Megasquirt Dash, using Raspberry Pi 3 B+
26 replies to this topic
#1 importwarrior
  • 18,212 posts
Posted 19 July 2018 - 05:25 AM
Megasquirt Tuner studios Dash, using Raspberry Pi 3 B+
There are many other methods to do this this is just one I liked.
The kit I got $72.00 no display:
https://www.amazon.c... 3 kit keyboard
It is best to get a case with a fan.
https://www.amazon.c...a Case with fan
Assembly process
https://youtu.be/lmuFMWbN9Ck
Part 1
PI Dash Setup: Part 1 Overview and Hardware
#2 importwarrior
  • 18,212 posts
Posted 19 July 2018 - 05:26 AM
Part 2
PI Dash Setup: Part 2 NOOBS Install and Basic Config
Part 3
PI Dash Setup: Part 3 Setup TunerStudio and Autostart
#3 jmactenn
jmactenn
  • 613 posts
Posted 19 July 2018 - 08:00 AM
You mean like this?  I used the same tutorial. Don't forget to get the car power switch to prevent damage to the pi when shutting off the car
https://mausberry-ci...supply-switch-1
Edited by jmactenn, 19 July 2018 - 08:06 AM.
88 front
#4 speedyquest
speedyquest
  • 4,043 posts
Posted 19 July 2018 - 08:52 AM
Awesome dude, if you have any linux specific questions feel free to ask. I don't have any Pi specific knowledge though. I do want to pick one up and learn about it though.
#5 jmactenn
jmactenn
  • 613 posts
Posted 19 July 2018 - 09:23 AM
I was a UNIX Systems and Networks admin in the nuclear power industry for almost 20 years.
88 front
#6 importwarrior
  • 18,212 posts
Posted 19 July 2018 - 10:11 AM
Tuner Studio Gas Gauge
https://www.youtube....h?v=j79OBLcsbqg
#7 speedyquest
speedyquest
  • 4,043 posts
Posted 19 July 2018 - 10:43 AM
My comment was mostly directed towards importwarrior but I'd gladly help anyone. If your knowledgeable about Linux then awesome :)
As for the gas level gauge you can easily use the stock sensor too, just find out its ohm range and use that to tell your dash what is full vs empty.
Edited by speedyquest, 19 July 2018 - 10:45 AM.
#8 psu_Crash
psu_Crash
  • 7,083 posts
Posted 19 July 2018 - 11:07 AM
I've wanted to do this for YEARS!
Then I get distracted, busy, broken ... etc etc ...
IW
What display did you buy?
Edited by psu_Crash, 19 July 2018 - 11:11 AM.
My Feedback Link
#9 importwarrior
  • 18,212 posts
Posted 19 July 2018 - 11:14 AM
Info provided by:
jmactenn
Fuel level sender ohms:
empty to full
115-117 ohms, 0 ohms.
Every sender will have similar ohm reading they wont be 100% the same as stated above.
Always good to test it out to be sure. a good starting point though..
Thanks for the help!
I will be needing some help once I get the last few items.
#10 importwarrior
  • 18,212 posts
Posted 19 July 2018 - 11:25 AM
IW
Same as the one in the 1st video.
#11 croquest87
  • 1,371 posts
Posted 19 July 2018 - 11:42 AM
I really like this!
#12 jmactenn
jmactenn
  • 613 posts
Posted 19 July 2018 - 12:51 PM
Fuel gauge is autometer programmable. Used spare sending unit to calibrate it. AEM GPS speedometer, AEM wide band, autometer elec oil pressure.
88 front
#13 importwarrior
  • 18,212 posts
Posted 19 July 2018 - 08:01 PM
Tuner studio Dashboards.
https://tunerstudiodashboards.com/
http://tunerstudioda...dashboards.html
#14 jmactenn
jmactenn
  • 613 posts
Posted 20 July 2018 - 11:01 AM
Nice find...….
88 front
#15 psu_Crash
psu_Crash
  • 7,083 posts
Posted 20 July 2018 - 11:22 AM
If only tunerstudio would run on an android system, I'd already have my old nexus 7 re-purposed and mounted!
MSDroid is great, but it isn't TunerStudio
My Feedback Link
#16 importwarrior
  • 18,212 posts
Posted 20 July 2018 - 12:58 PM
how about shadow dash ???
http://www.tunerstud...x.php/downloads
made by tuner studios
#17 speedyquest
speedyquest
  • 4,043 posts
Posted 20 July 2018 - 02:24 PM
Honestly, porting the Linux version over to Android wouldn't be hard. It's the interface that would be difficult. Chances are thats why it isn't on Android.
#18 speedyquest
speedyquest
  • 4,043 posts
That being said, shadow dash running on an Android tablet is a very clean solution. You just can't tune on it.
#19 jmactenn
jmactenn
  • 613 posts
Posted 20 July 2018 - 02:48 PM
You can't tune in the Linux version either. You can switch tunes but that's about all.
88 front
#20 speedyquest
speedyquest
  • 4,043 posts
Posted 20 July 2018 - 02:52 PM
In the Linux version of tuner studio? If that's what you mean then I'm happy to say you can tune in it. That's what I'm using as I type this.
