jcstarion88 Posted June 14, 2011 Report Share Posted June 14, 2011 i know; the power, acc, and the speakers, but i need the rest too. for example the antenna one.. pics...http://i1007.photobucket.com/albums/af193/jcskaterdude/IMG_20110614_193324.jpghttp://i1007.photobucket.com/albums/af193/jcskaterdude/IMG_20110614_193345.jpg lmk guys thanks JuanC> Link to comment Share on other sites More sharing options...
ucw458 Posted June 15, 2011 Report Share Posted June 15, 2011 http://www.starquestgarage.com Link to comment Share on other sites More sharing options...
Shelby Posted June 15, 2011 Report Share Posted June 15, 2011 why do guys do that,, you can pick up an adaptor plug at any auto sterrio shop and leave the oem connector alone please note,,the lights on signal wire is not a power feed wire, it's a ground signal wire , and is diff from the dim radio control lights when driveing with head lamps on the instrument lamps are control'd by the dimmer control it's on the ground side NOT the power feed side , most after market radios use a power to this lead and that burns out the fader swt , best to just leave that wire disconnect'd if useing an after market radio , take extra care when looking for a power feed for the radio face lamps the on/off swt on the quest radio is a ground swt not a power feed as your use'd to seeing , that don't change how it's wire'd, only info Link to comment Share on other sites More sharing options...
jcstarion88 Posted June 16, 2011 Author Report Share Posted June 16, 2011 Mine only has cables, it dosent have the oem connector Is there a wire I have to connect so my dashboard turn on? Link to comment Share on other sites More sharing options...
The Rabbit1 Posted June 16, 2011 Report Share Posted June 16, 2011 if your dash won't light up the previous owner probably tried using the diommer wire and fried the dimmer switch. do not use the dimmer wire at all. and black with a red stripe is your ground wire. antenna is blue and white. Link to comment Share on other sites More sharing options...
Shelby Posted June 16, 2011 Report Share Posted June 16, 2011 if your dash won't light up the previous owner probably tried using the diommer wire and fried the dimmer switch. do not use the dimmer wire at all. and black with a red stripe is your ground wire. antenna is blue and white. side note the oem power antena has power all the time,,the radio signal wire is to trigger the power antena relay to send power to the motor to extend the antena,, once extend'd the relay trips and shuts off , turn the radio off and the relay ground signal goes away and the relay runs the antena back down to the default positionwhere the relay again trips at the bottom if the cable inside the anterna breaks the motor will continue to run for ever ,because it never stops and can not cause an overload it works some what like the power window swts , the relay reverse's the power flow and also trips open when it has an over load (cable stops) after market radio's do not all work the same way , it depends on how their power antena's relays are wire'd Link to comment Share on other sites More sharing options...
jcstarion88 Posted June 17, 2011 Author Report Share Posted June 17, 2011 if your dash won't light up the previous owner probably tried using the diommer wire and fried the dimmer switch. do not use the dimmer wire at all. and black with a red stripe is your ground wire. antenna is blue and white.thanks for that info, question; so i need a new dimmer switch? to make my dash light up? Link to comment Share on other sites More sharing options...
Shelby Posted June 17, 2011 Report Share Posted June 17, 2011 or remove the fader control and solder a jumper arround it to ground,, and the lites will be full bright all the time Link to comment Share on other sites More sharing options...
The Rabbit1 Posted June 17, 2011 Report Share Posted June 17, 2011 have you tried turning the dimmer switch? real question here, lol Link to comment Share on other sites More sharing options...
jcstarion88 Posted June 21, 2011 Author Report Share Posted June 21, 2011 Yeah I play w/ it n nothing(dimmer) Link to comment Share on other sites More sharing options...
jcstarion88 Posted June 21, 2011 Author Report Share Posted June 21, 2011 or remove the fader control and solder a jumper arround it to ground,, and the lites will be full bright all the timeWhat's the fader control? Link to comment Share on other sites More sharing options...
Shelby Posted June 21, 2011 Report Share Posted June 21, 2011 can't find a good pic right off but page 8-42 shows it location , page 8-66 & 8-67 shows circirt Link to comment Share on other sites More sharing options...
jcstarion88 Posted June 21, 2011 Author Report Share Posted June 21, 2011 my servie manual doesn't have dose pages. (volume one) Link to comment Share on other sites More sharing options...
Shelby Posted June 22, 2011 Report Share Posted June 22, 2011 down load the manuals from here and it will http://www.starquestgarage.com/ Link to comment Share on other sites More sharing options...
jcstarion88 Posted June 26, 2011 Author Report Share Posted June 26, 2011 i got a new dimmer switch and my dash lights up now.. n i also got some help here http://www.starquestclub.com/forum/index.php?showtopic=121686so i am going to install my radio and see if i get everything right.. thanks guys... Link to comment Share on other sites More sharing options...
landon p Posted July 22, 2011 Report Share Posted July 22, 2011 just a quik question jcstarion88 wered you get your dimmer switch ive been 2 3 places and they said not even applicable in there systems Link to comment Share on other sites More sharing options...
jcstarion88 Posted May 17, 2012 Author Report Share Posted May 17, 2012 just a quik question jcstarion88 wered you get your dimmer switch ive been 2 3 places and they said not even applicable in there systemsthetexan88 Link to comment Share on other sites More sharing options...
Caliber308 Posted May 19, 2012 Report Share Posted May 19, 2012 my servie manual doesn't have dose pages. (volume one) You need Volume no.2. Bill Link to comment Share on other sites More sharing options...
