Need some help on identifying this
3 replies to this topic
#1 88351wtsi
88351wtsi
  • 951 posts
  • Interests:My kids, music, and cars, not always in that order.
Posted 12 April 2017 - 02:06 PM
This connector is by the relay tree and the black wire/white stripe splices into the a/c compressor ground wire. Trying to find where the yellow wire goes. This is a two wire blue and white plug.  Any help would be appreciated
1988 Conquests
His:  Durban maroon with 351w
#2 mstieg
mstieg
  • 6,111 posts
Posted 27 May 2017 - 02:09 AM
Can you zoom back or label this in MS paint so we know exactly which one you're referring to.  Kinda dirty & I'm not seeing a clear yellow.
Could help to find it in the manual.  Most of this is gone & rewired on mine or I'd take a look.  GL.
In Progress: breakin & tune
FOR SALE:  Rear Camber plates (basic); NIB beefy U-joints(2); etc.see-->  http://www.starquest...howtopic=133262 Custom 5 guage overlay panel: http://www.starquest...pic=136703&st=0
#3 bflann
bflann
  • 241 posts
Posted 27 May 2017 - 01:29 PM
the yellow wire goes to the a/c cut-off thermo sensor and provides ground for a/c magnetic clutch relay and the black provides 12v to the magnetic clutch through relay contact and also sends 12v signal to ecu indicating a/c magnetic clutch is engaged on a/c condenser, so if u have a/c working in car u need that connector for the a/c clutch operation and ecu idle control when a/c is running
#4 88351wtsi
88351wtsi
  • 951 posts
Posted 27 May 2017 - 03:16 PM
Thank you very much. The black wire is split to go 2 places so that should definitely be it. Much appreciated
Edited by 88351wtsi, 27 May 2017 - 03:17 PM.
1988 Conquests
