Saab daily
8 replies to this topic
#1 bha280
bha280
    runs with scissors
  • 1,421 posts
  • Interests:Stuff, junk, and things
Posted 15 May 2017 - 02:44 PM
This is my daily driver, a 2000 Saab 9-5 Aero wagon manual. Almost 208k miles, dual zone climate control, heated seats front/rear, rear A/C, perforated leather, aluminum dash and door handles, decent MPG, and sounds good. Just an educated guess, but around 260hp/330tq at the wheels
JZW Stage 4 and has made 302 fwhp and 356 ft-lb of torque (SAE) on the dyno reliably.
-Was before I got the car. Since then, the only upgrade was put in B234R cams
Engine/Performance:
B235R Saab HOT
- High pressure boost tune done at 21 psi
- 92 Octane tune
- 2006 9-5 Aero TD04-HL15T Turbo
- Krona 3 Inch, stainless steel, turbo back exhaust
- Krona performance bypass valve
- 3.5BAR fuel pressure regulator
- ETS 1100CFM 700hp Intercooler
- K&N Open air filter
- Coolant Thermostat and Temp sensor
- Genuine Saab DIC
- Genuine Saab Clutch
- Maptun/Walbro 255lph fuel pump
- B234R cams
Suspension/Brakes
- Genuine Saab Front suspension kit
     - 2 Tie rod ends
     - 2 Sway bar end links
     - 2 Ball joints
     - 2 Control arms
- 4 Koni adjustable dampers
- 4 Vogtland performance springs
- 6 Genuine Saab front subframe bushings
- Front and rear Brembo high performance brake rotors
- Front and rear Akebono high performance brake pads
Edited by bha280, 15 May 2017 - 02:44 PM.
1988 Starion 5-speed- AMC head, Schnieder HD springs and 292 cam, Wiseco's, Pauter Rods, adjustable cam gear, ported Evo III 16G, 3" turbo back, lightened/balanced flywheel, polished/balanced crank, SS braided oil and coolant lines for turbo, full hard pipes w/ TurboXS BOV and MBC, Trilogy injectors, MSD blaster 2 coil, 8.5mm wires, stress relieved and ported exhaust manifold, ported intake manifold, LSP 52mm TB, ARP everything, EGR, A/C, and cruise removed, silicon vacuum lines, STB's front and rear, ABS delete, 3" GM MAF-T Gen II, D/S rotors, SS brake lines, Innovate wideband, adjustable FPR, Walbro 255lph fuel pump, AutoMeter boost gauge, GM alternator, SS clutch line, meshies, factory hatch spoiler, mud flaps, Mookeh rear struts and adjustable front inserts, Cosmo dual-spring Coilovers, Mookeh pillow ball camber plates F/R, rebuilt trans, short throw, MSD 6a, poly bushings.
Soon to be in a flatty!
#2 rcm
rcm
    rcm
  • 2,152 posts
    muscle cars.
Posted 15 May 2017 - 04:55 PM
Man what a sleeper !!
#3 TexasQuest
  • 8,861 posts
Posted 15 May 2017 - 08:16 PM
Cool car man! Nice to see a modified Saab. How hard is it to find parts for those now? Must be a tight knit community.
Edited by TexasQuest, 15 May 2017 - 08:18 PM.
88 Fiji Blue -Tsi
#4 importwarrior
  • 18,269 posts
Posted 16 May 2017 - 04:44 AM
cool grocery getter / sleeper.
#5 bha280
bha280
    runs with scissors
  • 1,421 posts
Posted 16 May 2017 - 11:00 AM
Thanks! Surprisingly, it's not that difficult to get parts. There are quite a few dedicated Saab sites along with some Euro car sites with plenty of parts. It is a pretty tight community like the Starquest group. This is a great car and I would recommend them to anyone. Just like anything, keep up with the maintenance and it will treat you right. The tune and cams bring the power on fully at around 3500 rpms, and that torque is addicting. Part of the reason I love the Starion so much. Some day I'll get it on the dyno a post some real numbers.
#6 G54Bstore
G54Bstore
    SQC Commander
  • 5,157 posts
Posted 13 June 2017 - 01:10 PM
looks kinda like this volvo I just fixed.Its turbo ..pretty peppy
Edited by G54Bstore, 13 June 2017 - 01:11 PM.
W18 Rocky White Starion
Daily Driver
#7 IntercooledFlatty
IntercooledFlatty
    Get Sum
  • 14,377 posts
Posted 16 June 2017 - 11:43 AM
awesome car
          MOPAR POWERED
#8 G54Bstore
G54Bstore
    SQC Commander
  • 5,157 posts
Posted 16 June 2017 - 12:54 PM
Just sprung a oil leak that's dripping onto the exhaust manifold.
Back to the starion as my dependable daily driver. Lol
Daily Driver
#9 bha280
bha280
    runs with scissors
  • 1,421 posts
Posted 22 June 2017 - 10:16 AM
I know someone in Pensacola selling a 2005 Volvo V70R. Car is super rad. Turbo, v5, AWD, 6 speed, wagon, exhaust, super comfy seats, electronic suspension, $6500. About the only Volvo I want
