprint series ecu it should give you a decent starting point. If you are using the Elite series I dont know if it would convert over however you could manually input the ignition timing map and injector scale to be able to fire it up.
Also make sure they are High impedance injectors. I know the Sprint series requires it unless you wire in a resistor box. Not sure about the Elite series in terms of requirements.
#38 Woody
Woody
  • 324 posts
Posted 14 September 2017 - 09:21 PM
Here are some work in progress images. Unfortunately the intercooler I bought was too big to fit between the Chassis rails by 7cm. So damn close. So I had to buy another smaller one and wait for it to arrive. But now it's here it's getting the fabrication work done.
#39 Woody
Woody
  • 324 posts
Posted 17 September 2017 - 11:30 PM
A few more pictures of the completed piping and mount. I will share a picture of it with the bar back on tomorrow.
