uconn1150 Posted 17 hours ago Report Share Posted 17 hours ago Hello all! Has anyone used an auto transporter from U-Haul. Fine print says 6 inch ground clearance required. Isn't the air dam a smidge less? Looking for feedback and/or opinions. Thanks! Link to comment Share on other sites More sharing options...
ssblast20 Posted 16 hours ago Report Share Posted 16 hours ago Use them all the time. Just carry a couple cut 2x6s and you’ll be fine loading. Then a couple small 2x6s (about 12” length) to put under the front wheels once you load it. Steve Link to comment Share on other sites More sharing options...
uconn1150 Posted 16 hours ago Author Report Share Posted 16 hours ago 31 minutes ago, ssblast20 said: Use them all the time. Just carry a couple cut 2x6s and you’ll be fine loading. Then a couple small 2x6s (about 12” length) to put under the front wheels once you load it. Steve Thanks Steve! How long do the cut cut 2x6s need to be for loading? Also, did you leave the car in 1st (manual) or neutral? --Louie Link to comment Share on other sites More sharing options...
Gh4st Posted 12 hours ago Report Share Posted 12 hours ago Towed my Starion just last month just fine and had no rub on the air dam! Link to comment Share on other sites More sharing options...
ssblast20 Posted 11 hours ago Report Share Posted 11 hours ago I would say maybe 3 feet long for when you are loading on the ramps, and then just a couple 1 foot sections for the front. I’ve towed probably 20 of these things, and I’ve used a U-Haul trailer every time. It’s just a close call and you’ll want that a little bit of leverage, just to be safe. Link to comment Share on other sites More sharing options...
