Terrible RPM spikes while cranking
31 replies to this topic
#1 Preludedude
Preludedude
  • 3,389 posts
Posted 29 November 2019 - 03:17 PM
I have been battling these RPM spikes for over a year now. I still can not get my new MPI build to crank consistently...The RPM spiking during cranking causes ASE and WUE to turn on sporadically even though the car hasn't cranked yet..The RPMs are ALL OVER the place while cranking....So I am flooding the engine every time I attempt to crank it...
I have documented these problems in my restoration thread here:
http://www.starquest...c=152437&st=140
So I re-did the wiring from the dizzy to the VR cable and its very clean and everything is soldered and heat shrinked...
The dizzy does have the tiniest bit of play in the rotor, so you can rotate it slightly if the cap is off. But there's no way that tiny amount of play gives me these massive spikes during cranking.
Speedyquest, I took your advice and re-did my grounding.
As you can see, my engine block has 4 grounds going to it...
Guys, please help me. I'm at the end of my patience. I've fought these RPM spikes for over a year. I still haven't been able to drive this rebuilt engine/MPI build because of this problem...
Any suggestions of where to check for noise or something else?
Edited by Preludedude, 29 November 2019 - 07:24 PM.
#2 speedyquest
speedyquest
  • 4,338 posts
Posted 29 November 2019 - 05:34 PM
Have you done a high speed datalog for the trigger wheel? If not you need to do that to see what's happening. One of the common things that also effects a clean rpm signal is how close your sensor wires are to high power current. So things like coils, alternator, starter, etc put out tons of electrical noise and can effect your sensor readings.
#3 tsi_tom
tsi_tom
  • 2,448 posts
Posted 29 November 2019 - 06:12 PM
My thoughts if they mean anything:
In your ground to the block picture above, it doesn't look very clean.  The factory bolt is shiny and has a serrated washer.
Is it possible the sensor is bad?  Can you measure the resistance?
With these setups is a capacitor necessary to filter the spikes?
Engine
20 over forged pistons
Stock injection system
#4 Preludedude
Preludedude
  • 3,389 posts
Posted 29 November 2019 - 07:23 PM
Its clean...I sanded the block well, and use a wire brush on bench grinder to clean the bolt threads and head...
What sensor are you referring to?
Edited by Preludedude, 29 November 2019 - 07:25 PM.
#5 tsi_tom
tsi_tom
  • 2,448 posts
Posted 29 November 2019 - 08:24 PM
Isnít there a Hall effect sensor for crank position?
Engine
#6 Preludedude
Preludedude
  • 3,389 posts
Posted 29 November 2019 - 09:38 PM
Iím not running a crank trigger guys....Iím using a locked distributor.
#7 tsi_tom
tsi_tom
  • 2,448 posts
Posted 29 November 2019 - 11:13 PM
So that uses the stock pickup coil?
Edited by tsi_tom, 30 November 2019 - 08:27 AM.
Engine
#8 Turbo Cary
Turbo Cary
  • 1,798 posts
Posted 30 November 2019 - 07:45 AM
Are you using a tach adapter? Also what are your engine state settings in Megasquirt?
#9 scott87star
scott87star
  • 5,068 posts
Posted 30 November 2019 - 11:11 AM
He's using one of my 88-89 plug and play systems, it uses the stock ignition pickup although it runs through a new twisted pair shielded wire from the dizzy to the ECU, grounded at the ECU.  No tach adapter needed.  There are lots of these systems out there working well, I've never seen a noise issue like this.
Mark, if I remember correctly, we did a round or two of noise filtering without success, correct?  The noise filtering tends to be hit or miss, it either works like magic or doesn't help and I recall adding some to your system but maybe that was back when it was still TBI?
#10 Preludedude
Preludedude
  • 3,389 posts
Posted 30 November 2019 - 11:58 AM
I think we did, but we can try again....Iíll send you an email with the current tune.....
#11 scott87star
scott87star
  • 5,068 posts
Posted 30 November 2019 - 02:00 PM
The other thing to review is the rotor phasing.  A distributor has both low voltage and uber high voltage going on in the same space and if the rotor phasing is off, meaning the dizzy is off a tooth or two, you can get the high voltage going to the wrong place, like the rpm input.  To check you'd put the crank at 25 degrees BTDC #1 compression stroke and then take the cap off the dizzy, the rotor should be pointing directly at the #1 tower.
The surest way to eliminate any cross talk between high and low voltage is to change to a crank trigger, also provides much better timing resolution.
#12 ucw458
ucw458
  • 11,687 posts
Posted 30 November 2019 - 02:08 PM
On your shielded wires are they grounded at the engine and the ECU?  If so that creates a ground loop that can cancel out the shielding effect and let noise in.  Shielding should only be grounded at one end.
My 87
#13 Preludedude
Preludedude
  • 3,389 posts
Posted 30 November 2019 - 02:44 PM
So which shielded wires are we talking about?   Where are they located?
#14 ucw458
ucw458
  • 11,687 posts
Posted 30 November 2019 - 05:22 PM
Usually wires that have a low voltage signal that can be affected by EM fields.  For example, O2 sensor, ignition signals, knock sensor.  Particularly your wiring between the distributor and ECU.  The stock pickup produces a very low voltage signal around 1-2 volts iirc.  Any outside noise on that wire could cause issues.  Looking at the FSM it appears the negative side of the distributor pickup is grounded to the engine.  If you have it grounded at the ECU as well that would create a ground loop.
Maybe your battery cables coming from the trunk are causing issues.  This only happens when cranking..  Those cables are passing significant current when cranking.  If then are next to signal wires they can induce noise.  Maybe try removing the battery from the trunk and connect it in the engine bay as a test to see if the RPM signal clears up.
My 87
#15 Preludedude
Preludedude
  • 3,389 posts
Posted 30 November 2019 - 05:36 PM
So the dizzy has 3 wires on the connector.   The black/yllw wire (ground) is wired into the VR shield wire.
Does this black/yllw wire on dizzy connector need to be grounded on the engine?  And not wired into the VR cable....???
#16 psu_Crash
psu_Crash
  • 7,291 posts
Posted 30 November 2019 - 10:50 PM
No. It sounds like that is just the shield wire for the twisted pair cable. That should only be grounded at the ECU end.
Are you getting battery voltage spikes at the same time as the RPM spikes?
Edited by psu_Crash, 30 November 2019 - 10:52 PM.
The Valencia Project
My Feedback Link
#17 Preludedude
Preludedude
  • 3,389 posts
Posted 01 December 2019 - 07:07 AM
Iím wondering if the battery relocation is the culprit.
My TBI didnít have cranking issues back in July2017 before it blew a head gasket at drag strip.
Now after the tear down and rebuild, I went MPI and kept Scottís MS system.....now Iím having rpm spikes during cranking.
Found this informative site while googling issue:
https://www.w8ji.com..._to_battery.htm
Seems I shouldnít have 4 grounds all together that are directly tied to battery post....
Edited by Preludedude, 01 December 2019 - 07:28 AM.
#18 psu_Crash
psu_Crash
  • 7,291 posts
Posted 01 December 2019 - 05:54 PM
That's correct. One solid ground is all you need. I run from the battery negative, to MS, to a block mounted on the frame rail near the stock battery location. One heavy wire from that to the block. I can't remember 100% about my sensor grounds. I believe all or most anyway are grounded back to MS. With this setup I would get random RPM spikes under load that coincided with battery voltage spikes. So what I did was install a power filter on the MS 12 volt feed. Problem solved.
I'm sure something in the battery location grounding is the culprit. Although I never went back to figure it out ... yet.
My Feedback Link
#19 Preludedude
Preludedude
  • 3,389 posts
Posted 10 April 2020 - 04:47 PM
So I gave up until now. About to start working on this spiking issue again.  Wish me luck!
#20 tux
tux
  • 1,489 posts
Posted 11 April 2020 - 03:24 PM
Try grounding the shielding wire at both ends.
Grounding one end has the ability to turn the shield into an antenna and can pick up additional noise.
https://incompliance...bout-shielding/
