2014 Parts list for cheap coming soon...
eduardo castellanos
I know i been gone for a while but its due to me being out of town for 3 weeks with no access to my account as someone hack it and changed my password so it took a while to recover it from my end. The good news is that i have recovered it,the pending parts witch is only 1 will be shipped asap... Once again sorry for not being able to log in. Any ways with that said parts list will be added shortly at dirt cheap prices...
88/89 Engine wiring harness complete no cuts $65 shipped
a/c compressor $30 shipped
complete head $69 shipped needs new studs
Bare intake manifold with a couple of sensors minus tps or injectors $30 shipped
Front wiper motor 88 model $25 shipped
Front wiper motor 83-85 model $22 shipped
radiator $40 shipped
4 bolt cv shaft 28 shipped
front lower control arms both $40 shipped
under dash wire loom with fuse box and relay $30 shipped
under carpet wire loom to the back of the car connecting lights visors etc $39 shipped
black carpet in decent shape $35 shipped
5 speed conversion pedals with clutch reservoir and brake reservoir $60 shipped
i have the engine for sale complete or in parts up to the request by the buyers.. $$ price depends on part but like always cheap
front cross member with no cuts $ 45 shipped
both rear lower control arms no bolts $35 shippe
Lsd diff $100 plus shipping
torque tube in good shape $69 shipped
5 speed drive shaft $100 shipped
88989 tranny in good shape $120 plus shipping
Clutch and disk $ 75 shipped due to weigh
both Rear struts with towers both $50 shipped
rear hatch shocks $40 shipped
steering column with no coupler $30 shipped
1 steering coupler $35 shipped
rear washer fluid tank with tunnel and cap $20 shipped
rear black carpet $18 shipped
88/89 style front seat plastic trims knobs ext both sides $25 shipped
hand brake cables both for $30 shipped or $19 for each
hand brake handle with Y connector and bolts $20 shipped
under front seat ecu for the seat belts $19 shipped
All HVAC valves under dash $25 shipped
A/c condenser under dash $ 15 shipped
Fuel pump relay next to the A pilar on passenger side $20 shipped
black sunvisors both for $18 shipped
Black rear view mirror with vanity light center $25 shippeds
rear speaker deck driver side only $24 shipped
rear black seats upper and lower $45 shipped
Black ceiling $25 shipped includes rear piece as well.. I forgot the actul name of this part..
driver or passenger side electric seat belt $40 shipped each
Next to Battery relay COVER 3 piece black metal $20 shipped
1 fuel regulator $15 shippe
1 power steering reservoir with cap $15 shipped
1 front non shp strut with spindle $65 shipped
2 headlight covers with no dents $20 shipped
1 headlight motor driver side $20 shippe
front ac heat exhanger with sensors and the black can next to it $35 shipped
brake booster $20 shipped
passenger side door pannel black complete with upper pannel $35 shipped
driver side door pannel upper part only as the lower part has a gaping hole $19 shipped
driver and passenger inner door handle bezels black $15 shipped
driver and passenger side inner door handles $19 shipped
driver and passenger door locking mechanism $22 shippe
driver door hinges $25 shippes
passenger door hinges $25 shippe
driver or passenger side door glass $20 shipped each
driver mirror black heated $19 shipped
passenger mirror black heated $19 shipped
center mirror control bezel with clips intact $25 shipped
black ash tray $10 shipped
cigaret socket $16 shipped
MORE TO COME BY TOMORROW... EVERYTHING IS SHIPPED UNLESS STATED IN A COUPLE OF ITEMS...
PAYPAL IS STARIONCORRADO@AOL.COM
Edited by eduardo castellanos
The Engine harness doesn't happen to be out of an "auto"car does it?
If so, I'll take it (because of a few of the sensor connections I believe are slightly different) If not, I'll continue my search.
Thanks man!
-N8
Thanks man!
-N8
It should be the same auto or 5 speed as the sensors are the same with the exeption of the extra plug it has for the clutch pressure sensor to start it but you can always bypass it with a simple wire or connector.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
