-AN adapter to PS pump.
46 replies to this topic
#41 quest925
quest925
  • 818 posts
  • Interests:quest obsessed
Posted 05 May 2007 - 08:00 PM
On the steering gearbox, the return/low pressure line, what is the size of the adaptor to thread in? I tried the Summit 14mm, but its too small (on return line)
88'Starion under full resto
98' M3 CVT 28k miles-mint
83 Audi UR Quattro-The godfather
07' Benz-whatever I have to drive for work...
#42 emagdnim
emagdnim
  • 5,621 posts
Posted 06 May 2007 - 09:43 AM
if it was too small then it would be a 16mm.
What would an angel say, the devil wants to know.
#43 quest925
quest925
  • 818 posts
Posted 06 May 2007 - 02:07 PM
thanks!, looks like Im going to have a lot of extra parts....thanks again
#44 importwarrior
  • 17,890 posts
Posted 08 May 2007 - 07:11 AM
I am running EAR-130606 -6 power steering hose, EAR-134606ERL -6 45 deg JIC hose ends, (2) EAR-9919DFHERL -6 AN to 14MM-1.5 adapter, and EAR-139106 90 deg JIC
this is on the high pressure side only and the line is the braided blue cloth ordered from summit the total was $108 with tax
im doing that for sure. thanks for the part numbers!
#45 gofastredstar
gofastredstar
  • 709 posts
  • Interests:Starquest! Duh!
Posted 15 February 2008 - 07:31 PM
Anybody figure out what size the threads are for the oil block adapter? Oh, and the oil cooler bango size too? Thinking about making up my own lines, or buying a set from Lower Shores. Thanks
I'm your turbo lover!
88 Conquest (Fiji)
Magna, 75 lbers, 6062 turbo, 86 interior, 8 and 9's, 83 Hood, FIP Fuel and Ignition Ecu's, Sreaming Banshee mechanical, and other goodies I'm forgetting.
#46 mikec
mikec
    not around much any more
  • 6,304 posts
Posted 15 February 2008 - 11:40 PM
FYI on the power steering system pressures: the factory service manual, on page 19-3 (the specs page for the steering system) lists the pump pressures as 1067 to 1166psi - basically around 1100 psi.  So 1000psi rated hose is nowhere near enough.
mike c.
#47 zactek
zactek
    Artistic Technician
  • 3,935 posts
Posted 16 February 2008 - 01:05 AM
The hose I'm using is rated to 2600Psi, completely different than the regular braided-type which is ok for oil and fuel lines :wink:
Make sure whatever you're using for the PS lines is for PS application and has a teflon liner. :wink:
  Zack 8)
Life's too short to be like everyone else.
Savour kindness because cruelty is always possible later.............
Uploaded with ImageShack.us
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
