Quick Detach Front Airdam
7 replies to this topic
#1 Mix_67
Mix_67
    Wheel Spinner
  • 575 posts
Posted 24 May 2021 - 06:55 AM
Has anyone made an airdam quick removal?
I use my dolly to get the car to auto-x and the front airdam interferes with the dolly. I would like to be able to attach and detach it quickly at the track. Right now I just don't even run it with an airdam and don't like how it looks.
"Speed costs money. How fast do YOU want to go?"-Spoolin' Fools, Venus PA
"I was doing fine until about mid corner, that's pretty much were I ran out of talent and spun the car"
'87 Flatty Intercooled w/ 16gEvo3 @ 18psi, ssq-bov, ARP Head Studs, BSEK, 5-speed swap, 5 lug swap w/ 6bolt LSD, 3:90's, Cosmo Dual Spring Coilovers, MK1Shocks, MK1 Camber Plates, M28 head, Tial 38, SAFC-2, SSI-4,750/1400 Injectors
2010 DSM Shoot-Out DSM MAXeffort Street Tire Winner
#2 techboy
techboy
  • 3,911 posts
Posted 24 May 2021 - 02:05 PM
I've never seen one, but that doesn't mean someone hasn't done it. I know a lot guys use those quick release bumper attachments which would work on the sides of the air dam, but it's a little trickier on the front of the car b/c the airdam hangs from underneath the front bumper.  You might have attach like a "U" shaped or "L" shaped bracket and various intervals that the airdam hangs on.  Maybe with like a slide through cotter-pin or something like that.  I'm brainstorming here ...
EDIT: this isn't a solution for you I don't think ... but I removed all the rusty hardware and metal brackets from my airdam when I restored my car and drilled slots in intervals on the topside of the airdam and underside of the bumper.  With the exception of the left and right sides where it's still held by factory OE bolts, the whole center is held by heavy duty zip ties that you can't see.  Been that way for 5 years now and never had a problem.  If I ever wanted to remove just the airdam all I have to do is remove a few bolts and cut the ties.  I almost forgot I did it that way until I read this post.
Edited by techboy, 24 May 2021 - 02:09 PM.
#3 psu_Crash
psu_Crash
  • 7,524 posts
Posted 24 May 2021 - 02:25 PM
That would be great! I strategically place boards to get mine on the trailer for events. It's too much of a hassle to take the air dam off. I'll just take my chances lol
The Valencia Project
My Feedback Link
#4 obsolete
obsolete
  • 640 posts
Posted 24 May 2021 - 04:31 PM
I think these might be the answer: https://timmcamis.co...-fasteners.html
#5 psu_Crash
psu_Crash
  • 7,524 posts
Posted 24 May 2021 - 05:29 PM
Hmmm ...
My Feedback Link
#6 tux
tux
  • 1,831 posts
Posted 24 May 2021 - 05:39 PM
Still gotta get under the car to release them unless you figure out new attachment points
#7 87redcat
87redcat
    10 years and counting...
  • 4,186 posts
Posted 25 May 2021 - 05:39 AM
A lot of aircraft external access panels are held on by those very same fasteners. So vibration would not be a problem
#8 Turbo Cary
Turbo Cary
  • 1,956 posts
Posted 26 May 2021 - 06:35 PM
This is what we do to fix Speed 3 bumpers. Could be used for a Starion
https://mazdaspeeds....7-to-2009.1689/
