High high idle??
3 replies to this topic
#1 hondaiceman
hondaiceman
  • 472 posts
Posted 01 December 2019 - 08:40 PM
Rebuilt motor, 16g all new seals n gaskets.
I start the car and it revs to 6000 rpm.
If I take the piping off it runs alot better.
I have trilogy injectors that seemed clogged, then I had them cleaned. Ever since that it over revs everytime.
I know it's something simple because it ran perfect a few times.
Yes timing is fine.
It also does the same thing with stock injectors.
It's like it's getting to much air on start up, throttle body is closed.     Any idea what the hell is going on?
Pearl white 88 Starion, JE's 40 over, clearwater head/1mm os stainless valves,TEP cam,BSE kit, balanced,1g air mas,t3/t4 custom manifold,t70 turbo,kellys DP,and a bunch of new oem's, O and some nicely polished 8's +9's!!!
#2 croquest87
  • 1,775 posts
Posted 01 December 2019 - 09:14 PM
Isc not connected/ faulty ?  Sucking massive air some place? If throttle is closed you must be getting air in somewhere else to rev that high.
#3 techboy
techboy
  • 3,643 posts
Posted 01 December 2019 - 09:30 PM
Did you take the intake pipe off and actually verify the TB is closed? Only other thing I can think is the shaft seals are totally shot.
#4 TexasQuest
  • 9,118 posts
Posted 02 December 2019 - 07:37 PM
Try a TPS/ISC reset.
88 Fiji Blue -TSi
