TEP cooling fan relay info
6 replies to this topic
#1 89fijiquest
89fijiquest
  • 65 posts
Posted 29 July 2018 - 08:19 PM
The 89 I bought has the TEP cooling fan relays which I guess is supposed to cause both fans to run.  It looks like it required several wiring mods.  I was wondering if anyone that did that mod still has the installation instructions. Those instructions along with the shop manuals may give me the confidence to undo the mess.
Thanks,
Brian
#2 BuGG
BuGG
  • 1,963 posts
Posted 29 July 2018 - 08:40 PM
You dont need any additional relays to have the fans come on together.  Simply attach the sensor wire of fan #1 to the lower temp sensor signal wire of fan #2.
#3 89fijiquest
89fijiquest
  • 65 posts
Posted 29 July 2018 - 08:48 PM
That's what I figured and would probably do something like that in the future after I untangle the TEP mess I inherited.
#4 TexasQuest
  • 8,883 posts
Posted 29 July 2018 - 08:55 PM
Yes Bugg is correct. I run 2 low temp thermosensors that are wired together and has been flawless.
88 Fiji Blue -Tsi
#5 techboy
techboy
  • 3,299 posts
Posted 29 July 2018 - 09:25 PM
The easiest way to untangle an aftermarket mess is to look at a stock configuration and eliminate everything "extra" that you have.  For the radiator fans ... there's two thermo-sensors on the bottom of the rad that have a single wire connector going to it.  The fans on the radiator are supplied power with a black round connector on either side of the radiator and clip into the fan connectors.  That's it.  Anything else you have in addition to that, that you may be trying to eliminate you should be able to start cutting out.
That said, how much of the history of the car do you know?  There might be a reason an aftermarket system was installed ... like maybe there was a ECU problem and the fans weren't kicking on and the car was overheating. Just some food for thought.
#6 mstieg
mstieg
  • 6,178 posts
Posted 06 August 2018 - 01:05 AM
I'd recc replacing as much stock wiring as you can.  Esp. for something as important as cooling.  Can & probably will save your engine from a future electrical gremlin fail.
While driving, we'll never know if fans quit...at best we catch the (hopefully still accurate) temp gauge if it rises.
As for TEP - screw those overpriced jerkos.  A relay is a relay.  Like paying 4x for a Grade 8 bolt from the dealer vs. Ace Hardware.  Same bolt.
* not a bad idea to wire a switch to the fans & mount on the dash/console somewhere.
In Progress: breakin & tune
#7 89fijiquest
89fijiquest
  • 65 posts
Posted 08 August 2018 - 03:47 PM
I was hoping someone in these groups had purchased the kit 'back in the day' and had the instructions to make it easier to reverse engineer. I have the shop manual but not another car to look at.  I'm suprised to see extra relays and extra wires for this kit (and lot's of cutting it looks like) when like everyone says, just wire them together.  With the key in On position, whether running or not both fans on engine side of radiator run.  Looks like fan on other side of radiator is tied into the A/C compressor power and runs anytime the compressor runs.
This is a pic of the relay bracket. You can see 2 bosch relays and some custom wiring. I do still see 2 factory plugs for relays which is hopeful !
Posted Image20180805_192444
Edited by 89fijiquest, 12 August 2018 - 09:32 PM.
