damurida Posted March 15, 2008 Report Share Posted March 15, 2008 IM in the process of setting up my ms2 with edis..... but not sure what size trigger wheel is needed ...this is the only part that im lacking...also is there any other parts needed just for the install of the trig wheel itself...... Thanks Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted March 15, 2008 Report Share Posted March 15, 2008 http://www.starquestclub.com/forum/index.p...4+trigger+wheel There's a good number of threads on this in the MPI forum.. Importwarrior is working on a EDIS-4 setup with MS2.. Link to comment Share on other sites More sharing options...
damurida Posted March 15, 2008 Author Report Share Posted March 15, 2008 yeah...i have been searching thru the topics for 2/3 days now... and i have yet to find anywhere at all on what size trigger wheel that is being used... i know its a 36-1 but what size....i was thinking that it may be a 6.50 to 6.75 with a 1/2 pilot hole but was not to sure.... 4" 36-1 Trigger Wheel 6 3/4" 36-1 Trigger Wheel 8 1/4" 36-1 Trigger Wheel 36-1 Trigger wheel with a 1/2" pilot hole range from 2.5" up to 8.25" 36-1 Trigger wheel with a 1/4" pilot hole range from 3.5" diameter 36-1 Trigger wheel with a 5mm pilot hole range from 2.5" and 3" 36-1 Ring gear style trigger wheel range fom 4.5" up to 6.5" ....before i posted this question...im just finding pics and comments on how i hope it works and looks good..the normal stuff .....no size or measurements Link to comment Share on other sites More sharing options...
importwarrior Posted March 15, 2008 Report Share Posted March 15, 2008 the actual size and gap of the teeth is very important if you are going to make your own trigger wheel. if it is not proper you will not get the timming right and have a head ache. make sure you read up on it. on the other hand you can get different ones from www.diyautotune.com . they make them. http://www.diyautotune.com/catalog/trigger-wheels-c-48.html Link to comment Share on other sites More sharing options...
