bigmandsm Posted June 3, 2009 Report Share Posted June 3, 2009 (edited) Megasquirt powered fuel only for now mx6 intake enjoy! My first starion vid nothing big couple with it idling Edited June 3, 2009 by bigmandsm Link to comment Share on other sites More sharing options...
BrazilBoy Posted June 3, 2009 Report Share Posted June 3, 2009 Nice setup how hard was it to port match it? FIXED Link to comment Share on other sites More sharing options...
bigmandsm Posted June 3, 2009 Author Report Share Posted June 3, 2009 believe it or not not bad what i did was used a thick piece of metal for the sandwich plate and contoured it to the ports Link to comment Share on other sites More sharing options...
BrazilBoy Posted June 3, 2009 Report Share Posted June 3, 2009 believe it or not not bad what i did was used a thick piece of metal for the sandwich plate and contoured it to the ports How much "countouring' was required? 1mm, 2mm more? Link to comment Share on other sites More sharing options...
Scotty Dont Posted June 3, 2009 Report Share Posted June 3, 2009 Nice, I used the mx6 fuel rail and welded some bungs onto the stock manifold. Link to comment Share on other sites More sharing options...
bigmandsm Posted June 3, 2009 Author Report Share Posted June 3, 2009 I cant say in mm think of it as porting i will see if i can dig up some pic's with the plate when look at it with head bolted on it flows with the port as if the head was extended Link to comment Share on other sites More sharing options...
jinx Posted June 3, 2009 Report Share Posted June 3, 2009 Cool u got another up and running there was a site years back, with full details and lotsa clear photos, showing the MX6/probe intake-to-G54 adapt. I saved the link somewhere on my pc. Can't find it Link to comment Share on other sites More sharing options...
bigmandsm Posted June 3, 2009 Author Report Share Posted June 3, 2009 yeah this is the 2nd car the first one a junked I had a conquest but the rear 1/4 panels were rotted found a starion and swap everything over both cars are the same color look like twins Link to comment Share on other sites More sharing options...
Dave-O Posted June 5, 2009 Report Share Posted June 5, 2009 Interesting. Someone please post up pics and details, I'm very interested. What year MX6 is this intake from? There are several in junkyards around here, and I'm looking for any excuse to use pre-fabbed parts. Link to comment Share on other sites More sharing options...
bigmandsm Posted June 5, 2009 Author Report Share Posted June 5, 2009 Interesting. Someone please post up pics and details, I'm very interested. What year MX6 is this intake from? There are several in junkyards around here, and I'm looking for any excuse to use pre-fabbed parts. you can use a 1989 when you install get the intake gaskets from both trace the pattern drill the starion hole all the way thru the mazda hole counter sink bult to head with allen heads Link to comment Share on other sites More sharing options...
Couth'nize Posted June 5, 2009 Report Share Posted June 5, 2009 Can you post pics of your thermostat housing? I'm stuck there for now. Link to comment Share on other sites More sharing options...
bigmandsm Posted June 6, 2009 Author Report Share Posted June 6, 2009 Can you post pics of your thermostat housing? I'm stuck there for now. ok i will try to find pic but i will explain first the housing is welded to the sandwhich plate not the intake squared at the flange end that part takes time to weld so the intake does not sit on the weld Link to comment Share on other sites More sharing options...
Dave-O Posted June 7, 2009 Report Share Posted June 7, 2009 Definitely in for pics. This could be the mod for '09 right here. Link to comment Share on other sites More sharing options...
dem0ntsi Posted June 8, 2009 Report Share Posted June 8, 2009 wow that sounded MEAN as #*$@ :thumbsup: I wonder what kind of numbers it will put up? Link to comment Share on other sites More sharing options...
jinx Posted June 8, 2009 Report Share Posted June 8, 2009 This could be the mod for '09 right here hmmm... not quite, for '04 maybe - lol http://www.geocities.com/turbocraft29/red2.html at one point he ran mazda electronics also. He posted a good bit of info on his setup a few years back "boostandmuscle" posted his install details, a couple years ago also Link to comment Share on other sites More sharing options...
Dcrasta Posted June 8, 2009 Report Share Posted June 8, 2009 Hows the timing control? Looks like the Starion Dist in there. Nice work man glad u got here idling. Link to comment Share on other sites More sharing options...
BrazilBoy Posted June 9, 2009 Report Share Posted June 9, 2009 Definitely in for pics. This could be the mod for '09 right here. I agree I dig you can the stock distributor..It looks almost factory in there... Link to comment Share on other sites More sharing options...
bigmandsm Posted June 9, 2009 Author Report Share Posted June 9, 2009 Well I dont have any pics of the flange up close but will answer any ?'s I swear that it is so simple anyone can do it with some welding and the write up in 04 is what inspired me to do it Ok tommorrow is my day off I promise to take some pic up close installed on car. Link to comment Share on other sites More sharing options...
bigmandsm Posted June 9, 2009 Author Report Share Posted June 9, 2009 (edited) this is rough but a little idea www.bigmandsm.mysite.com/cgi-bin/photoalbum/view_photo/2180762 Edited June 9, 2009 by bigmandsm Link to comment Share on other sites More sharing options...
Couth'nize Posted June 9, 2009 Report Share Posted June 9, 2009 Thanks for the pics....I like the way you did the back coolant line. http://img14.imageshack.us/img14/5192/2063474l.jpg Link to comment Share on other sites More sharing options...
bigmandsm Posted June 9, 2009 Author Report Share Posted June 9, 2009 Thanks for the pics....I like the way you did the back coolant line. http://img14.imageshack.us/img14/5192/2063474l.jpg Man thankyou I was looking every where my harddrive got damage and had to fdisk it lost all my old pics only had the ones from my site where did you find that one? Link to comment Share on other sites More sharing options...
bigmandsm Posted June 9, 2009 Author Report Share Posted June 9, 2009 I feel like a dumb a** the pics are on my website sorry guys i was very tired last night Link to comment Share on other sites More sharing options...
BrazilBoy Posted June 9, 2009 Report Share Posted June 9, 2009 Could you do a basic write up with pics for us please..... Link to comment Share on other sites More sharing options...
jjooc Posted June 9, 2009 Report Share Posted June 9, 2009 yes please do a basic write up.. as far as i kno.. you used a 88-89 mx6 intake manifold.. but came off of what.. the 2.0, 2.2 n/a, or 2.2 turbo.. and.. exactly.. what did you do for the bolting up process.. face that meets the head.. idk what that is called.. you kept the stock face form the mx6 intake.. and made like a spacer and.. like.. ported and flowed to match the starquest.. .. are the injectors the stock that came with the mx6 i/m and.. i can see the coolant line.. um.. and the the megadquirt to do the wiring.. how'd you wire up the injectors.. and the hole electrical setup.. kicks a** setup .. but i think we all would like to no.. the if's and buts.. please do tell... Link to comment Share on other sites More sharing options...
Couth'nize Posted June 10, 2009 Report Share Posted June 10, 2009 I had almost forgot about my old post. Let me hijack this.... Here's my setup as of now... Link to comment Share on other sites More sharing options...
