Fuel filler neck hose replacement question.
15 replies to this topic
#1 importwarrior
  • 18,020 posts
Posted 09 April 2018 - 06:32 PM
Hw long did it take you to change it out.
any issues ?
Tips tricks to make it go easier?
Thank you.
#2 TexasQuest
  • 8,640 posts
Posted 09 April 2018 - 10:48 PM
I lifted the car up and removed the splash shield cover, loosened the filler neck at the body and basically cut the old rotted one out. I used a lot of lubricant to get the new one on.
88 Fiji Blue -Tsi
#3 techboy
techboy
  • 3,100 posts
Posted 09 April 2018 - 11:12 PM
What Texas Quest said^^^. Replace the 2 clamps down there while you're at it, which you probably would anyway, and face the screws on them somewhere where you can get to them in the future if need be.
#4 importwarrior
  • 18,020 posts
Posted 10 April 2018 - 11:10 AM
thanks!
appreciate the help.
#5 tux
tux
  • 1,173 posts
Posted 10 April 2018 - 08:23 PM
I couldn't find new hose from MItsubishi, they said unavailable.  I ended up using one from a Ford truck
#6 techboy
techboy
  • 3,100 posts
Posted 10 April 2018 - 10:46 PM
I forget the dia. Off the top of my head, but you can get them just about anywhere, it doesn't have to be a Mitsu one. Just make sure the hose material is rated for fuel.
#7 croquest87
  • 963 posts
Posted 11 April 2018 - 02:19 AM
Napa had filler neck hose cant remember what size but had them cut off one foot was a perfect fit and fuel rated to.
#8 importwarrior
  • 18,020 posts
Posted 11 April 2018 - 06:28 AM
I believe 2 inch
#9 TexasQuest
  • 8,640 posts
Posted 11 April 2018 - 06:37 PM
I must have got the last one for mitsubishi lol.
88 Fiji Blue -Tsi
#10 kev
kev
    Moderator
  • 4,888 posts
Posted 16 April 2018 - 01:56 PM
2" ID x 4" long   NAPA sells it but it comes in a 30" long section!
#11 importwarrior
  • 18,020 posts
Posted 16 April 2018 - 02:41 PM
Thanks Kev.
I got it done.
Smooth as silk.
Thank you all for all the help. What a great feeling knowing I can fill the tank again.
#12 kev
kev
    Moderator
  • 4,888 posts
Posted 16 April 2018 - 02:43 PM
Sorry I didn't see this earlier, I would have sent you a 4" section of the tube.
#13 importwarrior
  • 18,020 posts
Posted 16 April 2018 - 03:33 PM
Greatly appreciate it Kev. I actually got some for free from the hydraulic place near by.
I got the tband clamps from him because of his kind jester.
#14 Turbo Cary
Turbo Cary
  • 1,505 posts
Posted 17 April 2018 - 11:35 AM
The stuff Napa sells also works well as intercooler couplers. It has a woven outer section and won't swell under boost. I used it for my OVCP pipe
#15 croquest87
  • 963 posts
Posted 17 April 2018 - 02:57 PM
That's a great freaking idea man! I like it probably much better than silicone couplers because they're so soft
#16 importwarrior
  • 18,020 posts
Posted 17 April 2018 - 05:46 PM
This is the stuff I got for free.
http://www.novaflex....n-Hose-p655.htm
