Dash Gauge Replacement Panel GP
gauge cluster dash Autometer replacement overlay panel 5 gauge aluminum plastic
64 replies to this topic
#21 Jetspd150
Jetspd150
  • 386 posts
Posted 05 May 2013 - 07:30 PM
I think this product is a good idea, people are just trying to figure out how to make it work for them. Thanks for extending this GP.
#22 BOHO
BOHO
    Sucks at life
  • 5,102 posts
Posted 05 May 2013 - 07:58 PM
Before you make the final order lets just be clear on whats happening lol.
87 Starion 2jz
#23 mstieg
mstieg
  • 6,178 posts
Posted 05 May 2013 - 09:00 PM
View Postcreakyjoints, on 05 May 2013 - 03:42 PM, said:
I know this is probably going to drive you nuts. Any chance the holes for the gauges can be cut in a smaller diameter. I was basically thinking of putting the gauges in from behind after removing the bezel ring. Also this should let me use the clear plastic cover in front of the gauges. I will still want one I am thinking either way. I suppose I could have a ring welded on the inside of the holes. If you have my email please remind me to send money! :)
I hear you if wanting to keep the clear plastic front, but 'm doubtful there is enough depth to fit the gauges with bezels completely behind the panel.  Keep in mind this panel fits on top of the stock black panel and frame that holds it, and won't be supported without that, so they'd be about an inch further back than my setup, which as you see is already fairly tight, but (edit - just saw that you intend to remove the bezels)
This is a mock up, as I still need to secure the fuel & pyro, wire up & test, but I traced down the circuitry and it's looking easier than I thought.  It helps I had the gauge bulbs already working with stock dimmer circuit.  Yes they dim too :ph34r: :)
Edited by mstieg, 07 May 2013 - 11:46 PM.
In Progress: breakin & tune
#24 mstieg
mstieg
  • 6,178 posts
Posted 05 May 2013 - 09:06 PM
^*Also - I didn't take pics of the black frame cuts, but it's pretty simple - just Dremmel out whats in the way between the 2 stock tiny holes.
Yes - of course I'll make sure all's legit before getting them cut out.  It's looking like custom for everybody!? :wacko:
Based on sizing this up I don't think it'll work for ya Creaky, unless you have special narrow-depth gauges.
#25 BOHO
BOHO
    Sucks at life
  • 5,102 posts
Posted 05 May 2013 - 09:11 PM
I'm good with what you have as long as I can make it work and it lines up. I havn't cut on the white piece like you did yet. Kinda glad I didn't. I'll also take any advice on you hooking up your fuel gauge to the "factory" wires? Was having a hard time deciing what to do with the circuit.
87 Starion 2jz
#26 mstieg
mstieg
  • 6,178 posts
Posted 07 May 2013 - 11:38 PM
View Posttaeisallin, on 05 May 2013 - 06:45 PM, said:
cool. just a delete would do it for me.  im gonna use the top two warning linghts as my turn signals.
Talked to him today.  Can do yours without the upper turn signals.
#27 mstieg
mstieg
  • 6,178 posts
Posted 07 May 2013 - 11:43 PM
He can make em smaller if you size it all up and it fits for you.  Just send me the EXACT size holes you'd want.
I'd be glad to post a step-by-step "How To" once I get to that point and get it programmed.  I'm running the SportComp 3310 which is programmable.  Might do a simulated programming with the tank sensor float out of the tank before entering 16+ gallons into the before & after calibration procedure.
#28 BOHO
BOHO
    Sucks at life
  • 5,102 posts
Posted 08 May 2013 - 08:18 AM
Mine is programmable also just couldn't find the right wires from the factory sender unit. I'll send you the other 10$ since no one is jumping on this. As long as the turn signals match up to factory holes I'm good I think I can make it work. Let me know when your gonna make em.
87 Starion 2jz
#29 mstieg
mstieg
  • 6,178 posts
Posted 13 May 2013 - 10:46 PM
Okay guys.  I'm getting yours made this week.  If anybody else wants on board, great, but I'm not making you wait any longer.  I had a slight adjustment on the turn signal locations to get them moved in ever so slightly to line up perfectly.
BOHO - as is design, same as mine
Tae - no turn signal holes, no prob.  --> I can ask them to put those turn signal hole shapes in the place of the upper/outer 2 warning light holes if you want??  Should be pretty simple for them.  Please lmk if you want me to have them do this or just eliminate the turn signal holes only.
#30 BOHO
BOHO
    Sucks at life
  • 5,102 posts
Posted 14 May 2013 - 07:46 AM
Good deal.
87 Starion 2jz
#31 taeisallin
taeisallin
  • 1,247 posts
    get it? cars...
Posted 14 May 2013 - 08:59 AM
I may change my mind. Let me stare at yours a bit more and make up my mInd.
Thanks
#32 kidjc
kidjc
  • 2,273 posts
  • Interests:American Muscle/classics/hot rods/bikes, & Definitely Conquests & Starions, Cally Mull & "The Dragons Tail"
Posted 14 May 2013 - 08:15 PM
View Postmstieg, on 05 May 2013 - 12:34 PM, said:
Since Tae is the only one paid up so far, lets extend this a few days or a week until I can resolve your questions.  I hope to finish cutting the white plastic today and get you pics, line it all up, and check the fit.  Looks good so far.
I'll ask him about running yours without the turn signal holes.  It shouldn't be a problem to do that.  In fact with the green arrow pieces out, I noticed those are a tad to the outside, so I'll get him to bring em in to line up perfectly vs. what you see in my recent pic.  Moving to another area would depend on your line of sight and you'd have to mount the green arrow tabs and bulbs yourself.  I'm keeping the white stock mounts for simplicity.
Can you give me a pic of what you're wanting?  He can program that into the CNC process, so without checking, I'd figure the swirls could be as big or small as you like.  That would look pretty sweet.  I hope to hear back from him today.
Sorry... just caught back up w/ this. Don't have a pic, nor have I taken the Photo post 101 class. Thought most new what the silver brushed swirl Trans Am dash plate looked like? Must be my age thing? :unsure:  It just looks machined in a constant overlay swirl pattern on aluminum, Left to right? It "Really" would look sweet! So, am I to understand the clear dash shield won't work/clear on these? Appologize again for the lateness in respond'n.   Thanx!
#33 mstieg
mstieg
  • 6,178 posts
Posted 16 May 2013 - 10:47 AM
Something like this?
My CNC guy can do this, but said it'd be about $100 setup for their time, as each and every swirl would need to be another programmed step.  If that's good for you, we can make it happen.  It'd look killer IMO and shouldn't even glare under the shroud.  To clarify, that'd be $200 total for the fish scale swirl design work done on the aluminum panel done & shipped.  It might take a bit longer, but he's attiment about wanting each one done just right.  LMK asap what you want exactly.
Edited by mstieg, 16 May 2013 - 10:54 AM.
#34 creakyjoints
creakyjoints
  • 1,939 posts
Posted 16 May 2013 - 04:41 PM
Money sent for aluminum!
#35 mstieg
mstieg
  • 6,178 posts
Posted 18 May 2013 - 11:22 PM
I dropped by the shop and they've been very busy lately.  I hope to verify the turn signal hole adjustment Mon or Tues. and he will make yours all then within a day or two.  Thanks for your patience.
btw - wiring on these looks promising, although I'll need to test it in the car before guaranteeing how to work it all out.  Currently, the engine is still out.  Basically some wires will be snipped from the plugs to prevent current to the green circuit sheet that may touch & short elsewhere and rerouted instead to new gauges.  Most of the green sheet is for back lighting and stock gauges that's all gone.  Turn signals & warning lights remain intact and functional using lower centralized part of the green sheet.
Edited by mstieg, 18 May 2013 - 11:25 PM.
#36 mstieg
mstieg
  • 6,178 posts
Posted 25 May 2013 - 03:12 PM
Good news!  I saw the final adjustments today and it looks perfect. Turn signals line up just right now. He's running out the 2 paid plastics today. I should be able to pick up & ship next week. Creaky, yours might take a little longer as he needs to have the 5 gauge holes removed from the program.
Sorry for the lag, the CNC shop has been slow to get to this now as they've been real busy.  This is really just a side project my buddy is doing with the programming help of his boss.  Can't make these any better tho.
Edited by mstieg, 25 May 2013 - 04:57 PM.
#37 mstieg
mstieg
  • 6,178 posts
Posted 25 May 2013 - 04:55 PM
Creaky - your alum. Panel without gauge holes should also be going out next week. He's running it today.
#38 creakyjoints
creakyjoints
  • 1,939 posts
Posted 25 May 2013 - 07:32 PM
All good. Not stressing at all.
#39 kidjc
kidjc
  • 2,273 posts
Posted 26 May 2013 - 11:12 AM
Ya know... that looks great! But for what ever reason (it's been so long since I had a Trans Am 1975-76') the swirls are a bit different, & looks smaller, maybe not fish scale???, from what my minds recall remembers? (make sense?) However, it's "On Track!" I am open to this yes, I can PMya to go over the details, is that cool?   Thanx! ;)
#40 mstieg
mstieg
  • 6,178 posts
Posted 02 June 2013 - 11:45 AM
They are done, packed, & will go out Mon.
Also tagged with one or more of these keywords: gauge, cluster, dash, Autometer, replacement, overlay, panel, 5 gauge, aluminum, plastic
