MainstreaM Posted May 15, 2013 Report Share Posted May 15, 2013 (edited) Toying with selling this one too. 2200 miles on block, .010/.010 crank, bearings and rings. 4500 on the rest of a completely rebuilt engine. Balanced w/B.S. removal.Block decked, bored and tanked by Dad (Randy)..020 Wiseco'sDad's Marnal w/ O.S. valves, Schneider springs, clean up ports and combustion chamber.274 cam.ARP head and main studs. Custom pickup so I didn't have to use stock bolt.Prepped rods w/ARP bolts. Floater pins.Clevite bearings.New oil pump, timing chain, gears, guides.New water pump, belts, motor and tranny mounts.TB rebuiltRebuilt brake booster.New Cap, rotor, spark plugs, 8mm spiral core wires.ACT HD clutch. New pilot and throw out bearing.Lightened stock flywheel.New 105 amp alt from Jolly Roger.New rear mounted battery after Optima junk top went bad.Sunpro guage set. Oil, water, volts. (stock works also).3" Down pipe and 3" full exhaust. Dynomax muffler hidden in stock location. Chrome tip.Silicone hoses.Braided S.S. oil feed, oil drain line, oil cooler lines, turbo water coolant lines, clutch lineNew U-joints.Interior black leather is nice. wear on driver bolster and has a 1/4" separation.Car alarm w/remote lock/unlock.Window tint.Drilled and slotted discs all around. new brake pads.New Fuzion tires all around.Due for a Mobil 1 oil change, have the stuff just waiting on a day off without a million other things going on.Cleaned all grounds except two, will get to these when I get the strut replaced. BadCar has rebuilt title. Driver side front corner was crunched by previous owner. Insurance co. totaled it because repair was more than book value. Was completely repaired before I bought car. Can't tell was in accident. Absolutely no frame damage from accident. Front rims are 7". I guess one was dented from accident.Wheels have spider cracks in clear coat.Has stock 12A turbo. (Nothing wrong with it just should be bigger).Aftermarket fiberglass Air dam is cracked.Front passenger strut is leaking oil and wheel bearings need replaced, will have this fixed soon.Suspect tires out of balance since I found stick on weights laying in the driveway. Vibration above 70mph.Body has faded spots in clear (typical for Mitsu) and assorted dings and chips. One small dent in driver door about the size of a quarter from someones door.Factory radio and wiring are suspect.Injectors are starting to leak around the seals, will try to get this fixed ASAPSmall wear spot on drivers seat bolster Title in hand and in my name. Not raced or beat on, and is very dependable, I use it as my back up vehicle in case my Liberty breaks down. Drive 60 miles one way to work a couple times a week. Came from Florida and made the 1000 mile drive without a problem. PO did all the engine work and I have receipts. No overheating issues plus the AC works. If this doesn't sell, I have it scheduled to be painted at my uncle's body shop in July. Going to Venice Florida first week of June and can bring it with me. Picking up a car down there and will have room on the trailer on the way down. 3500 as is4000 strut replaced, new wheel bearings, grounds cleaned, tires balanced, four wheel alignment6000 dings fixed, airdam repaired, and new factory match paint Dirty pics:http://imageshack.us/a/img826/296/20130312151503418.jpghttp://imageshack.us/a/img266/4945/20130312151525454.jpghttp://imageshack.us/a/img9/6460/20130312151553781.jpghttp://imageshack.us/a/img521/1029/20130312151537469.jpghttp://imageshack.us/a/img26/575/20130312151658149.jpghttp://imageshack.us/a/img802/1746/20130312151645891.jpghttp://imageshack.us/a/img824/3522/20130312151624660.jpghttp://imageshack.us/a/img5/9092/20130312151404384.jpg Kane Edited May 15, 2013 by MainstreaM Quote Link to comment Share on other sites More sharing options...
wrngwae Posted May 15, 2013 Report Share Posted May 15, 2013 Saw this car in person. nice ride. bump for ya Brotha. Quote Link to comment Share on other sites More sharing options...
importwarrior Posted May 15, 2013 Report Share Posted May 15, 2013 wish it was a month or 2 earlier.nice car! Quote Link to comment Share on other sites More sharing options...
IntercooledFlatty Posted May 15, 2013 Report Share Posted May 15, 2013 Fiji FTMFW ...nice quest, GREAT price Quote Link to comment Share on other sites More sharing options...
MainstreaM Posted May 15, 2013 Author Report Share Posted May 15, 2013 Saw this car in person. nice ride. bump for ya Brotha. Next time you need to stay for a brew or two. I've always wanted Scotty's T80 car, so if this one sells, that is what the funds will go towards. Quote Link to comment Share on other sites More sharing options...
wrngwae Posted May 16, 2013 Report Share Posted May 16, 2013 hahaha,, i will be heading back to ATL in October i believe... i will hang out some more with ya..bump for a good car. Quote Link to comment Share on other sites More sharing options...
Madseason41 Posted June 7, 2013 Report Share Posted June 7, 2013 PM sent. Quote Link to comment Share on other sites More sharing options...
MainstreaM Posted June 7, 2013 Author Report Share Posted June 7, 2013 Car has an appointment at the body shop Wednesday, will take a couple of months to finish, no tape and spray, full pull apart and paint each panel individually. Kane Quote Link to comment Share on other sites More sharing options...
MainstreaM Posted July 21, 2013 Author Report Share Posted July 21, 2013 (edited) Still not painted yet so it could still be sold. He got 48 and 52 Ford pickups in for a full respray. My car was put on the back burner since those are big money jobs and mine is at the family discount. Edited July 21, 2013 by MainstreaM Quote Link to comment Share on other sites More sharing options...
marso Posted July 25, 2013 Report Share Posted July 25, 2013 (edited) That was my car and I can vouch for everything he is saying. Don't let the R title scare you there is nothing wrong with this car. The owner before me had an aftermarket radio and he is the one who cut the wiring then reinstalled the stock before selling it to me. The radio worked but did not keep stations and the wheel controls did not work. The harness side wires are all there. I wouldn't mind having it back but no room for a toy. That's why it was sold. Edited July 25, 2013 by marso Quote Link to comment Share on other sites More sharing options...
89Steve Posted August 8, 2013 Report Share Posted August 8, 2013 Has this been sprayed yet? I'm toying around with the idea of getting another SQ if its clean and at the right price. Also is there any rust on frame rails or quarter panels? Quote Link to comment Share on other sites More sharing options...
MainstreaM Posted August 8, 2013 Author Report Share Posted August 8, 2013 Not sprayed yet, it's on the family discount plan which puts it in the corner to be worked on when regular work is slow. No rust on this car that I can find. I'll probably regret selling it. Kane Quote Link to comment Share on other sites More sharing options...
Roush Posted August 8, 2013 Report Share Posted August 8, 2013 Coming back to FL anytime soon? lol Quote Link to comment Share on other sites More sharing options...
MainstreaM Posted August 9, 2013 Author Report Share Posted August 9, 2013 Coming back to FL anytime soon? lol Next planned trip is after Christmas. If asking price is met and paid in full, I'd seriously consider making a special trip sooner. Just made an offer on a house and 47 acres. Selling this could really help with that. Kane Quote Link to comment Share on other sites More sharing options...
Matt300ZXT Posted August 9, 2013 Report Share Posted August 9, 2013 Would love to have the Fiji, and even in town Too bad the Z32 gets all the attention...why must you taunt me Kane?!? Quote Link to comment Share on other sites More sharing options...
MainstreaM Posted August 9, 2013 Author Report Share Posted August 9, 2013 Would love to have the Fiji, and even in town Too bad the Z32 gets all the attention...why must you taunt me Kane?!? Buy eet, or I shall taunt you a second time.http://sacredcalf.files.wordpress.com/2010/10/snipshot_monty.jpg Quote Link to comment Share on other sites More sharing options...
Roush Posted August 10, 2013 Report Share Posted August 10, 2013 Any engine bay pics? Quote Link to comment Share on other sites More sharing options...
tsiconquest88 Posted August 10, 2013 Report Share Posted August 10, 2013 Still not as nice as the fiji i got from u lol... It was quite a mint Quote Link to comment Share on other sites More sharing options...
MainstreaM Posted August 12, 2013 Author Report Share Posted August 12, 2013 http://imageshack.us/a/img199/8656/cmxo.JPG Quote Link to comment Share on other sites More sharing options...
marso Posted August 18, 2013 Report Share Posted August 18, 2013 It looks like I accidently left the white shifter ball in the car. I thought I took it out. I had it specially made for me. Any chance I could get it back? Quote Link to comment Share on other sites More sharing options...
MainstreaM Posted June 24, 2014 Author Report Share Posted June 24, 2014 After some drama with my little bro, i've got this car back in TN. Still kicking around the idea of selling. Has 70k on it now. Kane Quote Link to comment Share on other sites More sharing options...
helrazr70 Posted June 27, 2014 Report Share Posted June 27, 2014 As you have always known, I am partial to clean, low mileage, and black SQs... This one definitely deserves consideration though. It's just a hair outside my current price range though. I have been toying with the idea of picking up another SQ for a little while now and with PF coming up next week I decided to see what's out there. I figured I would poke around and see what is between here and there prior to the drive down there. Quote Link to comment Share on other sites More sharing options...
mikeamoss Posted July 4, 2014 Report Share Posted July 4, 2014 What's up with your '89?Painted yet?Any of issues addressed.... Wheel bearings, leaky injectors, bent wheel? Could I get some better pictures? Thanks, Mikem_amoss@hotmail.com Quote Link to comment Share on other sites More sharing options...
joshquest88 Posted July 19, 2014 Report Share Posted July 19, 2014 Is car still available? Quote Link to comment Share on other sites More sharing options...
MainstreaM Posted July 21, 2014 Author Report Share Posted July 21, 2014 Car is still somewhat available, although, here's the latest. After going over it with a fine tooth comb, thanks to helrazr70's attention to detail or OCD (which ever you want to call it) some more things have been noticed. The story of this car is questionable. The VIN stamped into the firewall, (not the firewall build plate) has been ground off. The other VIN tags seem to have been replaced at some time but I can not support nor deny this until I can tear the car down and match all the hidden VIN numbers in various body panels. Drivers door doesn't quite line up with the roof of the car indicating a possible bow in the body or could be a door that shouldn't have made it past quality control. A trip to the local frame machine is the only way to know for sure. Downpipe gasket is leaking, my fault, used a copper gasket in a pinch last time it went out. The vibration at 65mph seems to be torque tube related or could be the bow in the body. It's starting to get the rear end clunk of a failed diff mount as well. I probably won't sell it as is cause I know how cheap starquesters are and will end up getting lowballed to the point of pissing me off. Not being a d*ck, just been in the game long enough to know. What's up with your '89?Painted yet?Any of issues addressed.... Wheel bearings, leaky injectors, bent wheel?Could I get some better pictures? See aboveNopeNope, injectors are fine, curbed not bentI'm a very busy person, if you are serious about buying I can. Is car still available? Somewhat, see above. Quote Link to comment Share on other sites More sharing options...
