'86 year Starion won't hold idle
Started by stesir, Aug 14 2018 10:51 AM
10 replies to this topic
#1
Posted 14 August 2018 - 10:51 AM
hey there:
I got an '86.. nearly everything about the car is new or rebuilt, has the correct 1986 year components...
the motor is only able to start and run if you keep on pumping the gas pedal, in other words cannot get it to IDLE..
any help is much appreciated...THANKS!
#2
Posted 14 August 2018 - 11:03 AM
cross post
#3
Posted 14 August 2018 - 01:03 PM
Does it have the map and maf both working? Some 86 run better without maf. But map has to be used.
#4
Posted 14 August 2018 - 03:49 PM
When u turn the key to on .Can U here the nose idle say ZIPPPP ?? Have u done the TPS reset ??
Edited by markhansenconquest, 14 August 2018 - 05:23 PM.
#6
Posted 15 August 2018 - 10:20 AM
I thought the MAF and MAP was the same thing? IT def has an '86 airbox on it and all from MARK...I don't think I hear anything when the key is turned on to Electric position right before starting..it has the upgraded Canadien guy new TPS that he sells but I have no clue about that and my mech guy always says don't worry about that or we did it when I try and ask about resetting the TPS..
#7
Posted 15 August 2018 - 01:56 PM
You should have a MAP sensor (manifold absolute pressure) on your firewall with a vacuum line attached to it. That has to be there. Do you hear your fuel pump turn on? Did you just I stall the tps or did you do it properly and set the position using a volt meter?
#8
Posted 16 August 2018 - 08:48 PM
if u don't here the nose switch go ZIPPP ...Check the wires that go to the elec motor , sometimes the wires are broken inside the rubber boot .........
#9
Posted 17 August 2018 - 06:09 PM
Guys how do you post pics or someone here please give me your email where you can post the pics please? Thanks
#10
Posted 17 August 2018 - 07:40 PM
Download Imgur you can upload pics to here or link to here l use it all the time and it works good.
#11
Posted 11 October 2018 - 06:37 PM
Please see updates in virtual mechanic board, I’ll post in there from now on...1 thing I wish I could go to a large star quest meet with this car because I know with you guys it be running no problems. Thanks
