White '87 Starion - 2JZ/V160 swap
14 replies to this topic
#1 gtxthunder
gtxthunder
  • 1,939 posts
Posted 10 June 2019 - 04:16 PM
1987 Mitsubishi Starion
Vin: JA3CC54N5HZ038725
Chassis/Body:
25.5 roll cage - X in roof - 7.50 cert.
Dual Stroud parachutes
Dual driveshaft loops
Window net
1983 Starion tail lights
New paint on hood, rocker panels and 3 piece rear spoiler
Airdam, bumper cover and the metal bumper support were new when i installed them in the last few years
Windows were just tinted several months ago. I believe they're 35%.
Interior:
Driver and passenger Kirkey seats and black seat covers
Simpson 5 point harnesses
Autometer Cobalt tachometer,  Speedometer, 45psi boost, water temperature, oil pressure, volt meter, and fuel level gauges.
Aem Uego air fuel gauge
Custom aluminum door panels with integrated window switches
Battery has been relocated to the trunk.
Stock trunk area has been cut out and replaced with a flat piece of aluminum. Stock fuel tank is still in place and a custom mount was made.
Suspension/Braking
Manual brakes
Line lock
Front big brake kit with wilwood calipers
Rear cross drilled rotors
Stainless brake lines
D2 coil overs
Front and rear adjustable camber plates
Boxed in front control arms
Poly front control arm bushings and strut rod bushings
Rear Diff:
Resealed
Poly diff mounts and rear control arm bushings.
Driveshaft shop pro series axles
Transmission/Clutch
Rebuilt v160. Came out of Jess Barton's old Supra that ran deep into the 8s.
Clutchmasters triple disc clutch
Driveshaft Shop carbon driveshaft
Turbo/Manifold:
Shark Fab t4 manifold with dual Tial mvr wastegates
Tial Q bov
Precision 7685 turbo
Powerhouse 5" intake pipe
Intake Manifold/Fuel
Sleeper Designs billet intake manifold
ID2000 injectors
Nitrous Express direct port system
Bosch 044 at stock tank
Weldon mechanical cam driven pump
1 gallon surge tank in engine bay
Weldon regulator
Head:
Headgames pocket port
Kelford T202D cams
Powerhouse cam gears
Ferrea dual springs, titanium retainers, valves and locks
Shimless buckets
Short block:
Real Street RS1600
10:1
Turbo Tuff rods
Billet main caps
New oil pump, water pump, all gaskets and seals.
Crower oil pump gear
Misc:
Ati crank pulley
Powerhouse pulley kit
Powerhouse alternator
Aem v2 ECU
Aem iat, 5 bar map, fuel pressure and oil pressure sensors
Weld RTS wheels
Mickey Thompson 26x10.5 slicks
I had this car list for sale a few years ago, but i had some motor issues shortly after. The set up has changed a lot since then. I purchased everything new all over again. All parts now have less than a few hundred miles on them.
The car is located in Tampa Florida right now. In a month or so, it will be back in Maryland.
Im asking $40k or best offer. I have well over $75k in receipts from the last three years.
Pictures will be up shortly. Im 1500 miles away from the vehicle, so if you request pictures of certain items, it is going to take me a few weeks.
#2 IntercooledFlatty
IntercooledFlatty
    Get Sum
  • 14,390 posts
Posted 11 June 2019 - 08:58 AM
don't do it ;)
          MOPAR POWERED
#3 Preludedude
Preludedude
  • 2,963 posts
Posted 11 June 2019 - 04:10 PM
So what was the best pass it made?
#4 gtxthunder
gtxthunder
  • 1,939 posts
Posted 11 June 2019 - 05:10 PM
Hasn't been to a track in years. Ive only seen the car a handful of times in the past two years. It's time to move on.
#5 Preludedude
Preludedude
  • 2,963 posts
Posted 11 June 2019 - 08:20 PM
Maybe if you could enjoy it, you'd keep It.
#6 gtxthunder
gtxthunder
  • 1,939 posts
Posted 11 June 2019 - 08:23 PM
Probably. But with my career that isn't possible. If i get asking price ill include my 2017 enclosed trailer.
Edited by gtxthunder, 11 June 2019 - 08:25 PM.
#7 Turbo Cary
Turbo Cary
  • 1,683 posts
Posted 12 June 2019 - 10:22 AM
The transmission you have, is that the one from her car that got stolen and stripped or did she change to a different one before it was stolen?
#8 gtxthunder
gtxthunder
  • 1,939 posts
Posted 12 June 2019 - 10:43 AM
They built another Supra after the original was stolen.
#9 Turbo Cary
Turbo Cary
  • 1,683 posts
Posted 12 June 2019 - 07:00 PM
Ah i didnt know if parts were ever found. I remember they found it fully stripped which sucks cause that car had a lot done to it.
#10 Shaky
Shaky
  • 13 posts
Posted 14 June 2019 - 11:22 AM
Do you have pic's?
#11 Preludedude
Preludedude
  • 2,963 posts
Posted 14 June 2019 - 07:37 PM
View PostShaky, on 14 June 2019 - 11:22 AM, said:
Do you have pic's?
Here is his official build thread...
http://www.starquest...howtopic=150745
#12 gtxthunder
gtxthunder
  • 1,939 posts
Posted 14 June 2019 - 09:16 PM
Im flying to Tampa next Friday. Will update with quality pictures, dyno sheets, etc.
#13 Mech
Mech
  • 4,213 posts
  • Interests:Starquests
Posted 16 June 2019 - 01:03 AM
Why do all that work just to turn around and sell it?  Why take such a loss money wise?  You don't drive it now, but potentially in the future you will. Keep it.
#14 gtxthunder
gtxthunder
  • 1,939 posts
Posted 16 June 2019 - 04:25 AM
I've had the car since 2010. You've never lost interest in something? If I was trying to get the most money back, the car would be getting parted out right now. I work 45 plus weeks out of the year on the road - I've only seen the car a handful of times in the last 5 years.
#15 IntercooledFlatty
IntercooledFlatty
    Get Sum
  • 14,390 posts
Posted Yesterday, 09:05 AM
i understand...someone will get a killer car and a hellova deal
          MOPAR POWERED
