No more searching here it all is.
c/v axle take apart..
http://www.starquest...opic=144461&hl=
Idler arm bushing..
http://www.starquest...topic=143132=
Torque tube bushing.. (Also see GNT for new bushings)
http://www.starquest...opic=123245&hl=
Tilt steering lock permanent fix..
http://www.starquest...=113171&hl=tilt
Build you own oil cooler lines... (p.m. me for a custom built or OEM spec'd set I offer these for sale)
http://www.starquest...howtopic=134353
Water lines for turbo, AN fitting sizes and heat shielding...
http://www.starquest...topic=123261=
idler arm bushing flatty and fatty type...
Coolant bypass hose sans water pump removal...
http://www.starquest...howtopic=138599
Porting stock wastegate/manifold/turbine housing...
http://www.starquest...howtopic=143496
Code reader...
http://www.starquest...30614&hl=reader
Throttle shaft seals R and R...
http://www.starquest...howtopic=124046
center console latch repair...
http://www.starquestclub.com/forum/index.php?showtopic=135537&hl
Edited by JohnnyWadd
