EGT temps
egt temps
23 replies to this topic
#21 Chad
Chad
    noob
  • 9,182 posts
  • Interests:Starquest Fanatic
Posted 17 December 2016 - 01:11 PM
Yah, I've seen similar.  If the plugs look good, and fuel consumption and oil loss seem normal for how you drive it, those are normal figures.  I'd target 1000-1100 for cruise.  1400-1500 is normal for WOT and full boost, that's why headders get burnt up (carburized) eventually.  When you start seeing 1600* at full load, that's when you have concerning problems.  Some all out drag racers will see 1800*, but those are brief bursts.   If you are cooler than 1400* at full load, that's actually concerning, the tune is off.
The glowing effect also depends a lot on wall thickness of the headder.  I've seen a stock cast steel manifold glow too, but that was after climbing 4000* elevation in a short distance at mild but steady boost on a bone stock car.  thin wall headders heat up faster, but stock cast manifolds will glow too if kept hot long enough.
#22 Chad
Chad
    noob
  • 9,182 posts
Posted 17 December 2016 - 01:13 PM
check out this color chart:
http://911research.w...es/metcolor.htm
#23 Mach 5
Mach 5
  • 504 posts
Posted 17 December 2016 - 02:19 PM
now that's cool!!! ouch... I mean hot.
mine was still climbing but I was racing hghway speeds the other night.
That chart should be a sticky.
Owner and Founder of Triple R Motors aka Radical Rev Race Mods- Jarek-
-Rides-
-1987 Starion -Midnight Star - Build Progress see link
http://www.starquest...howtopic=152434
-1989 Chrysler Conquest-Track Beast Mode gtx3071r TBI 365hp 407tq @20psi- RIP
http://www.starquest...ic=151885&st=40
-1989 Pontiac Grand Prix Turbo SE- 3.1 gt4088r getrag284 Tilton twin disc
-1991 Toyota Hilux Pickup 1uz itb cp pistons kelford cams TripleR head porting/ long tubes
-1990 McLaren Turbo Grand Prix sold...
-1985 AE86 20v.. 171hp@ 8200rpm RIP
#24 Funky Phil
Funky Phil
    Super Pooper
  • 6,425 posts
Posted 17 December 2016 - 03:20 PM
Gas temperature exceeds that of surface temp.
