S14 spindles with stock hubs?
3 replies to this topic
#1 Merlyn
Merlyn
  • 59 posts
  • Interests:motorsports, guns and computers
Posted 11 June 2019 - 07:38 PM
Just got a set of S14 spindles and coilovers.
Out of curiosity, has anyone ever tried mounting stock wheel hubs to S14 spindles with a different wheel bearing? If there happens to be one that matches the OD of the spindle and the ID of the Star/Quest front hubs, it would likely be cheaper than new S14 hubs/bearings/studs
Merlyn
-- 1988 Conquest TSi, Currently under the knife
#2 MotoCam360
MotoCam360
    Motocam360
  • 2,148 posts
Posted 11 June 2019 - 10:49 PM
New 5lug S14 assembly with pressed in bearing was $115/pair delivered.....why mess around with SQ hubs??
Edited by MotoCam360, 12 June 2019 - 01:57 AM.
Tim
My Feedback Link
#3 87redcat
87redcat
    10 years and counting...
  • 3,957 posts
Posted 12 June 2019 - 02:59 AM
They take different type bearings so that a no go unless you want to spend a ton if money at a machine shop
#4 76ColtGalant
76ColtGalant
  • 128 posts
Posted 17 June 2019 - 06:54 PM
Also to note, Nissan uses  M12x1.25 studs on the wheel hub unlike Mitsubishi that uses M12x1.5 studs, so you will need a new lug nuts as well.  S14 hub bearings aren't pressed in like S13 hubs, they are a sealed unit with the hub. So yes every time you need a new bearing, you buy a complete hub assembly.
Tim
76 Galant Coupe
79 Galant Sigma Wagon
88 Fiji Blue SQ - 4g64 swapped
94 Montero SR DOHC 3.5l
92 Galant VR4 362/1000
