EVO Front Macpherson Strut setup into Starion
Macpherson Strut EVO
23 replies to this topic
#1 TxStig
TxStig
  • 36 posts
Posted 02 July 2018 - 12:45 PM
This may be an already deemed to be too difficult endeavor but has anybody ever tried or know someone who has tried to use the Macpherson Strut setup from the EVO's in the front of the Starion. I like most am struggling to accept that the D2 Coilover solution is pretty much the only way for anybody wanting to upgrade to a "track" suspension. Most of the reviews I have read say that they are still probably a little too soft for the track.
Surely it would not be too much work to make brackets to make use of an EVO upright. Hubs are pretty common it doesn't have to have to have a drive spline internally. Then at least struts that bolt on instead of being welded would be able to be used?
I just think this would open up TONS of suspension and brake options...but as i said maybe it's already been looked at and maybe I am way off base?
https://wisefabusa.c...ront-track-kit/
http://www.jdmaster....ab-front-track/
I realize these kits are also tremendous money - but just trying to find a solution I will be happy with.
#2 Preludedude
Preludedude
  • 2,686 posts
Posted 02 July 2018 - 12:48 PM
I've never seen anyone here on SQC review the D2s as "soft"
#3 tsi_tom
tsi_tom
  • 2,237 posts
Posted 02 July 2018 - 01:18 PM
Mine are bouncy
Engine
20 over forged pistons
Stock injection system
#4 TxStig
TxStig
  • 36 posts
Posted 02 July 2018 - 03:24 PM
Just going by what i saw in a couple of reviews when reading about them.
Again I just like to have more choices. the possibility of remote reserviors would be awesome. It would open up a bunch of choices for brakes too. You could put EVO Brembos or aftermarkets....just don't see why nobody has tried it? They are both Macpherson strut. I think I may be able to make something that works with EVO uprights and bolts into our standard cross member.
I think it's the direction I am going to try and go. Just wanted to see if anybody had already done it
#5 aconro
aconro
  • 236 posts
Posted 02 July 2018 - 03:52 PM
For the front suspension, I know a few people that have converted to s13 parts: coilovers, uprights, and brakes.  They just require extending/ modifying the LCA.
I am also very interested in more information on an alternative setup.  Mainly for gaining better parts availability and aftermarket support.
My D2's also feel bouncy but I feel some of that might have had something to due with them being on set to the hardest stiffness and me not checking them for ~10,000 miles.  I have heard that you can wear out coilovers quickly if you leave them on the hardest damping setting for too long.  However, I am not sure of the validity of that claim.
1988 Chrysler Conquest TSI Auto (Sold)
1987 Chrysler Conquest TSI 1JZ Swap - MS3-Pro, Holset HX35, ID1000, E85
2008 Dodge Caliber SRT-4
2007 Buell XB12R
#6 TexasQuest
  • 8,681 posts
Posted 02 July 2018 - 03:59 PM
I'm sure you can get stiffer spring rates for the D2's & KSport coil overs if you feel the need. That's the purpose of full body coil overs.
88 Fiji Blue -Tsi
#7 BC_99
BC_99
    Plays in traffic
  • 5,172 posts
Posted 02 July 2018 - 06:10 PM
Convette is on D2s. That is more racing than anyone else recently has or will be doing with a starion. My D2s are stiffer than I care for. I have softened the dampeners about 70% of the way and they are still way stiff enough for a street car.
BC
#8 importwarrior
  • 18,108 posts
Posted 02 July 2018 - 07:30 PM
View Posttsi_tom, on 02 July 2018 - 01:18 PM, said:
Mine are bouncy
Mine are bouncy also. I need to check preload again on the spring.
I think my spring preload is not set properly possibly causing the bounce I feel.
I am set 15 clicks from soft.
Once you get the D2 lower threaded part welded up you can always get the D2ís
Rebuilt to your specs.
Different spring rates.
Thicker or thinner oil for the strut -shock.
Sky is the limit just contact nick and or D2 support. Tell them what you want.
#9 Turbo Cary
Turbo Cary
  • 1,542 posts
Posted 02 July 2018 - 08:59 PM
Is anyone properly corner balancing their suspension system? I feel most people just get their ride height close without actually dialing in the system. I'm sure if y'all went and obtained some scales to do the process, you'd be amazed at how much better the car will ride/handle.
#10 tsi_tom
tsi_tom
  • 2,237 posts
Posted 02 July 2018 - 09:24 PM
You are right and this is on my list. Mine bounces me out of the seat when going over a bump.   I did preload as suggested here so that may be my problem.
Engine
#11 importwarrior
  • 18,108 posts
Posted 03 July 2018 - 07:46 AM
I took it to a place called P-Tuning.
They supposedly did but when measuring all 4 corners the front is with in a 1/4 inch of each other.
the rear is a 1/2 inch difference from side to side. Ride height.
but car handles great and drives straighter than any other car I ever had.
#12 TxStig
TxStig
  • 36 posts
Posted 03 July 2018 - 08:55 AM
This is to account for when you sit in the car - unless you measured those heights with weight in the front seat?
If you are only "setting the height" with coil overs you are not putting any pre-load into springs in order to induce pre-load you would have to actually use the collar to compress the spring while the car is unloaded. Otherwise the pre-load is the same.
I am going to go ahead and see about making the front suspension from an EVO work (again it is Macpherson Strut) plus it will keep it Mitsubishi - the idea of cutting up a front suspension and welding it up just seems janky.
This car will be pretty much track use only - possibly Time Attack.
As a side note (and not to brag too much) but I did I spend a couple of seasons working for RisiCompetizione in the American LeMans Series on the Ferrari F430 GT Car. Also have ten years of racing shifter karts under my belt so supreme adjust ability it what I am after.
I will be sure to document the results.
#13 Fuze
Fuze
    AKA @Battlemagnet
  • 2,751 posts
  • Interests:Chess Boxing
Posted 06 July 2018 - 04:13 PM
As for the front suspension swaps, I agree S13/S14 Nissan LCA/knuckle/brake/strut swaps are the absolute best option if your feel like you need more variety of compatible parts. You can probably do the whole swap and just change the strut tops, and the Nissan LCA's push the wheels out about another inch or so, no more 25mm wheel spacer! No car has more suspension options than a damn S13 Nissan Silvia/240, and the parts are similar in design to the Starion parts. The Evo is AWD, the knuckle is for AWD, the arms are different, doesn't make sense to adapt that when better options exist.
And my D2's don't bounce! But keep in mind, it's not always about off the shelf with these cars and plenty of parts from other cars can be adapted over. You can also swap springs and change rates on the D2's, or have them re-valved stiffer. IIRC John Lazorack's are a custom built/valved set.
Edited by Fuze, 06 July 2018 - 04:15 PM.
Insta = @battlemagnet
#14 Funky Phil
Funky Phil
    Super Pooper
  • 6,413 posts
Posted 20 July 2018 - 08:51 AM
Mine are bouncy
Spring preload
#15 starquestJOE
starquestJOE
  • 3,510 posts
Posted 22 July 2018 - 06:13 AM
Mine are not bouncy at all. In fact they is no give to them at were i have them set too. Smooth but firm
IM STARQUEST 4 LIFE ....
88 esi-r-white-SOLD
88 tsi white 61k-SOLD
89 tsi-black-rip
87 tsi-black/red-SOLD
88 tsi yellow sold
89 tsi white parts car
88 esi-r-black-RIP
#16 speedyquest
speedyquest
  • 3,925 posts
Posted 22 July 2018 - 10:47 AM
Mine are the same. I am very happy with them.
#17 tsi_tom
tsi_tom
  • 2,237 posts
Posted 22 July 2018 - 12:23 PM
I think I asked you guys this before what preload did you apply?
Engine
#18 speedyquest
speedyquest
  • 3,925 posts
Posted 22 July 2018 - 03:03 PM
I did what they suggest in the instructions, zero preload.
#19 starquestJOE
starquestJOE
  • 3,510 posts
Posted 22 July 2018 - 07:32 PM
My preload is turn the collar til it touches the spring. Then one full turn. Lock it in place
88 esi-r-white-SOLD
89 tsi-black-rip
88 tsi yellow sold
88 esi-r-black-RIP
#20 Convette
Convette
    I used to driftjunk
  • 4,989 posts
  • Interests:Going faster
Posted 23 July 2018 - 06:31 PM
Not worth the time or money to try and use evo stuff...dont know why everyone wants to all the time.
D2s are nothing short of amazing. I've run them for the past 6 years, thousands of miles on the street and close to that on the track.  And no, I'm not saying this because of sponsorship,  they are not one of my sponsors.
I've replaced all of them once, and prolly need to do so again soon.  The inserts are $100 a piece.   I have the "race versions"  very much like the street ones, just stiffer springs and slightly different valving.  I've beat cars with $10k suspension systems... doesn't mean that they are superior.
That said, if your car is bouncy you have them setup wrong.  Watch Matt Farah's "One Take" review on my car, take note to ride quality.
Spend time making your car not suck before re inventing far more issues than it already has.
