LS1 / T56 Starion
77 replies to this topic
#61 19cturbo
19cturbo
  • 6,677 posts
  • Interests:cars
Posted 06 March 2018 - 08:29 AM
View PostSFBMX88, on 06 March 2018 - 12:07 AM, said:
Did you weld up those holes where the idler arm went?  Seems like you could get a little more rigidity by welding to those through-holes.  Nice work!  Have you checked swaybar clearance with the pan?  I slotted my mounts a bit and my sway bar fits, but pretty sure its going to contact the pan during normal driving.  Thinking Im gonna notch the subframe and push everything back another half inch or so.
I welded the two layers together in several places then welded the patch back in. I welded the holes where I drilled out the spot welds.
View PostConvette, on 21 February 2016 - 11:51 AM, said:
#62 19cturbo
19cturbo
  • 6,677 posts
  • Interests:cars
Posted 11 March 2018 - 09:31 PM
Small update.. got the new brake booster in, its from a 1980 challanger. uses stock mounting holes, stock master cylinder fits it and its smaller than OEM. huge help here. Also got the hole for the battery cable situated and the hole fro the harness to go through. and the parts for the clutch line came in! Ordered my engine bay paint as well. Shouldnt be too long now.
#63 importwarrior
  • 17,809 posts
Posted 12 March 2018 - 08:41 AM
does the booster need a spacer besides the factory stock parts? or is it a direct bolt on no mods???
#64 slowquest
slowquest
    Maybe someday, I'll be FastQuest
  • 2,487 posts
Posted 12 March 2018 - 08:43 AM
Only thing that I had to do was adjust the pushrod length. It was about 1/16 too long as was holding the brakes applied. These are getting VERY hard to find however.
#65 Bradrock
Bradrock
  • 789 posts
Posted 12 March 2018 - 09:07 AM
Is that booster different than this Cardone rebuilt part 55-5103?
www.ebay.com/sch/eBay-Motors/6000/i.html?_from=R40&_nkw=challenger+brake+booster+1980&_sop=15
Thanks, Brad
Cool stuff!
Run's with scizzor's
#66 SFBMX88
SFBMX88
  • 1,522 posts
Posted 15 March 2018 - 12:08 PM
Have you tried different brake masters on it?  Looks like you can fit the more common horizontal flange master cylinders on it.  Where did you get it?  Part numbers?  Could you possibly measure the center to center on the horizontal studs?  If its around 3 1/8", that should take newer masters.
Edited by SFBMX88, 15 March 2018 - 01:20 PM.
#67 19cturbo
19cturbo
  • 6,677 posts
  • Interests:cars
Posted 16 March 2018 - 09:26 PM
Thanks, Brad
Cool stuff!
Same booster
#68 19cturbo
19cturbo
  • 6,677 posts
  • Interests:cars
Posted 16 March 2018 - 09:27 PM
55-5103 from rock auto
#69 SFBMX88
SFBMX88
  • 1,522 posts
Posted 20 March 2018 - 09:39 AM
Could you possibly measure the master cylinder studs from side to side?  Just want to know if the newer masters will bolt up.
Edited by SFBMX88, 20 March 2018 - 09:43 AM.
#70 19cturbo
19cturbo
  • 6,677 posts
  • Interests:cars
Posted 15 April 2018 - 09:12 PM
I made a trip back down to Haltech to pick up some more goodies! this dash will be awesome! I decided to keep the factory fuel gauge and low fuel light, I have had issues in the past with aftermarket fuel gauges, so this way is clean and simple! They also helped me get sorted on getting the proper connectors to get all this wired up!
I decided to wire the relay block for the haltech elite 950 to a connector, so i can situate the harness on the engine, install it, then just feed the harness through the firewall and plug it in, instead of having to feed it all through the firewall from the inside!
Racepak! I started with an idea in my head, drew it out on paper, ordered some LED's and got started, i stil have to get the decals made to finish it up!
#71 19cturbo
19cturbo
  • 6,677 posts
  • Interests:cars
Posted 15 April 2018 - 09:17 PM
Due to bad weather here ive just been getting done what i can, Its getting close to time for final assembly now! that will get the car running at least, ill still have to do al lthe brakes and make sure its all in good working order before i get it on the road,
Drug it outside to give it a proper bath before painting.
Ready to spray!
#72 mbruneaux
mbruneaux
  • 1,357 posts
Posted 16 April 2018 - 08:26 AM
Looks great
Canterbury, CT
1998 BMW 528i 5 Speed because the Suburban gets 10 MPG
#73 speedyquest
speedyquest
  • 3,737 posts
Posted 16 April 2018 - 09:19 AM
Great work man, you are really making a ton of progress on this.
#74 TexasQuest
  • 8,509 posts
Posted 16 April 2018 - 11:07 AM
Looking great man, excellent work!
88 Fiji Blue -Tsi
#75 19cturbo
19cturbo
  • 6,677 posts
  • Interests:cars
Posted 16 April 2018 - 01:17 PM
Thanks for the replies. Hopefully it starts going together soon!
#76 Preludedude
Preludedude
  • 2,344 posts
What is the part number for the brake booster (1980 challenger)....
This would be good information to have here on the boards...According to you, its a direct swap?
#77 19cturbo
19cturbo
  • 6,677 posts
  • Interests:cars
Posted 16 April 2018 - 10:18 PM
All part numbers are in the first post.
#78 Starionslider
Starionslider
  • 285 posts
Posted 16 April 2018 - 11:05 PM
Lookin good man. Your nearing the finish line. It will be a great accomplishing feeling on the first drive. I remember my feeling driving mine for the first time on my buddys repair plate. I was like omg this feels so illegal and i love it.
