Ok so im getting rdy to do the mpi swap
i hope i have everything i need
Intake ordered from Lee (should have it in week)
msII v3.57 and harness
iat sensor with pigtail
cts with pigtail
4 75lb/hr low impedence injectors
4 inject pigtails
iac
iac block to mount iac
iat bung
mk1 crank pulley 36-1
mk1 dizzy block off plate
mk1 vr sensor bracket
ford edis-4 peices
*DM alum radiator
*DM 4" intercoller
and a bunch of different charge pipes
the only thing im not sure on is the tps sensor i know Lee uses a ford throttle body on his intakes but im still not sure what tps to get and use
other than this am i forgetting anything
other than the intake everything should be here by friday
when i get started on it i will post pics along the way for everyone to see
here is my starting point
http://i640.photobucket.com/albums/uu127/hoskinsr/IMAG0001.jpg
thx guys
  • Replies 96
  • Created
  • Last Reply
Top Posters In This Topic
Make sure you have a six pack, some good friends, and lots of patience at your disposal.
As for the TPS, ask Lee which one he uses. I could tell you but my car is four hours away. I got it from him. It is probably the most commonly found ford TPS sensor out there. It may take a little bit to get your intake in but it is all worth the wait in the end.
Edited by YoungQuestFan
ok got my intake from Lee today
just shot some paint on it (doing the wrinkle finish on it and its has just started to wrinkle now)
here are a few pics
http://i640.photobucket.com/albums/uu127/hoskinsr/IMAG0012-1.jpg
http://i640.photobucket.com/albums/uu127/hoskinsr/IMAG0013-1.jpg
just got the engine back in the car so everything is comming right along
Take everything out and start by putting back one thing at a time, that the engine needs to run. You won't have much left by that time other than abs, power steering... ect. You need to have a wiring diagram for the car, that will tell you what things under the hood are for so you can figure out if you are going to need them or not.
Why did you paint it? That thing was purrrdy :( Do you have any pictures of it before?
Edited by maxboost87
worked on the car for a couple of hours taday here are some pics
http://i640.photobucket.com/albums/uu127/hoskinsr/IMAG0016.jpg
http://i640.photobucket.com/albums/uu127/hoskinsr/IMAG0015.jpg
http://i640.photobucket.com/albums/uu127/hoskinsr/IMAG0014.jpg
Sorry Lee not much on polished stuff to much work to keep up (but it did look nice)
another update sorry for the crapy pics its dark outside now
I only get about an hour to work on it each night
http://i640.photobucket.com/albums/uu127/hoskinsr/IMAG0020.jpg
does the vr sensor look lined up right ?
http://i640.photobucket.com/albums/uu127/hoskinsr/IMAG0019.jpg
http://i640.photobucket.com/albums/uu127/hoskinsr/IMAG0018.jpg
let me know what you guys think and if you see something i need to change please let me know
just an update i will get some pics up later its been a long day
i got the front d2's on and the front polly bushings and new mk1 front sway bar all done today
my new intercooler came in today it is a beast ill get some pics of it up later also
right now im about half way dont with my wiring harness then i need to get the exhaust manifold on and waiting for the new turbo to get here should be here tues next week
just ordered the schneider 284 cam and valve springs should have it thursday or friday
with that turbine housing you will not be able to take advantage of that cam. i made same mistake.
good build otherwise:)
so i made a little more progress tonight
http://i640.photobucket.com/albums/uu127/hoskinsr/IMAG0054.jpg
http://i640.photobucket.com/albums/uu127/hoskinsr/IMAG0055.jpg
http://i640.photobucket.com/albums/uu127/hoskinsr/IMAG0056.jpg
http://i640.photobucket.com/albums/uu127/hoskinsr/IMAG0057.jpg
down pipe looks like it might get interesting but ill figure it out
Looking good. Curious as to the "not being able to take advantage of the cam" comment though. Someone care to explain for this n00b here? :lol:
we shall see in a couple of weeks i hope i just need to find the time to get it finished
i almost have all the wireing done
then i have to get the down pipe done
and the rear suspension
