BOHO and a Magna
255 replies to this topic
#1 BOHO
BOHO
    Sucks at life
  • 5,102 posts
Posted 11 April 2009 - 04:50 PM
Well....I'm no Chad but I think I did ok.....
Until I put the water neck on...lol....Gonna have to do something with the water neck...not sure what yet....but overall happy with the progress on the magna...I havn't put it on yet but did the modding myself.
lol...can you see my problem....
I figured since I'm already having so many problems...I might as well.......
Still have to redo the ports and might have do do something with the throttle cable bracket....not sure if its even close to what it should be....
Edited by BOHO, 11 April 2009 - 04:51 PM.
87 Starion 2jz
#2 CONQUEST POWER
CONQUEST POWER
  • 147 posts
Posted 11 April 2009 - 05:11 PM
#3 quikconq
quikconq
  • 5,025 posts
Posted 11 April 2009 - 05:31 PM
yes looks good
i think there are several different water necks
some with a little different angle,,and shorter
FEEDBACK PAGE,,,,please leave some feed
http://www.starquest...pic=121065&st=0
#4 BOHO
BOHO
    Sucks at life
  • 5,102 posts
Posted 11 April 2009 - 05:42 PM
Hmm...I didn't know that...I'm also not sure what to do with the fuel rail yet...I'm using a aeromotive...Trying to find a T fitting for the rear...and not sure how I want to cap the factory hole yet...
87 Starion 2jz
#5 Chad
Chad
    noob
  • 9,182 posts
  • Interests:Starquest Fanatic
Posted 11 April 2009 - 06:02 PM
Did you not get the black plastic fuel rail spacers?  you'll need them...
grind down the factory regulator boss flush and drill/tap it for a 1/8" NPT pipe plug .  Then drill/tap the capped end for a return line.
Use a metric-to-AN banjo fitting, or drill/tap for a 90* AN fitting.
#6 BOHO
BOHO
    Sucks at life
  • 5,102 posts
Posted 11 April 2009 - 06:07 PM
No I didn't get the spacers with mine.....I also need gaskets....anyone have any info on that?
87 Starion 2jz
#7 substock
substock
  • 3,993 posts
Posted 11 April 2009 - 06:30 PM
QUOTE (BOHO @ Apr 11 2009, 07:07 PM) <{POST_SNAPBACK}>
do as chad said with the stock fpr hole
i tapped mine 1/8" and put my fp gauge sensor in that hole
'89 Conquest
#8 Technology
Technology
    TheNerdyProfessor
  • 11,394 posts
  • Interests:Lots of boost!
Posted 11 April 2009 - 10:22 PM
I made my own gaskets for the upper plenum and TB, you can find DIY gasket material at some auto parts stores.
Definately move the water neck to clear the intake, mine is about 1/4" or so away from the radiator hose, and I think some heat is absorbed from that when idling at least.
#9 RichyQuest87
RichyQuest87
  • 662 posts
http://www.shop.trilogyturbos.com/product....amp;productId=5
My injector bosses on my OG magna fuel rail leaked so bad and finding a replacement was next to impossible I found one of these on ebay.  The ends are 6AN on both sides and no regulator hole to plug.
87 Conquest TSI:  Schiender 274 cam, T-70, Tial 38mm WG, Manga Intake, 1000cc injectors, MSII, EDIS, ACT 6-puck clutch with X-treme PP, Fidanza, AEM UEGO, big doggin FMIC
#10 BOHO
BOHO
    Sucks at life
  • 5,102 posts
Posted 15 April 2009 - 04:19 PM
Well...I got my stock intake off today...My intake valves look HORRIBLE.....#4 is way worse than the others but they have alot of build up on them....Anything I should do while I can see them...without pulling the head...?
87 Starion 2jz
#11 jisleyjr
jisleyjr
  • 1,265 posts
Posted 16 April 2009 - 09:25 AM
QUOTE (BOHO @ Apr 11 2009, 06:07 PM) <{POST_SNAPBACK}>
I think i recall reading in a past thread about finding these spacers on an eclipse, 2.0L or 1.8L engine.
1988 Conquest, Fiji with blue/grey cloth interior. Magna MPI/MS2/EDIS-4, D2's, td05h/s16g
1987 Starion, Black Ext and Black Leather, parts car :(
1983 Starion, Black Ext and grey cloth interior, driveway queen
2006 Acura TL, Anthracite Ext with Black Leather, rolling on 18's.
#12 BOHO
BOHO
    Sucks at life
  • 5,102 posts
Posted 16 April 2009 - 06:05 PM
This is going to be be a little harder than I thought...lol....Might take a while....lol
Edited by BOHO, 16 April 2009 - 06:19 PM.
87 Starion 2jz
#13 PDodson
PDodson
    Mr Starquest
  • 3,902 posts
Posted 17 April 2009 - 06:01 AM
An 87 style thermostat housing should work for ya....its shorter than the 88 style
1988 Durban Maroon Auto
MPI
#14 BOHO
BOHO
    Sucks at life
  • 5,102 posts
Posted 17 April 2009 - 05:00 PM
Is there any special reason that the vacum source for the  brake booster is setup for #4 cyl? Can I just put it on the plenum?
87 Starion 2jz
#15 Minagera
Minagera
    The Petulant Child
  • 3,317 posts
Posted 17 April 2009 - 05:03 PM
QUOTE (BOHO @ Apr 17 2009, 05:00 PM) <{POST_SNAPBACK}>
We take the vacuum from the back side of the manifold to the booster.
88 Conquest, White with Maroon Interior 5-speed. (Bought with Seize Engine and hasn't been touched since)
http://sosmanuals.minagera.org/
#16 BOHO
BOHO
    Sucks at life
  • 5,102 posts
Posted 17 April 2009 - 05:06 PM
from the plenum?
87 Starion 2jz
#17 Minagera
Minagera
    The Petulant Child
  • 3,317 posts
Posted 17 April 2009 - 05:10 PM
QUOTE (BOHO @ Apr 17 2009, 05:06 PM) <{POST_SNAPBACK}>
from the plenum?
Yup where the threaded hole is.  I re-tap it and put a brass 90* fitting with and then a barb fitting in that.
#18 Chad
Chad
    noob
  • 9,182 posts
Posted 17 April 2009 - 05:38 PM
I put mine on the #4 runner because that is where the stock hose went, that way you don't need to buy a new hose.
Functionaly speaking, you can put it anywhere after the throttle body adn before any injector (like the plenum).
#19 BOHO
BOHO
    Sucks at life
  • 5,102 posts
Posted 17 April 2009 - 08:44 PM
Thanks....This aluminum sux....My taps are coming out pretty messy....I'll be able to get them to seal but damn....Its odd to me...real coarse or something...I finished it today...Now I've got to get the fuel setup and finish the wiring.....I'm still not sure what to do on the intake gasket also. I bought one for the tbi manifold and that rear water port is too tall for the magna...Does any one have a link to some info I could look at?
87 Starion 2jz
#20 Chad
Chad
    noob
  • 9,182 posts
Posted 17 April 2009 - 09:05 PM
You need to fill that port in and re-sise it to US spec.  Either that or make an adapter plate that can sndwich between the head and intake, but that will then require both US and aussie gaskets.
Are you using lube on your taps when you cut the threads?
