Sputtering from idle to 3K RPMS
8 replies to this topic
#1 Black88Starion
Black88Starion
  • 19 posts
  • Interests:Cars, computers, baseball, football, basketball.
Posted 16 May 2017 - 01:34 PM
Not sure why but my 88 starion is sputtering really bad from take off to 3kRPMs. After 3K the car pulls hard. Any thoughts as to why this is happening?
#2 markhansenconquest
markhansenconquest
  • 3,109 posts
Posted 16 May 2017 - 03:27 PM
clogged injector,,bad injector connection...clean  injector backwards  first in to a white rag and see what comes out !!
#3 BC_99
BC_99
    Plays in traffic
  • 5,107 posts
Posted 16 May 2017 - 04:13 PM
Look for a vacuum leak.
BC
#4 anthonytsi
anthonytsi
  • 68 posts
Posted 16 May 2017 - 06:36 PM
All of my sputtering and hesitation problems have been because of a bad throttle position sensor. Once I got a half decent used one on there the problems stopped. Look up how to "sweep test" the one that's on your car on this site. Easy to do. I recommend taking it off of your car to do it. If you do make sure you don't  drop the screws. That's easy to do.
Edited by anthonytsi, 16 May 2017 - 06:37 PM.
1987 Conquest TSI with 113,450 miles.
1996 Volvo 850 Turbo Platinum edition with 120,000 miles.
1994 Jeep Grand Cherokee with 200,000 miles.
#5 Black88Starion
Black88Starion
  • 19 posts
Posted 17 May 2017 - 07:11 AM
Thanks for all of the replies. I will go through and check all of what was mentioned and give yall an update.
#6 Black88Starion
Black88Starion
  • 19 posts
Posted 18 May 2017 - 07:15 AM
Yesterday after checking out some things with it I checked the oil and I can smell gas in the oil. Any thoughts on this?
#7 G54Bstore
G54Bstore
    SQC Commander
  • 5,075 posts
Posted 18 May 2017 - 08:13 AM
Most likely you got injector stuck open. Test them both
W18 Rocky White Starion
Daily Driver
#8 Hoosierquest
Hoosierquest
  • 1,343 posts
Posted 18 May 2017 - 10:56 AM
Are your injector clips switched?  I'm pretty sure it should start and run with the green injector unplugged. That would be an easy test to make sure they are correct.
#9 Black88Starion
Black88Starion
  • 19 posts
Posted 18 May 2017 - 03:23 PM
I will test them tonight.
