Starion problems need help!!!
Starion Turbo 2.6 G54b Esi-r
23 replies to this topic
#21 #NBHNC
#NBHNC
  • Newbies
  • 29 posts
Posted 07 June 2012 - 08:50 PM
Well I finally did a compression test.
Cylinders
1: 110psi
2: 105psi
3: 105psi
4: 105psi
#22 markhansenconquest
markhansenconquest
  • 3,194 posts
Posted 08 June 2012 - 02:44 AM
has the tank been taken out and cleaned really good....mine ran good some times and sometimes it would cut out...if you drop tank look in side for rust...mine had a light rust or dirt..used 3 bottles of toilet bowl cleaner that has muridic acid in it.. pour in tank duck tape holes shake up and down and upside down coat all of inside.leave for a day or two depending on how bad ..,wash out with power nozzle.at least ten times till clean water comes out...also check metal screens it top hat if dirty back blow to clean out..blow dry with shop vac or let it dry out in sun .. after cleaning out system ...flush gas throu system with out injectors in place.!!!!!!!!straight in to coffee can to see if you got clean gas ...i did that to mine it ran like a champ ..even small specks of dirt or rust will cause it
to cut out...good luck hope that help you out!!!!!!!!
#23 Indiana
Indiana
    Addicted Starquester
  • 14,736 posts
Posted 08 June 2012 - 10:27 AM
Hook it back up like its supposed to be and buy a new CTS.
#24 #NBHNC
#NBHNC
  • Newbies
  • 29 posts
Posted 08 June 2012 - 12:58 PM
It has a new cts
Also tagged with one or more of these keywords: Starion, Turbo, 2.6, G54b, Esi-r
