Wiper repair
13 replies to this topic
#1 19cturbo
19cturbo
  • 6,698 posts
  • Interests:cars
Posted 10 January 2014 - 03:53 PM
I know several people have had issues with their wipers in the past. Weather it be the nut on the stud coming loose and causing the wiper post to "walk" in the cowl of the car.. (which mine did) or just the wipers being slow even on high. There was a write up for fixing the motor and regreasing it. I had to buy some new linkages and post from SOTTY to fix mine, and i could figure out why when i tightened the nuts on them, the wipers would slow down. After some looking i figured it out.
There used to be grease in there but has since dried up after a good 26 years. I am willing to bet almost none of you have ever greased these..
So here it goes.
Remove the wiper linkages and wiper posts from your car. Remember how the linkages go together before you snap them apart (take a picture)
Edit from 19cturbo...added to this post by the moderators:   i used a 24MM socket on the big nut, it was slightly big but worked fine.. in case anyone was wondering.
This is the drivers side post attached to the linkage, they linkage just pops off with a little pressure.
Once you remove it from the linkage, remove the little C clip from the top of it, and you may have to use a hammer to tap the two pieces apart, but they do come apart. I actually had to use a small torch and heat mine a bit before they would come apart. it should look like this
inside of that piece, there are two inserts. they need to be cleaned of the old grease, i used emory cloth wrapped around a small punch to do the trick, the inserts will come out if you want, a little bit of heat and a small tap with a punch and hammer but be careful.
Dont loose the wave washer that sits on the post, it is important.
Clean the grease off the inside of the inserts and off of the wiper post itself, it looks like glue its been on there so long.
I used a screw drive to scrape some of it away the moved on to a scotch brite pad, then to emory cloth to clean it up better.
once everything is clean and will slide back together easily. Its time to grease them up and assemble them.
There is a little wave washer that goes on first, put a little bit of grease on each side of it. Apply some grease to the post and to the outer piece as well once you have the inserts cleaned and reinstalled.
I used plenty of grease to be sure it was coated well, you can wipe the excess away after your finished. slide the two pieces up and down a few times and reapply grease, to make sure everything is coated.
put the top washer back into place
insert the C clip, yes its a little bent out of shape at this point but thats ok just get it on there
take a pair of needle nose pliers and pinch the C clip back together.
Wipe away the extra grease and you are ready to reinstall them..
Edited by kev, 15 January 2014 - 08:51 AM.
View PostConvette, on 21 February 2016 - 11:51 AM, said:
#2 vbrad511
vbrad511
  • 8,320 posts
Posted 10 January 2014 - 04:46 PM
Excellent write up. Did this speed your wipers up when you were done?
#3 19cturbo
19cturbo
  • 6,698 posts
  • Interests:cars
Posted 10 January 2014 - 05:11 PM
ive had issues with mine... the nut on the passanger side was rusted, had to get a whole new linkage, but they seem to run smoother after this... they were always kinda crappy lol
#4 R-R-Quest
R-R-Quest
  • 490 posts
  • Interests:Having fun, Going fast!
Posted 10 January 2014 - 05:14 PM
Excellent info.  Thanks for taking the time to do that.  Like vBrad said, how do your wipers function now?
#5 19cturbo
19cturbo
  • 6,698 posts
  • Interests:cars
Posted 10 January 2014 - 05:31 PM
much smoother, you can tell just from the sound there is less strain on the motor..
#6 SOTTY
SOTTY
  • 6,466 posts
  • Interests:Az gotz da cotton mouff
Posted 10 January 2014 - 05:51 PM
Nice write up mang . :)
#7 IntercooledFlatty
IntercooledFlatty
    Get Sum
  • 14,332 posts
Posted 10 January 2014 - 06:03 PM
fast cars dont need no stinkin' windshield wiperZ yO
excellent post ma brutha frum anotha motha ;)
...amazing what can get done while waitiing on other ninjas to do THEIR work A ?
          MOPAR POWERED
#8 19cturbo
19cturbo
  • 6,698 posts
  • Interests:cars
Posted 10 January 2014 - 06:13 PM
aint that the truth..
can we get this moved to the HOW TO section?
#9 JohnnyWadd
JohnnyWadd
  • Banned
  • 8,936 posts
Posted 10 January 2014 - 06:19 PM
Cool.
#10 wrngwae
wrngwae
    Always Smooth like Keith Stone
  • 3,465 posts
  • Interests:trying to keep this motor under the hood, and off the engine stand
Posted 10 January 2014 - 07:02 PM
you have fat fingers mikie lol. what type of grease did you use? snythetic?
Edited by wrngwae, 10 January 2014 - 07:03 PM.
1989 Conquest  MOTOR BUILT BY DAD!!!!!!!!!.20 over block. Wiseco pistons.new M28 head w/ ss valves. Holeset Hx35 at 25psi.Snow Performance Meth injection, hurricane MPI intake manifold. 750 injectors. 3" exhaust. 3bar map sensor. Ajusta Head gasket. ARP head studs. FIP updated by Scott87star to control spark, and boost. running MS2.0.6. XTD stage 3 clutch.  I'm likely forgetting something. http://www.enginemachineservice.com http://www.starquestgarage.com
Scotts the man! check out his store.  http://www.starquest...             My site provided by Natallica the sticker Guru http://nbingaman.wix.../gntperformance Posted Image
#11 19cturbo
19cturbo
  • 6,698 posts
  • Interests:cars
Posted 10 January 2014 - 07:14 PM
i aint got fat fingers kid! dont get me twisted...
i just used coastal chasis grease. thats what i had available to me at the moment..
#12 importwarrior
  • 18,111 posts
Posted 11 January 2014 - 06:02 AM
assembly order for mounting to the car.
what size is the BIG Nut?
#13 kev
kev
    Moderator
  • 4,908 posts
Posted 13 January 2014 - 06:28 PM
Excellent post. It is amazing how nice and smooth the wipers work after you regrease them!   Like a brand new car again.
Thanks for creating this thread!  This is a must do maintenance for all conquests.   If you leave these go, the wiper post will seize and that entire aluminum mount will start to rotate in your cowl and eventually destroy your cowl (ask me how I know?  lol).
kev
#14 kev
kev
    Moderator
  • 4,908 posts
Posted 15 January 2014 - 08:57 AM
Note:   Added the socket size to the original post per the OP's request.   Only bad thing about the FAQ forum; nobody can respond/edit.
Also, thought I would add a pic of the seized wiper post removed from one of my former cars.   The threaded portion of the mount snapped when trying to remove the nut.   This is what I found once removed.   The entire post assembly was seized and was spinning in the cowl.   It wore the aluminum down as shown and caused a fair amount of wear on the steel cowl that required repair.  This was one of those things where I knew there was an issue but I kept putting it off.   When I finally got to it, a 30 minute job turned into the car being down for a few weeks until I found a replacement part/repaired the cowl/reassembled.
If you have never greased these posts on your car, I'd strongly recommend that you consider it soon.
kev
