CXRacing Starion Radiator AND Shroud
I-W CXRacing CX Racing
18 replies to this topic
#1 importwarrior
  • 18,156 posts
Posted 12 February 2015 - 08:42 AM
http://www.ebay.com/...=item2a461d0efe
Radiator And Shroud
$349
#2 Fuze
Fuze
    AKA @Battlemagnet
  • 2,751 posts
  • Interests:Chess Boxing
Posted 12 February 2015 - 10:01 AM
Edited by Fuze, 12 February 2015 - 10:01 AM.
Insta = @battlemagnet
#3 TexasQuest
  • 8,755 posts
Posted 12 February 2015 - 09:02 PM
Been eyeballing that. Wonder how reliable that setup is............
88 Fiji Blue -Tsi
#4 nightwalkerancestery
    Dedicated Addict
  • 1,063 posts
  • Interests:G54B, Datsuns, More Power, Electronics, Music, Bowling
Posted 12 February 2015 - 11:08 PM
VERY reliable. I've been running the radiator without shroud and two 10" fans for 2 years and have never had a problem of running too hot even in 100* weather. Can only imagine how much better it'll be with the shroud.
- Charles
88 Mitsubishi Starion Esi-R: DD. Rebuilt stock engine (About 20k miles). Mechanical rocker arms. NJV Head. 240sx SR20 Aluminum Radiator. 1g BOV (about to put in Greddy RS). 650/950 Delphi Injectors from Brian, Aftermarket Rising Rate FPR. Removed emissions. Gutted cats. Rebuilt rear end. Polyurethane end links.
Resto Thread: http://www.starquest...opic=129093&hl=
87 Mitsubishi Starion Esi-R: NJV Head. Full port and polish. Ported mixer housing w/ knife-edged divider. Stress-relieved, ported, polished OEM Exhaust Manifold. BSE kit. 2.5" Mandrel Bent Aluminized Exhaust with 3" Stainless downpipe. 2.5" OVCP w/ TurboXS BOV. 18G-TD05H Turbo at 18psi w/ Port and polished Compressor & Exhaust housings. New bushings all around. Poly End Link and Mount Bushings. Solid Diff mounts 88 6-bolt rear end. 044 Bosch Fuel Pump. Trilogy Injectors (stock flow). Stainless braided fuel lines w/ AN fittings and NRG FPG. No emissions. 475lb/ft pressure plate with stock sprung disc. 2-step 225mm flywheel lightened to 23lb. To Be Continued...
#5 tankbob
tankbob
  • 1,103 posts
Posted 14 February 2015 - 04:00 AM
Worth buying just the fans/shroud to upgrade from stock? I already have the *DM radiator
#6 importwarrior
  • 18,156 posts
Posted 14 February 2015 - 08:02 AM
I have read that the shroud prevents flow through the rad when fans are not running
Causing the engine to run hotter then normal. But cools quick when fans are on.
They stated it was better without the shroud when cruising. Now that is based our cars.
#7 louswheel
louswheel
    King Kong Status
  • 9,283 posts
Posted 16 February 2015 - 09:27 PM
KayDM radiator is the CX Racing radiator.  That's who made it for him.  So just buy the fans and shroud  and you're all set.
#8 mechengrkj
mechengrkj
  • 436 posts
Posted 09 March 2015 - 09:15 AM
I bought this last week and went to install it without success. With the shroud and fans in place, the primary fan hits the water pump pulley. I'd say don't waste your money buying the shroud because you won't be able to use it anyways.
#9 JohnnyWadd
JohnnyWadd
  • Banned
  • 8,936 posts
Posted 09 March 2015 - 06:16 PM
That shroud sucks. It only helps because it doesn't compromise the core like you can with the zip tie mounts.If you use foam tape between the fan and the fin contact it will work a lot better than having the shroud. You get 100 percent of the fans CFM moving air through the fins, AND your ambient air flow is not blocked. Those shrouds that you see on most OEM applications have little one way vents and holes and are spaced farther out from the core than those shrouds on the ebay kits. They are more like airdams than shrouds.
I bet motocam360 could make a set for use to use like this
http://smg.photobuck...kets_8.jpg.html
I used the zip ties before and never had an issue
Was it 1400 bucks? The ebay auction shows $1399 right now!
You could do two two Spal 16 inch fans and a relay kit for 1/10th that price. I am guessing they are out of stock and that's why they raise the price. At $349.00 its still a decent deal, toss the shroud and use both fans, just wire them into the stock relays. WIN
Edited by JohnnyWadd, 09 March 2015 - 06:37 PM.
#10 importwarrior
  • 18,156 posts
Posted 09 March 2015 - 07:12 PM
The only reason its so high is because they are out
Or they are on back order.
As soon as they get more made the price will go back to normal levels.
They do this so they dont have to end the ad
#11 randy
randy
  • 4,099 posts
Posted 09 March 2015 - 07:39 PM
Those spal fan backets looks great.
#12 psu_Crash
psu_Crash
  • 7,052 posts
Posted 09 March 2015 - 07:44 PM
O yeah? That's some good information since I too run the afore-mentioned radiator. I'd like to ditch the stock shroud for something in better shape.
Edit: Just read the rest about the fitment of the shroud ... I have two 14" fans here that I planned to use a while back but stuck to the stock setup since it was easier at the time.
So how would you mount 2 x 16" fans on there!? The 2 14s I have seemed that they were too big?
Edited by psu_Crash, 09 March 2015 - 07:47 PM.
My Feedback Link
#13 TexasQuest
  • 8,755 posts
Posted 09 March 2015 - 08:14 PM
Those fan mounting brackets look sweet! MotoCam definitely should make those!
88 Fiji Blue -Tsi
#14 importwarrior
  • 18,156 posts
Posted 10 March 2015 - 05:12 AM
could not fit 2 16 BUT a 12 and 16 fit.
basically an example of what i did i just put 12 in upper left corner and the 16 in bottom right corner.
tight but fit. mount the 16 first.
#15 importwarrior
  • 18,156 posts
Posted 18 June 2015 - 05:07 AM
after running with the shroud for a while in 95 DEG days...
it seems like the radiator air flow is kind of reduced.
on hot days it seems to run a little warm. with out the
shroud i think the air flow when fans are off was better.
less restriction.
the only difference i see that is better is now that i used
window sealer foam strips to close any and all gaps in the
shroud, when fans turn on the temps drop a lot faster on
the dash gauge. to me it is more noticeable.
on regular days below 90 the gauge is rock solid and does
not move.
Still very happy.
#16 randy
randy
  • 4,099 posts
Posted 20 June 2015 - 10:20 PM
so aare you still using the shroud?
#17 markhansenconquest
markhansenconquest
  • 3,306 posts
Posted 23 June 2015 - 01:20 AM
use the stock fan and it works perfect..................*dm rad is raadddddddddddddddddd....best rad for your quest!!!!!!!
#18 JohnnyWadd
JohnnyWadd
  • Banned
  • 8,936 posts
Posted 23 June 2015 - 02:50 AM
kess restriction.
not move.
Still very happy.
The shroud is indeed a cooling loss due the the lack of ambient flow. If you use foam tape at the fan mount and go without the shroud you might be even better .
#19 importwarrior
  • 18,156 posts
Posted 23 June 2015 - 04:56 AM
Thats what i am thinking.
i did use the foam strips on the sides of the radiator between the rad support and radiator
but not across the top and bottom the gap is so small i dont believe it will be much help to
do so. but the side gap is big.
i just dont know if i want to stick radiator fan mounts through this radiator it is so nice!
Also tagged with one or more of these keywords: I-W, CXRacing, CX Racing
