Red 88 ESI-R for Sale in Los Angeles (Culver City)
Del
I'm selling the car even though I'm really sad to do it. It's my daily driver right now and I need something a little more reliable.
The car runs really well and starts when you turn the key but has a few problems that make the impractical for me right now.
I've done a good amount of work to the car but it needs a lot of body work and some has a few mechanical problems. It has around 136,000 miles (I say about b/c the speedo cable has been broken for two months).
What I've done:
Top End Performance Rear Struts and Front Struts (http://www.racetep.com/dod_mitstrut.html)
Top End Performance Lowering Springs
Top End Performance Front Sway Bar
Top End Performance Custom Made Rear Differential Mounts
Top End Performance Installed Rear Axels
Metal Master Brake Pads (Front and Rear)
Top End Performance Performance Street Clutch (less than 500 miles wear)
Dunlop Tires (less than 1,000 miles wear)
Top End Performance Mandrel Bent Down Pipe (w/ new 02 sensor)
Tope End Performance Mandrel Bent B Pipe with High Flow Catalytic Converter
HKS Cat Back Exhaust
Top End Performance Over the Valve Cover Hard Pipe with Turbo XS BOV
Turbo XS Manual Boost Controller
New Starter Motor
Rebuilt Power Steering Gearbox
Replaced Injector Clips
Autometer Boost Gauge
Whats Wrong Right Now:
Reverse Lights Don't Turn on in Reverse (appears to be a wiring problem - I've replaced the switch)
Broken Speedo Cable (I have a replacement but it needs to be installed)
Front Transmission Seal Leak
Cracked Passenger Side Tail Light (I have a replacement but it needs to be installed)
Damaged and cracked front air dam
Damage to passenger side front quarter panel
I was hoping to get $4,000 for the car.
Let me know if you're interested and I'll take pictures. Please PM me if you have questions or if you're in LA and would like to come look at the car.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
