Fuel pump cover redesigned
19 replies to this topic
#1 artinist
artinist
  • 7,308 posts
  • Interests:Favorite Food:E46 M3
Posted 01 June 2006 - 02:20 AM
ok, so you wanna have quick easy access to the pump and the surounding area?  this is how it should have been done in the first place.
here is the teaser of an access panel.
next grab some aviation snips and start chumping. the largest practical hole is about 20"x5" , you can't make it wider than that easily for the following reasons.
1. the surounding material beyond that is double layer and hard to cut
2. you need some material on the side of the spare tire for the new cover to sit against.
3. you don't need a bigger hole
the edges at this point are going to be pretty sharp and dangerous.
take a pair of channel locks or something similar and flatter the edges then get a grinding bit of some kind and put it on the drill and grind down all sharp edges. finaly get a 100 sandpaper and make sure no sharp edges are left or else you will end up cutting yourself at some point.
you will notice how much easier it is to work in the area now with all that space available. so now its a good time to inspect the in-tank fuel filter and also check for rust in the tank. read the service manual if you don't know how to do this safely.
now put a piece of cardboard on the cover and tap on it with a hamer so the opening will leave an indentation of the outline on the cardboard. cut the cardboard 1/2" larger than the opening and then transfer that into some kind of metal cover for the top. i used a thin piece of aluminum.
anyone wanna use plexyglass? lol
get some kind of weatherstriping from the hardware store for the buttom side to prevent dirt and sound from coming inside the car.
drill some holes and use 1/2" long sheet metal screws to fasten the cover
:wink: [/img]
88 Starion - 341rwhp@23psi on 91 octane - sold
97 3000GT VR4 - Sold
#2 Sully
Sully
    is SQ and Headache free!!
  • 4,739 posts
  • Interests:88 KBS MKIV F500
    03 Chevy S-10
    92 Mazda Miata
Posted 01 June 2006 - 02:22 AM
very nice.... never could figure out why they made that space so small
QUOTE (dstar88 @ May 4 2009, 11:55 AM)
I woke up naked with a dead deer next to me and blood everywhere..so i think i had fun..
A wise man once said:
"if you cant afford to do it right the first time, you damn sure cant afford to do it TWICE"
#3 GoFastBeater
GoFastBeater
  • 2,599 posts
Posted 01 June 2006 - 04:54 AM
I only pulled one gas tank.  The next two cars this is exactly what I did.  Much easier and faster!
ADAM
SOLD--89 SHP, sy/ty 20g, custom header, 52mm intake/tb, 284 cam, MAFT, 3" exhaust, hardpipes, Greddy BOV............
#4 Boosted_One
Boosted_One
    Addicted Starquester
  • 15,981 posts
  • Interests:It's all about BOOST!
Posted 01 June 2006 - 05:48 AM
great writeup Art, I'm gunna throw this in the FAQ later...
Mike K
#5 MrTurbo
MrTurbo
  • 247 posts
  • Interests:'90 Mighty Max...to be converted. (Hopefully)
Posted 01 June 2006 - 07:09 AM
Very nice Art...glad to see my question motivated another piece of beauty out of you wink.gif I took your advice on the front grille...came out sharp, I'll have to post some pics later.
Take it easy,
Lee
'90 Mighty Max
#6 shogun
shogun
  • 765 posts
  • Interests:cars cars cars
Posted 01 June 2006 - 07:51 AM
well done!!!! I like how clean of a job you did!!
1987 quest
2002 camaro Z28 35th aniversery edition (NEW!)
1993 camaro (v-6)
1979 chevy malibu ... 350ci worked to the balzz!!
      (11.4 in the 1/4 )
#7 JAinsworth
JAinsworth
  • 16,871 posts
Posted 01 June 2006 - 08:14 AM
I did basically the same thing, but used Dyno-mat to cover the metal plate.
Jimmy
#8 chiplee
chiplee
    Advanced Slacker
  • 10,489 posts
  • Interests:Yes
Posted 01 June 2006 - 08:21 AM
I did the same thing about 7 years ago and never covered it with anything.  I almost never drive in the rain.  A drain hole in the bottom of the spare tire area would fix any water problem though.
Posted Image Posted Image
'88 TSi, 06H-20G, HAWK, Roller cam, Water inj, etc^10 320whp/370wtq
#9 MontyTSI
MontyTSI
  • 8,557 posts
  • Interests:Spliting Atoms
Posted 01 June 2006 - 08:28 AM
good job art!!
pm your address and/or paypal concerning the items we pmed each other on so i can get the money to you.
take care,
monty
A CERTIFIED EXPERT IN SPOTTING THE OBVIOUS :)CTS-V, 1961 MGA MKII, Aprilia rsv1000 factory, ducati 900ss (not stock), 1988 mighty max 4x4 4.22 geared, 1987 TSI, 1987 flatty
#10 YELLOWHELL
YELLOWHELL
  • 2,535 posts
Posted 01 June 2006 - 11:02 AM
I've been debating doing this very thing. I didn't want to hack it all up though. It's nice to see a finished product that I would put in my own car. Looking good man.
#11 Shelby
Shelby
    Rookie
  • PipPipPipPipPipPipPipPip
  • 50,164 posts
Posted 01 June 2006 - 12:00 PM
lets look at  this way the factory want'd you to drop the tank so  cleaning and inspecting it would be a normal thing to do,,with  these cars seting for many years some times , cleaning the tank is unavoidable , and  if you neglect doing it,, clog'd injs and will result  ,or fuel starvation
while this  may work  just  how often  will you be changeing the fuel pump,,once every 18 years or so,, hardly  a reason to cut holes in the  floor of the car huh , get over it guys , it won't kill ya to do a little work,, 30 min at most to drop the tank
88TSI Silver
89TSI red auto
#12 Casey_L
Casey_L
  • 3,229 posts
  • Interests:Keep dirt away from the impeller!
Posted 01 June 2006 - 12:16 PM
We have changed the fuel pump in my friends rx-7 multiple times, its so easy to change it on thoes cars.
My Feedback
87 Mitsubishi Starion - Project Car
MS2-Extra 3.03y Firmware GM LS1 Coils, Wasted Spark
14.366 @ 100.10 Mph  - 12A, 17psi @ New England Dragway
#13 Dcrasta
Dcrasta
  • 6,359 posts
Posted 01 June 2006 - 12:57 PM
whats next? female chest appendage implants?
CLICK My CAR For Mods Info
MY_CAR_RUNS_ON_PARTS_FROM_DAD
Downloadable-88-FSM
Professor-Q's_FAQ
#14 artinist
artinist
  • 7,308 posts
Posted 01 June 2006 - 01:13 PM
my car has 200k miles on it and the tank was clean as an 18 year virgin. its not really that the tanks rust when they sit around. they rust when they spend most of their life empty. when the tank is empty, moisture builds on the inside wall, especially in cold weather. a tank thats kept with fuel in it will not rust.
#15 Mazarin
Mazarin
    Is so oldschool, he datalogs with an Apple IIe
  • 3,693 posts
Posted 01 June 2006 - 01:40 PM
I love Dremel.
Pardon my ignorance, but instead of sniping, can I use a dremel or is there a safety issue w/ that?
First one: Red 88 - 245whp/312wtq - HIN: Nightshift - Chicago '07 WINNER
Second one: Durban 88 - Buckskin - SHP - Auto - Sold to to capable hands
Third one: White 84 Flatty - T3/T4 - GM MAS/MAFt - VELNAS - Sold to local capable hands
"...Remember: Don't crush 'em, restore 'em!"
#16 Shelby
Shelby
    Rookie
  • 50,164 posts
Posted 01 June 2006 - 01:52 PM
a full tank may have work'd 15 years  ago but  you better beleave  leaveing this junk they call gas in a tank full or not , will result in  the tank being useless , rust is not a  problem   acid will eat that away in a heart beat,, it's the seperate'd fuel that is the  real problem,, almost pure tar is  seperate'd out of the gasoline , and that my firends we did not have in the old cheap gas ,i guess adding it is what  makes the cost so high  for  distilling todays  gas  ( or not takeing it out  hehe )
way over 50% of todays gas  will not burn  alone , so what about it is so espensive  if it's not the  gas  what is their useing  to make a filler for it ,
truth be  known  they are skiping distillation  steps and adding in   non burning fillers,,to increase their  proffet from the sales
why cause they can
88TSI Silver
89TSI red auto
#17 chiplee
chiplee
    Advanced Slacker
  • 10,489 posts
  • Interests:Yes
Posted 01 June 2006 - 02:18 PM
QUOTE (Shelby)
yeah, actually the factory access panel is meant for access to the electrical connections, and for pure visual inspection. for leaks and such.  I don't mind having a cut trunk and when I was 18 I didn't know any better so I cut it.
#18 GoFastBeater
GoFastBeater
  • 2,599 posts
Posted 02 June 2006 - 02:31 AM
QUOTE (Mazarin)
I love Dremel.
I did once, but won't again.  Sparks + fumes = ugly.  Just ask freebird.  laugh.gif   laugh.gif   laugh.gif   laugh.gif
Buy yourself a cheap set of tin snips for $15 at harbor freight.
ADAM
#19 ZPI28
ZPI28
  • 5,696 posts
  • Interests:Im just interested
Posted 02 June 2006 - 09:16 AM
I used a dremel to cut mine open, but I didnt use a cut off wheel. I pulled the tank on my first pump, car sat for 11yrs and had to clean the tank. Then on the second,third,and forth fuel pump I used the access hole. Then I decided to put in another tank, because the rust was killing me, and I dropped it again and replaced it with a clean one from richie rich. 2 weeks ago I got a Walbro and replace my master E8000 with it. I used the very convient access hole, but I hope its done now. I also used some aluminum tape to cover the seams with>
Steven
#20 Kellydahman
Kellydahman
  • 3,943 posts
Posted 02 June 2006 - 09:25 AM
Nice cover there Art. I'd cut the hole in a milisecond before wasting 30 minutes of my time dropping a fuel tank just to replace a stinkin pump...
Here in Cali there are plenty of gas tanks at the junk yards to if it's bad it's no big deal..
CUT. CUT. CUT..... :wink:
