Boost question
8 replies to this topic
#1 TFRACING
TFRACING
  • 54 posts
  • Interests:Old cars (Mopar dsm), motorcycle drag racing, just a plain motor head.
Posted 16 October 2018 - 02:13 PM
1989 Chrysler Conquest TS, Auto, This one has me confused, with in the first 10-15 min after driving it I can make full 10lbs of boost the first time I stab it, after that it will only go to 5 lbs. No hesitation and the revs keep going up, but it feels like its staving for air to me. I have replaced VAC lines, VAC Advance, plugs, wires, PCV, AIR FILTER, Injectors, injector clips ( it did have a bad hesitation, gone now) Im not a tech and I know I must be missing something.  I also have the exhaust off the car and Im just running the front cat. Any help would be great.
Thanks in advance
Tony.
#2 importwarrior
  • 18,143 posts
Posted 16 October 2018 - 02:39 PM
Sounds like a leak in the intercooler pipe or coupler not sealing properly.
If you can do a boost pressure test.
#3 croquest87
  • 1,168 posts
Posted 16 October 2018 - 03:59 PM
Hope you are not leaning out. You should really have a afr gage installed. It's much easier to know what your car is doing.  My 87 when l first bought it had rust in the tank and filters where severely plugged. It wouldn't boost and all kinds of weird symptoms.
#4 BC_99
BC_99
    Plays in traffic
  • 5,177 posts
Posted 16 October 2018 - 04:04 PM
Stock boost gauge or aftermarket mechanical?
BC
#5 TFRACING
TFRACING
  • 54 posts
Posted 16 October 2018 - 05:40 PM
BC
Stock boost gauge, also the tank is very clean with no rust and all the filters have been replaced. I did just make a boost pressure tester and no leaks, one more thing to check off the list. lol
#6 87redcat
87redcat
    10 years and counting...
  • 3,761 posts
Posted 16 October 2018 - 05:56 PM
BC beat me to the question. Invest in a good vac gauge it will be a lot more accurate. The stock ones are known to not be accurate
#7 croquest87
  • 1,168 posts
Posted 16 October 2018 - 06:12 PM
Cool  sounds like your gage has issues  mechanical gage should do the trick  good luck.
#8 TFRACING
TFRACING
  • 54 posts
Posted 16 October 2018 - 06:39 PM
I will give that a try. Thanks for the help.
#9 TexasQuest
  • 8,730 posts
Posted 19 October 2018 - 11:20 PM
Good quality aftermarket gauges are invaluable for these cars.
88 Fiji Blue -Tsi
