Manual Brake Conversion: Parts List
52 replies to this topic
#1 speedyquest
speedyquest
  • 3,925 posts
Posted 05 April 2016 - 10:32 AM
Wilwood Parts:
Wilwood Compact Master Cylinder Kit: 260-10374 = $80.00
Wilwood Adjustable Proportioning Valve: 260-8419 = $45.00
Wilwood Brake Master Clevis: 330-13192 = $16.00
Fragola Fittings:
Tube Nut: FRA-481803-BL X 5 = $1.00 each
Tube Sleeve: FRA-481905-BL X 5 = $1.00 each
3AN to 1/8" NPT Adapter: FRA-481603-BL X 1 = $4.00
3AN to 1/8" NPT 90 Deg: FRA-482203-BL X 1 = $7.00
3AN Tee w/ female swivel: FRA-498201-BL X 1 = $18.00
3AN Tee w/ 1/8" NPT side: FRA-482503-BL X 1 = $8.00
JDL Parts:
Brake Master Adapter Plate (includes hardware) = $40.00
Portfield Parts:
Portfield R4S Front Pads: AP389-R4S = $72.00
Portfield R4S Rear Pads: AP144-R4S = $63.00
Notes:
I used Fragola fittings because I really didn't want to trust no-name fittings, you could save a bit of money if you went with the ebay stuff but I personally wouldn't suggest it.
When you go to order these things remember this is just what I needed for my specific setup and you could plumb this other ways. I figured you guys would appreciate a clear path to follow and a break down of cost so you can decide for yourself if this is right for you.
I'll be updating this as I finish this project. I'll include some pictures and also what I think of the car both with stock pads and the Portfield ones. I'll keep ya posted!
Edited by speedyquest, 05 April 2016 - 10:34 AM.
#2 BC_99
BC_99
    Plays in traffic
  • 5,172 posts
Posted 05 April 2016 - 10:56 AM
Nice write up. Thank you for taking the time to do this.
BC
#3 speedyquest
speedyquest
  • 3,925 posts
Posted 05 April 2016 - 10:57 AM
No problem at all BC, I see people talking about this semi regularly and I figure maybe if the info is available more people might take the dive lol.
Edited by speedyquest, 05 April 2016 - 10:57 AM.
#4 psu_Crash
psu_Crash
  • 7,036 posts
Posted 05 April 2016 - 11:29 AM
Great stuff Speedy! Looking forward to some pics of the install. Specifically in the engine bay side. If there is already a thread with that .. then I apologize :)
My Feedback Link
#5 speedyquest
speedyquest
  • 3,925 posts
Posted 05 April 2016 - 11:33 AM
No need for apology psu_Crash, if you want to see some early pictures I have a few in my build thread. I actually just finished plumbing it last night but it was so dark out I just couldn't take a picture. I'll take some tonight and post them here.
Build Thread --> http://www.starquest...c=143564&st=400
#6 Dred_85.5_TSI
Dred_85.5_TSI
    Flatty Love
  • 2,211 posts
  • Interests:I have an announcement to make, "Turbo........ That is all".
Posted 05 April 2016 - 04:59 PM
Thanks speedy! I'll probably be referencing this when I work on converting my 84. I can't wait to see pics of this setup. Good job :)
Posted Image   1984 Starion ES: Currently running 15psi, Stock block (ARP main and head studs rod bolts, Clevite bearings) BSEK, M28 NJV head with mechanical valve train gasket matched on intake and exhaust, Treadstone exhaust manifold and Holset HX35w with BEP turbine housing, MK1 3" stainless exhaust, Old skool HKS super BOV, 3" GM MAF with MAFT, Artinist's old 4" core intercooler, custom Aluminium hard pipes, S13/SR20 Aluminium radiator w/clutch fan, Innovate LC-1 wide band O2, `83 crank pulley with A/C removed.
   `88 5 speed trans with Stedbani short shifter, Stedbani poly trans mount and engine mounts, drilled and slotted rotors, Joly roger stainless steel braided lines(brake, clutch, oil cooler, and ABS delete).
   KYB GR2, Artinist sleeve coil-overs, MK1 poly bushings, Energy Suspension poly end links, MK1 Adjustable tension rods, Cusco front camber plates, Artinist slotted rear camber plated.
ABS, A/C, Cruise control.. deleted, Right hand drive E-brake handle.
... more to come
Feedback:
Feedback thread #1
Feedback thread #2I'm PayPal Verified
#7 speedyquest
speedyquest
  • 3,925 posts
Posted 05 April 2016 - 07:38 PM
Here is a close up of how everything is plumbed on the firewall. After doing this I'm not happy with how everything is ran aesthetically so I'll be redoing it. But mechanically this will work perfectly.
#8 speedyquest
speedyquest
  • 3,925 posts
Posted 05 April 2016 - 07:40 PM
.... Soooo I literally just posted this picture and immediately noticed I plumbed it wrong. For fun I won't post what's wrong immediately, I'll let you guys take a crack at it first.
I deserve whatever witty jabs you guys feel like sending my way... Ugh
That's what happens when you rush. My only saving grace is I planned on replumbing the whole car after moving it the 6 blocks to my new shop anyway.
Edited by speedyquest, 05 April 2016 - 07:42 PM.
#9 speedyquest
speedyquest
  • 3,925 posts
Posted 05 April 2016 - 07:45 PM
And just a view to show the difference in space available now.
#10 importwarrior
  • 18,108 posts
Posted 05 April 2016 - 07:55 PM
great write up. i would like to put this in the FAQ section.
#11 speedyquest
speedyquest
  • 3,925 posts
Posted 05 April 2016 - 08:07 PM
Feel free importwarrior but wait until I finish it so I can edit it.
#12 importwarrior
  • 18,108 posts
Posted 05 April 2016 - 08:10 PM
i was just going to copy your first post and your pic and a link to this post so if people have questions thay can post them here.
#13 speedyquest
speedyquest
  • 3,925 posts
Posted 05 April 2016 - 08:18 PM
Definitely don't post that picture yet please. Go up and read my post. I plumbed that wrong... LOL
See if you can figure out what I did. I'll post a new picture after I fix my blunder.
#14 Funky Phil
Funky Phil
    Super Pooper
  • 6,413 posts
Posted 06 April 2016 - 12:51 AM
Looks like the front driverside is gonna go bald.
#15 cyberquest
cyberquest
    Power Poster
  • 4,963 posts
Posted 06 April 2016 - 01:07 AM
i love the simplicity of it and the space it frees up, i think i would want to drive one to see how it feels but i like the idea behind it.
2005 Acura RL SH-AWD
#16 speedyquest
speedyquest
  • 3,925 posts
Posted 06 April 2016 - 07:30 AM
Ding ding ding we have a winner. I mistakenly plumbed the drivers side front into the rear calipers position. I'll fix that and get a new picture up.
#17 speedyquest
speedyquest
  • 3,925 posts
Posted 13 April 2016 - 08:23 AM
I can report that the manual brake conversion feels goooood! It was a short drive to the cars new home but in that time I was able to see how it felt at the very least and I'm pleasantly suprised. Because of other people talking about how much manual brakes sucked etc I expected them to not work well at all and to require tons of braking effort and that just was not the case. The cool thing is that the car still has the stock pads installed. Once I get the Portfield race pads on there the brakes are only going to feel better.
@importwarrior: I'll update the pictures when I can so you can do what what you wanted with the info.
Edited by speedyquest, 13 April 2016 - 08:24 AM.
#18 importwarrior
  • 18,108 posts
Posted 13 April 2016 - 10:59 AM
ok, no rush.
#19 Funky Phil
Funky Phil
    Super Pooper
  • 6,413 posts
Posted 14 April 2016 - 05:48 PM
People were referring to old crap. Some think technology stopped in the 60's when it is blatantly obvious that it wasnt halted until the mid 70's.
#20 cyberquest
cyberquest
    Power Poster
  • 4,963 posts
Posted 15 April 2016 - 11:24 AM
i had a mid 80s S10 with manual brakes. i think more important is the fact that cars of the 60s-70s where big old hunks of detroit steel and weighed as much as a delivery truck. i would imagine the light weight of the quest would be a whole lot easier to stop.
