Injector Clips?
Fuel Injection Fuel Injector
9 replies to this topic
#1 Pyre78
Pyre78
  • Newbies
  • 2 posts
Posted 03 April 2018 - 05:50 PM
Does anyone know where I could go about getting a fuel injector clip for a 1987 Conquest? The plastic that attach to the fuel injector to give it power is so old and dry it cracked when I was trying to remove it to check my fuel issue, and as these tend to go bad I suspect that these being so old might be the cause of my issues.
Anyone have any leads / know of any other cars I might be able to pull these from, or if I would be able to buy these new somewhere?
Thanks!
#2 croquest87
  • 1,395 posts
Posted 03 April 2018 - 06:05 PM
Engine Machine Service in Niles OH has them along w other parts for these cars check it out. By the way they are Bosch style injector conectors.Look them up online!
Edited by croquest87, 03 April 2018 - 07:51 PM.
#3 importwarrior
  • 18,244 posts
Posted 03 April 2018 - 06:27 PM
DAD on here has them.
http://www.enginemac.../electrical.php
#4 techboy
techboy
  • 3,273 posts
Posted 03 April 2018 - 09:51 PM
You can find them eBay and other places, but I say buy them on Importwarrior's link above from Dad - shop small and support the community.
#5 importwarrior
  • 18,244 posts
Posted 04 April 2018 - 12:53 PM
the reason to buy from DAD is the inner most part of the injector clip on our cars has a rounded edge if you get the wrong clips you could crack the injectors.
#6 CaliConquestAlex
CaliConquestAlex
    The Wrench
  • 2,387 posts
  • Interests:BOOOST!
Posted 04 April 2018 - 05:32 PM
LMAO...why would you order injector clips online when you can go to ANY junkyard and cut them off of pretty much any import car and probably take them for free.
#7 Evoz17
Evoz17
  • 158 posts
  • Interests:Mitsubishi's, soccer, life
Posted 04 April 2018 - 06:44 PM
Only if they still let you walk into the yards. No pick and pull yards anymore here in my area.
#8 Preludedude
Preludedude
  • 2,832 posts
Posted 04 April 2018 - 07:55 PM
People may want new ones....
#9 croquest87
  • 1,395 posts
Posted 04 April 2018 - 08:52 PM
Yup  new is new !
#10 Pyre78
Pyre78
  • Newbies
  • 2 posts
Posted 22 April 2018 - 07:01 PM
Got the new clips, turned out not to be the issue. Sorry about not replying, dudes! I'll make another post about my problem in just a bit.
