Stabbing transmission - manual
21 replies to this topic
#1 tux
tux
  • 1,290 posts
Posted 03 December 2018 - 01:55 PM
Hey guys,
I'm trying to put the transmission back in.  Everything seems to be aligned (clutch/pilot bearing) and I can feel the transmission slide into the teeth of the clutch.
When wiggling around the tranny I can feel some kind of light feedback (i'm assuming grazing over the hole for the pilot bearing).
But I can't get her in there.  I've tried for a few hours.  Tried jacking up the engine from the pulley a bit.  all kinds of wiggling and so, but I can't get her in.
Anyone have any tips?
#2 speedyquest
speedyquest
  • 4,150 posts
Posted 03 December 2018 - 02:02 PM
I'll ask a few of the standard questions just because someone else will and we might as well get it out of the way right now.
1) Did you use an alignment tool?
2) Did you try using the bolts to force the transmission and engine together? If so you could have damaged something
3) Have you checked the condition of both the pilot bearing and the transmissions input shaft?
Otherwise I'd say one of the biggest things it to take your time, focus on trying to get the transmission and engine parallel with eachother, and if you can get some help.
Edited by speedyquest, 03 December 2018 - 02:02 PM.
#3 tux
tux
  • 1,290 posts
Posted 03 December 2018 - 02:44 PM
1) Yes, I used the plastic exedy alignment tool and double checked with a metal universal tool I had
2) No, I haven't use the bolts to force it together.
3) The pilot bearing is brand new and I "test fit" it on the input shaft prior to pressing the bearing into the flywheel.
#4 pcristquester
pcristquester
  • 2,423 posts
Posted 03 December 2018 - 03:59 PM
Maybe check the alignment dowels for damage
#5 speedyquest
speedyquest
  • 4,150 posts
Posted 03 December 2018 - 04:39 PM
Then I've got no idea, you've done everything you should do.
#6 tux
tux
  • 1,290 posts
Posted 03 December 2018 - 06:08 PM
Brand new alignment dowels, freshly ground flywheel
#7 croquest87
  • 1,498 posts
Posted 04 December 2018 - 06:11 AM
Just a thought   By any chance did your pilot bearing get pinched or go sideways or nicked your input shaft on small diameter? Sucks to take it off but maybe slide that flywheel and clutch on outside the car and see how it all fits. Also l would make sure that the holes that dowel bushings slip into are clean and burr /nick free as they are soft and easily get messed up. If dowel bushings are sitting at on angle for any reason things will not go smoothly. I prefer to put smooth radius on them instead of that 15 deg chamfer.Small amount of grease on mating surfaces sure makes things slide in easier lol.
Edited by croquest87, 04 December 2018 - 06:14 AM.
#8 psu_Crash
psu_Crash
  • 7,162 posts
Posted 04 December 2018 - 02:54 PM
Been there before!!
I had an install take me hours to get the dam thing to slide back together a couple years back. I've since created alignment pins by cutting the head off of some bolts and threading them into the block. Once things slide together I take them out one at a time and replace with the proper bolt.
Saves a serious amount of headache
My Feedback Link
#9 tux
tux
  • 1,290 posts
Posted 04 December 2018 - 04:11 PM
Great idea!
#10 mikec
mikec
    not around much any more
  • 6,318 posts
Posted 05 December 2018 - 12:42 AM
Another thing is to put the transmission in gear and rotate the output shaft back-n-forth so the input shaft splines rotate a bit.  That helps them seat into the clutch disk.
The transmission and engine have to be VERY closely aligned for things to work.  Just a degree or two of vertical and/or horizontal mismatch is enough to keep the transmission input shaft from even trying to fit into the clutch disk.  One thing I suggest to folks before the remove the transmission is to draw straight lines on one side and on the bottom of the transmission and matching lines on the engine.  Something you can see to verify the alignment before you resort to brute force.  Another way is to run strings from fixed points underneath the car: one string running front to back under the engine and transmission, another along the sides.  Site along those strings and draw lines on the transmission body.  Too late for you though.  What I'd do in your situation: I assume you've got the transmission on a jack or some sort of support, hopefully near the center of the transmission.  Put one hand on the bottom of the bellhousing and the other on the output shaft of the transmission.  While twisting the output shaft back-n-forth again (transmission in gear, I'd suggest 4th) lift/twist/wiggle the bellhousing end.
mike c.
#11 Dad
Dad
  • 8,146 posts
    87 White Quest
    87 Shetland
    83 Starion- Chevy powered
    ___________________________
Posted 05 December 2018 - 05:43 AM
If you force it and there is still pressure against the crank, it will destroy your crank thrust bearing, after it is all bolted just check the crank end play to be sure it still floats forward and back.  Also we are assuming this is all original parts except clutch and flywheel of course.   If you still have the pilot bushing from an automatic in your crank that will give you grief
Dad
#12 tsi_tom
tsi_tom
  • 2,284 posts
Posted 05 December 2018 - 07:05 AM
Donít forget the plate between the engine and transmission.  Not sure if you took that off, but it still should align with it removed.
Engine
20 over forged pistons
Stock injection system
#13 tux
tux
  • 1,290 posts
Posted 05 December 2018 - 09:43 AM
Dad
Shouldn't be any automatic pilot bushing!  The bushing fit on the input shaft before (I'm assuming it's just not able to get the right alignment)
I've got her 1-2mm from reaching the alignment dowels on the lower part of the transmission.  Just can't get it really any closer.
#14 psu_Crash
psu_Crash
  • 7,162 posts
Posted 05 December 2018 - 09:48 AM
Sounds like the pilot bearing isn't cooperating. Perhaps the pilot isn't centered up perfect. Some of those alignment tools leave a good bit of slop.
Wiggle, push, wiggle, push ... repeat. It can be a real PITA! Sometimes they fall together. Other times...
Is it close enough to get the bolts started? That might help get things lined up
Edited by psu_Crash, 05 December 2018 - 09:50 AM.
My Feedback Link
#15 tux
tux
  • 1,290 posts
Posted 05 December 2018 - 04:20 PM
i'm about 1-2mm from the alignment dowels on the block
#16 DSMracespeed
DSMracespeed
  • 1,110 posts
  • Interests:STARQUEST...CARS,CARS,CARS
Posted 10 December 2018 - 07:47 AM
Is the release bearing installed correctly?
I usually put a ratchet on the crank pulley bolt and rotate the engine to help allign the clutch disk splines to the input shaft...make sure to rotate the engine in the correct direction or you could jump a tooth on your timimg chain.
Jerry
'87 Starion
'88 Conquest TSI...4G63 swap
'86 Lotus Esprit Turbo...Restoring
'08 Evo X MR
'03 Evolution VIII
'03 350z
'95 Eclipse GSX
'00 Celica GTS
'02 Protege5
'88 CRX Si
'04 RX-8
#17 tux
tux
  • 1,290 posts
Posted 11 December 2018 - 12:12 PM
Just an update, I got the flu so I am giving up until I am no longer sick.
#18 kev
kev
    Moderator
  • 4,982 posts
Posted 11 December 2018 - 02:58 PM
I had a little bit of issue stabbing mine after rebuild.  I installed new alignment bushings on the block (the two bottom bolt holes for the tranny).  They had some slight interference with the mating holes on the transmission.   I deburred the holes but it was still tight.  Ended up using longer hardware to reach the thread and carefully pulled the tranny onto the bushings.
#19 ucw458
ucw458
  • 11,548 posts
Posted 18 December 2018 - 04:06 PM
I've had that happen with a couple SQs.  No matter how well aligned they didn't want to go together.
Start by putting a long bellhousing bolt in each side.  Use a ratchet if you must but the goal is to just get them finger tight against the bellhousing.  Then grab the tailshaft and wiggle/push hard till you feel it get loose.  The bolts should be loose now.  Snug them up again and repeat.  Do this until the trans slides onto the alignment pins.  If it's still tight you can walk the trans the rest of the way with the bolts.  Do no more than 1/2 turn on each side at a time so you are walking it on evenly.  If the bolts start to feel tight wiggle the tailshaft again.  It sucks to have to do it this way but I have done it twice without damaging anything.
Every SQ manual trans I've seen had input shaft play.  Maybe that contributes to it.
My 87
#20 Tim_C.
Tim_C.
    Addicted Starquester
  • 10,094 posts
Posted 20 December 2018 - 10:37 AM
I just stabbed mine in yesterday. My daughter is home from college for Christmas, so I told her I'd pay her to help me. I did the heavy lifting, and she aligned the tail shaft to get a straight shot at the pilot bearing. It went in very fast, like 20 seconds we had it over the dowels and a bolt started.
My engine had a a bad leak at the rear main area, so I removed the flywheel and rear main seal to find the bolts that hold the seal housing to the oil pan had been drilled out. The new bolts were the same diameter size. The true problem was oil was leaking right out through the thread area on one of the bolts. Can't believe I didn't see it before pulling the trans! I could have easily siliconed the threads to stop the leak. Anyway, it gave me an excuse to put a better clutch in it. I also found another stock main seal housing and shorter bolts and put a new rear main seal in it too.
I put a TEP Street clutch in it years ago with the newly rebuilt engine. It holds very well, but was too grabby. It was either in or out with no in between. So I just put in the ACT Street Clutch because I have one in my '86 that holds great and is super smooth.
'84 Dodge Conquest Parts car
