boneTSI Posted February 14, 2013 Report Share Posted February 14, 2013 So the strangest thing happened.ny car has been running great.just put bew plugs and wires changed oil antifreeze even brake fluids out.aroubd ten pm a few nights ago i got in my car,drover literally 1 mile to the gas station.put 93 in and filled my tank.drove home.next morning i woke up for work and car would crank beautiful but not turn over.left no light on or anything either. Everythink eletrical in my car works still.battery at full charge.is getting spark and fuel as well.changed fusible links and new link cable in little black box by neg battery port.also tried starting fluid which didnt at all either.any ideas? Again everything works still just wont turn Link to comment Share on other sites More sharing options...
kyle's89quest Posted February 14, 2013 Report Share Posted February 14, 2013 Are you sure your getting enough fuel?? I know this is a no no, but spray a little starter fluid to see if it likes that. Then go from there. Link to comment Share on other sites More sharing options...
boneTSI Posted February 15, 2013 Author Report Share Posted February 15, 2013 Starter fluid was no help ive tried twice Link to comment Share on other sites More sharing options...
MikeMeyerhoff Posted February 15, 2013 Report Share Posted February 15, 2013 Maybe Fanta can help. Link to comment Share on other sites More sharing options...
vbrad511 Posted February 15, 2013 Report Share Posted February 15, 2013 Pull a couple plugs and see if they're wet. Link to comment Share on other sites More sharing options...
Amonje123 Posted February 15, 2013 Report Share Posted February 15, 2013 If u tried starting fluid and it doesn't start that means there no spark. Did u make sure there was spark at all the plugs not just 1. Maybe a bad coil. The spark should b bright and blue like a lighting bolt, Not dull and wimpy. Had this problem with my ride. I had spark just didn't seem right. Swaped coil and it work. Just throwing that out there. Link to comment Share on other sites More sharing options...
ucw458 Posted February 15, 2013 Report Share Posted February 15, 2013 Maybe Fanta can help. LOL I was thinking the same thing. One would hope your car can't turn/flip over Link to comment Share on other sites More sharing options...
scott87star Posted February 15, 2013 Report Share Posted February 15, 2013 Sounds like a dead ignitor. 1 Link to comment Share on other sites More sharing options...
Shelby Posted February 16, 2013 Report Share Posted February 16, 2013 remove coil wire from dist cap and hold 1/4" away from a metal ground,,have some one spin the engine over with starter,,got spark or not what you do from there depends on spark or no spark Link to comment Share on other sites More sharing options...
boneTSI Posted February 17, 2013 Author Report Share Posted February 17, 2013 Thanks for the replies! i Will be looking at car tomorrow and will try what everyone said.i will keep posted. Link to comment Share on other sites More sharing options...
